Old 11-03-2009, 04:19 PM   eBay Motors   #1 (permalink)
raiderfan
raiderfan's Avatar
abs help
Anybody have a schematic of the back of the wheel hub where the abs line goes? I think I may have broken the wire, (as my abs light is on, and on the right front,the plastic clips that hold the wires in place are broken) but cannot see where it hopefully plugs into the caliper or wherever it may go...... thanks!
Jason M
white 2006 crewcab shortbox /lbz/31,000 miles/leveling kit
18" moto metal wheels/275/65/r18 hankook Dynapro mt
Westin wheel to wheel nerf bars
Bully stainless toolbox/Putco stainless bed caps/tailgate cap
lund stainless advenger bug sheild
pioneer AVH-P4000DVD w/ Ipod interface/xm/usb
Jlb door speakers/PPE standard
4" turbo back magnaflow (thanks Chad @ alligator performance)
2008 kz sportsman sportster 30SB toyhauler to drag around
raiderfan is offline   Reply With Quote
Old 11-03-2009, 05:00 PM   eBay Motors   #2 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Umm i think there are only 2 wires in there...take it apart and shoot for continuity. Or better yet, you can go to an autoparts store and have them scan your truck and it will tell you which one is bad. If the sensor is bad, you will probably have to change the hub unless you can work some magic with the sensor.
Old 11-03-2009, 05:14 PM   eBay Motors   #3 (permalink)
raiderfan
raiderfan's Avatar
hmmmm, I was really hoping to just change out a wire harness, as I got the wires with tire chains, it might happen again........might not be that easy
Jason M
Old 11-04-2009, 10:53 PM   eBay Motors   #4 (permalink)
ski
ski's Avatar
Look behind the rotor and you'll see where the ABS sensor goes into the wheel hub. Undo the bolt and carefully pry out the sensor and clean the area around the hole then put the sensor back in.
2002 GMC SLE Crew Cab, 181,000, Hypertech, S&B Intake, 4" Magnaflow exhaust with a Hushpower muffler
ski is offline   Reply With Quote
Old 11-04-2009, 10:54 PM   eBay Motors   #5 (permalink)
ski
ski's Avatar
http://www.2carpros.com/images-1/abs_sensor.gif
Old 11-05-2009, 05:43 PM   eBay Motors   #6 (permalink)
raiderfan
raiderfan's Avatar
thanks, I went out afer i posted, I took off my wheel, brakes and disk, found the sensor, and removed it, i do think the disk has to come off, as the back plate is in the way, thanks for the help!
Jason M
Old 11-05-2009, 06:12 PM   eBay Motors   #7 (permalink)
Ridin'GMC
Ridin'GMC's Avatar
Remove the backing plate. Spray it with lots of wd 40 or PB blaster.
06 LLY CCSB
Just another white truck on the site.
Tuned by Killerbee's Original LBZ tune.
480 rwhp & 830 lb-ft of torque as of 11-7-09 on stock tranny
Ridin'GMC is offline   Reply With Quote
Old 11-05-2009, 06:55 PM   eBay Motors   #8 (permalink)
raiderfan
raiderfan's Avatar
yep, got it out and changed, thanks !
Jason M
Old 11-05-2009, 07:40 PM   eBay Motors   #9 (permalink)
rkeithdavis
rkeithdavis's Avatar
Doesn't plug into the hub assembly. If you break the wires, the sensor assembly is no good unless you can somehow reattach them, which is unlikely if the break is close to the hub.
'04.5 GMC Sierra 2500HD LLY/Allison M74, Summit White, CC/SB SLE 4x4, Leather, Westin Nerf bars, DiabloSport Predator 2.02 (+65 hp), Backup Camera, Homebrew Biodiesel, Power Service, AC Delco stock filter w/TxC CAI, LuberFiner Fuel Filter, BTSI Security Lock, Stiff Throttle Spring, High Idle mod, EGR blocked, Resonator blocked, PCV rerouted, LBZ Mouthpiece, 2" cranked lift, 4" Banks turbo back w/muffler, Garmin C330 GPS, Tekonsha Voyager 9030 brake controller, PowerBright 400/800w inverter, All Headlights mod, OnStar, Spray liner, V-5 Talon, VentShades, James Window Tinting 20%, Engine Driven On-board Air, riding on Michelin LTX M/S 285/75 R16
rkeithdavis is offline   Reply With Quote
