Old 11-05-2009, 10:34 PM   eBay Motors   #1 (permalink)
SteepyBS
SteepyBS's Avatar
Exclamation ball joint!!
so im in the process of installing a new passenger side upper ball joint, but as i tighten down the stud nut the stud starts to spin inside the joint so i cant torque it, ive tried hanging the weight of the hub assembly and also jacking up the wheel end so the UCA is being pressed up but it still spins
Im Brandon, 18 from Seattle
03 Silverado 2500HD LT crew cab LONG bed
6" tuff country lift 315x75x16 on Raceline Renegades
Edge juice with attitude
aFe intake and Dual 4" exhaust
added tow mirrors, nerf bars, reverse lights
tweaked and tuned CB for police warnings
->77 Camaro Type LT 350sbc/TH350
and i paid for both my own rides
SteepyBS is online now   Reply With Quote
Old 11-05-2009, 10:37 PM   eBay Motors   #2 (permalink)
blott22
blott22's Avatar
on my 98 1500 i replaced all the ball joints and i dont remeber the best but i thought i got some vice grips and wrapped a towl around it and clamped it.
Brent
2006 Chevy LBZ Crew Cab W/T
PPE Standard
Resonator Plug, Transgo Jr.
Banks Ram Air Intake, Glowshift Gauges, Diamond Eye 4" Turbo Back, Limo Tint, 18" Moto Metal 955, Dual Flip Deck, 1200 watt amp, 2 Eclipse 10" subs.
FOR SALE
Diablosport Predator
blott22 is offline   Reply With Quote
Old 11-05-2009, 10:59 PM   eBay Motors   #3 (permalink)
Dmax15
Dmax15's Avatar
Do the threads look ok on both the stud and the nut? I'd clean them up as much as possible and put some grease on the threads then put some weight on it to keep it from spinning. Mine did this too but somehow I was able to get enough weight on it to keep it from spinning but I can't remember exactly.
2002 GMC LB7
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is online now   Reply With Quote
Old 11-05-2009, 11:54 PM   eBay Motors   #4 (permalink)
SteepyBS
SteepyBS's Avatar
figured it out! i had to put a pry bar between the UCA and the knuckle and ended up not using the nylock that came with the new ball joint because the nylock would just bind everything up
bad balljoint complete, now to replace the other one when im not getting rained on the whole time
Old 11-06-2009, 09:05 PM   eBay Motors   #5 (permalink)
blott22
blott22's Avatar
Pry bar. thats what it was not the vise grips
Brent
PPE Standard
FOR SALE
