k just changed my alternator and now my truck wont start. when i was reattatching the power cable i accidentally touched the turbo mouthpiece with the wrench and there was a few big sparks. could this have killed my computer? if not what could be the problem. it cranks over real good and i think its getting fuel. primed it a couple times now. please help.
__________________ 2003 2500HD (Bought it wrecked)
Bullydog Dynodominator with 110 hp tune, PPE boost valve .... otherwise stock for now.
95 sonoma with a solid front end (and a 4bt soon)
97 CBR Fireblade 12000 miles. cherry
74 cj5 only the frame is left stock. lift axles drivetraine. all of it bigger and better.
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
i have been and i dont see anything burnt yet. its really starting to piss me off. should disconnected the batteries. woulda been done and driving the sob. now since i tried to be lazy im chasing gremlins.
i just looked through all of the fuses in the cab and under the hood cant find one burnt are there any hiding somewhere or could it be one of those big black ones??? i switched a few around and everything still works but it wont start.
I don't know if GM uses them, but some cars have "fusible links". A really dumb idea, in my estimation because you can't tell if they're blown, and usually they are hardwired. Perhaps some of the other guys might know for sure.
__________________ 2007 2500 HD Classic LBZ/Allison, standard cab, stone stock, rollup windows, manual door locks, towing and plowing packages with Western plow.
Any luck yet? Now I'm starting to side with you on the ecm, but would also think if it did fry something it should throw some codes. Got anything to check for codes? Would be nice to have some of the pros chime in, but I think there all in the post The best truck ever.
__________________ 2009 Silverado K3500 LT LMM CC SRW All Stock.
4" mbrp in a pile on garage floor.
efi live
egr block plate on the way.
well i left the battery charger on it since about noon today and it just fired up at about a 9 o'clock. now, i let it run for a while then took it out for a half hour drive then let it run in the drive way for a while and guess what. i shut if off and it wouldnt start again. i think my batteries are right shot. ive still got my old alternator (105amp) and the 145amp i replaced it with ill have the old one checked and if its still good then i know its gotta be the batteries. but still it was cranking pleanty fast. i dont know why it wouldnt start. thats gotta be it. cuz computers dont go out and then come back.
did you check to see what your voltage was when the truck was running? if it was around 14 your alternator is fine
sounds to me like its your batteries, the short to ground might have killed them when your wrench hit
__________________ Im Brandon, 18 from Seattle 03 Silverado 2500HD LT crew cab LONG bed
6" tuff country lift 315x75x16 on Raceline Renegades
Edge juice with attitude
aFe intake and Dual 4" exhaust
added tow mirrors, nerf bars, reverse lights
tweaked and tuned CB for police warnings ->77 Camaro Type LT 350sbc/TH350
