We have an 06 C5500 truck with a 6 speed Allison tranny that is giving us a lot of problems.
We changed both tranny filters and the fluid as a general service procedure.
Now the tranny will not go into gear until you rev the motor a little, and when it does it really "bumps" and then will move out. Once it is driven for a while, it works fine. When we shut it off for a long period (overnight or even just a few hours) it has the same problem again.
Does anyone know the proper setting codes for this tranny, and have any idea what is going wrong
FYI, it was working just fine until the filter and fluid change
__________________ Rick
1985 Chevy 3/4 ton diesel, 87,000 original miles, immaculate inside and out
1991 Ford Aerostar van - 1991 Ford 1-ton van with wheel chair lift for my wife
2006 Jeep liberty, with Rubicon under carriage "OldTow" fits me pretty well......It oughta at 72 years young and still hookin !
Old Cowboy By Trade, now driving a tow truck !
Cowboy Preacher By Calling....
__________________ PIN IT TO WIN IT
2003 2500HD ECSB Duramax
38,000 Miles
AFE Stage 2 Intake
AD100- Thx Todd MPF
285/75/16 MTR's
Every window 20%
In the beginning after the filter change it was filled and run way over full, but is at the proper level now.
It now has about 160,000 miles on it !
how often did you change the fuild/filter before the last change? you could have washed away some of the grit/chit holding things together causing improper enguagement and possible slippage. Do you ever notice a shift hesitation?
38,000 Miles
AFE Stage 2 Intake
AD100- Thx Todd MPF
285/75/16 MTR's
Every window 20%
Could be NSBU switch, even though your symptoms are little different than that. Something to try though, they go bad often. NAPA has them for fairly reasonable cost.
__________________ 2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
To the best of my knowledge we didn't find any foreign material in the filters or the pan, and the mechanic said as far as he can tell, mechanically it was fine. Didn't notice any slippage before.
When we got the truck it had 114,000 miles on it, so don't know about the service it had before.
OK, now I am going to show you just how dumb "old cowboys" are. What is the NSBU switch??
Neutral Safety Back up switch. It is on the drivers side of the trans on the outside. Do a search and you'll find lots of info as they go bad regularly. Just replaced mine, about $60 and 15 min to fix. Had some of the same probs as you.
