i just start my truck it lik 30 degrees high idle kicks on im b s with my buddys for like serious 5 min and coolent just starts dumpin out right under where the water pump is it didnt even have time to build pressure then low coolent light come on so i shut it off ran to walmart got 2 gallons of dexcool and drove it home very carefully wtf is wrong ith truck is kiilin me one hing after another this time is not my fault
water pump? or the hose on the water pump has a hole in it have you looked it all over yet?
__________________ Chase
LMM
EFI Live
Dpf and Egr Deleted
Trans Go Jr
You can get much farther with a kind word and a gun than you can with a kind word alone.
MPF ALL IN ONE LOGISTICS LLC
usually the head gaskets will push coolant out the over flow unless then completely went to hell to push that much coolant out and they would have pushed it out on both sides of the truck not the front usually im not saying they wouldnt do that, just seems odd that its by the water pump
LMM
EFI Live
Dpf and Egr Deleted
Trans Go Jr
mine just went out a few weeks ago... there a real pain
__________________ 2003 Silverado 2500HD 4x4,Ext, LB7, Silver
6inch Black Single,
18inch Rockstars with 285 Nitto Terra Grapplers
Ported MouthPiece,PPE Lift Pump
Autometer Cobalts, K&N Intake, Cognito HD Tie-Rods EFI Live with DSP 2 Switch Tuned by MMLMM SunCoast Stage III
dont worry Matt its not as bad as it sounds..i'm sure its just a hose since in a truth i dont see how it could be anything else..if it is the WP i have changed a few,they are a pain to do but with a lil time it can be done! have you looked at it already? in the last year i have torn heads of 3LLYs and none of them lost coolant like that..the WP gaskets are known for going bad but they wont loose coolant fast though..AutoZone has new ones for $100
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
if anyone has changed a wp on a d max please help me with some info and trick of r /r
Check your weep hole under WP.
as far as changing WP you will need to remove the starter so you can hold the flexplate from moving. IIRC balencer bolt is 36mm nut, reverse threads. balancer must come off to replace WP.
__________________ Brian, 19, 06 LBZ, EFILive, MM Diesel Performance, Alligator Performance, Suncoast, TTS, Cognito, High Tech Turbo, PPE, Magnaflow540rwhp/1000tq. 12.64/107.52
