Old 11-05-2009, 06:04 AM   eBay Motors   #1 (permalink)
jmc
hellllllppppp thought i fixed it ....
ok 2001 178,000 stock everything new injectors new fuel filter housing new rubber hoses no air in fuel filter truck starts well almost always then once in a while , well now once a week it wont start at all i pump the primer crank then need to pump from lack of pressure it seems but wont start. is it fpr or cp3? is cp3=fuel pump please help... oh i also notices a slight pulse in the idle. after i did the injectors in went away but is back ever so slightly very minute compared to what it was
jmc is offline   Reply With Quote
Old 11-05-2009, 06:17 AM   eBay Motors   #2 (permalink)
duramax07tmd
duramax07tmd's Avatar
You might have a small leak in the fuel filter housing but you said it was new, so this does not help you. Someone will chime In.
07 Chevrolet Silverado Classic
2500HD 6.6L Duramax LBZ < For Sale
Allison 6 Speed
CC SB LT2 4x4
Edge Evolution Race
4 inch MBRP Turbo Back
Ready Lift Leveling Kit
285/75/16 Michelin LTX A/T 2
Resonator Plugged
Llumar 5% tint
Special thanks to Tyler @ www.meyerperformance.com
duramax07tmd is offline   Reply With Quote
Old 11-05-2009, 06:20 AM   eBay Motors   #3 (permalink)
jmc
the cp3 or fpr is what i am thinking would the cp3 cause lack of pressure with no air in fuel filter
Old 11-05-2009, 06:28 AM   eBay Motors   #4 (permalink)
jmc
one other thought when i did my injectors the high pressure lines had a little corosion and my ses registerd a small fuel leak for 2 days when i would stomp on it do you think that maybe the fuel is leaking out before the injector but not regeistering now?
2001 stock 178,000 new injectors ff housing rubber hoses and who knows whats next.
Old 11-05-2009, 06:43 AM   eBay Motors   #5 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
I think that sounds like you have fuel leaking back through the fuel return lines off the CP3. I COULD be wrong, but I had another friend who chased a similar issue for months until they found an irregular weeping happening right at the fuel return line...
Hope that helps a little...
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
