Old 11-05-2009, 10:57 AM   eBay Motors   #11 (permalink)
warhorse
warhorse's Avatar
i couldnt check what the voltage was my instrument cluster is non functioning. not a single gauge or the display below it. witch i think i put a thread up about earlier but didnt get too much help. and my voltmeter is at my old mans house. either way im gonna get new batteries as soon as ive got my unenjoyment monies.
2003 2500HD (Bought it wrecked)
Bullydog Dynodominator with 110 hp tune, PPE boost valve .... otherwise stock for now.
95 sonoma with a solid front end (and a 4bt soon)
97 CBR Fireblade 12000 miles. cherry
74 cj5 only the frame is left stock. lift axles drivetraine. all of it bigger and better.
warhorse is offline   Reply With Quote
Old 11-05-2009, 11:30 AM   eBay Motors   #12 (permalink)
SteepyBS
SteepyBS's Avatar
im thinking thats your best bet is that they wont hold a charge cause of the fireworks show, if you put a couple new ones on hopefully youll be good to go!
good luck
Im Brandon, 18 from Seattle
03 Silverado 2500HD LT crew cab LONG bed
6" tuff country lift 315x75x16 on Raceline Renegades
Edge juice with attitude
aFe intake and Dual 4" exhaust
added tow mirrors, nerf bars, reverse lights
tweaked and tuned CB for police warnings
->77 Camaro Type LT 350sbc/TH350
and i paid for both my own rides
SteepyBS is offline   Reply With Quote
Old 11-06-2009, 09:07 AM   eBay Motors   #13 (permalink)
warhorse
warhorse's Avatar
yeah im hopin thats the case.
Old 11-10-2009, 04:04 PM   eBay Motors   #14 (permalink)
Len Todd
I do not think that arcing a wrench off the battery post will destroy a battery, let alone two. I have sparked a few times myself. It would take a direct short of several+ seconds. Plus, you are cranking.
Fully charged batteries should read 12.2 VDC with a voltmeter. You can get a cheapie analog voltmeter for $8.00 at Home Depot. Also, if the batteries are charged, they can be load tested. Typically auto parts stores will load test them for free. Also, you can get a charger for < $40 these days. Having these tools around and using them is a lot cheaper than buying new batteries. But, if they won't charge or give a good load test, then you know they are shot.
'09 2500 Z-71 HD with Allison
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
Len Todd is offline   Reply With Quote
Old 11-10-2009, 04:56 PM   eBay Motors   #15 (permalink)
warhorse
warhorse's Avatar
yeah ive got all of that stuff. and ive done all the tests. batteries are fine. I brought the alternators up to carquest yesterday. both of them the old one and the 145 amp i pulled at the wreckers tested good. now after i put the old one back in it worked just fine gauges came back on and the batteries got charged up while i ran around town today. then on the way home the battery light came on and it said they arent charging again. then i had no gauges all the way home. fuses all checked good and i cleaned all of my contact points. could something else cause this? like a regulator on the alternator going bad. but do those go out and comeback like that?
Old 11-10-2009, 06:05 PM   eBay Motors   #16 (permalink)
Len Todd
Have you checked all your grounds and cleaned the battery terminals? This sounds like a loose connection. What voltage are you seeing at the battery when you see the problem?
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
Old 11-11-2009, 12:04 PM   eBay Motors   #17 (permalink)
warhorse
warhorse's Avatar
12volts give or take. my terminals are pretty shiny so i dont think theyre the problem.
Old 11-11-2009, 02:58 PM   eBay Motors   #18 (permalink)
warhorse
warhorse's Avatar
well i went around town today and my truck went into limp mode. no reverse and 3rd gear only. so im pretty sure somthing is really messed up and none of the modules are seeing their desired voltage.
Old 11-11-2009, 04:00 PM   eBay Motors   #19 (permalink)
Len Todd
Warhorse: Where are you located in Upper Michigan?
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
Old 11-11-2009, 04:04 PM   eBay Motors   #20 (permalink)
Len Todd
SO, ... When it is acting up, measure the voltage at the back of the alternator. If you are not seeing > 13.2 VDC, then you have an intermittent alternator. Probably the stator opening up when it gets hot. When it gets cold, it works.
'06 Desert Fox TH
'53 Cranky Spouse
N8AGS
