Old 11-05-2009, 11:15 AM   eBay Motors   #11 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
Originally Posted by Hondarider552 View Post
Check your weep hole under WP.
as far as changing WP you will need to remove the starter so you can hold the flexplate from moving. IIRC balencer bolt is 36mm nut, reverse threads. balancer must come off to replace WP.
r u serious the starre i m used to changin chevy 350 wp couple bolts and ur done i heard this is a 4 hr job
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
Old 11-05-2009, 11:22 AM   eBay Motors   #12 (permalink)
DuramaxSMOKE11
DuramaxSMOKE11's Avatar
yea it is. its not that bad or a job tho. just take your time and clean and make sure everything is right cause all the pumps use a o-rings for seals not gaskets
2005 Chevy 2500HD Duramax LLY, Banks ram air intake w/super scoop, Banks 4" exhaust, CAT DELETE and NO MUFFLER, EGR blocker plate & fingerstick, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performance and Guy at SoCal Diesel
DuramaxSMOKE11 is offline   Reply With Quote
Old 11-05-2009, 06:30 PM   eBay Motors   #13 (permalink)
thank u for all ur help
Old 11-06-2009, 06:19 AM   eBay Motors   #14 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
if your good you can remove the fan without removing the starter,i wasnt able to but a mechanic friend did it.i forgot to ask him how though!
you will have to remove the TCM,fan shroud,fan,damper pulley and then you can get to the 3bolts(15MM)holding the main pump on then you have to remove 2 nuts(13MM)connecting the line going to the oil cooler! its quite easy after you have done it a few times!
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 11-06-2009, 01:34 PM   eBay Motors   #15 (permalink)
thank u james that clears it up a little
Old 11-09-2009, 10:43 AM   eBay Motors   #16 (permalink)
wow that was tough and a lot of work involved in doing that i hope i never have to do that again wate rpumps suck on duramaxs end of story
Old 11-09-2009, 11:33 AM   eBay Motors   #17 (permalink)
DuramaxSMOKE11
they do for first time doers but after that they get easier and easier. the hardest part will always be the fan and the dampner bolt
To come soon
Old 11-10-2009, 03:29 PM   eBay Motors   #18 (permalink)
jc1843
The bolt is standard right hand threads-- not reverse [left hand]threads
Chevy 04.5 LLY, 265s, shell, XDR, MikeL 6spd, TransGo, deep pan, blocked, fingered, de-badged, PVC, 65 Gallon Aero tank, PPE, LBZ- mod, Pre-fuel filter, tow mirrors, BU cam, gauges, GPS, Sirius, bags
Old 11-12-2009, 01:12 AM   eBay Motors   #19 (permalink)
yea i found out it was a pain to break it loose had a 6ft cheater bar on it
