Old 11-06-2009, 01:49 PM   eBay Motors   #1 (permalink)
dannyshumate01
window motor assembly
in my drivers side motor assembly the wire that pulls the window up and down broke. I would assume you have to replace the motor also or can you just replace the wire? has anyone tackled this or is this somethin I should take to the shop and have fixed?
2003 Sierra Crew Cab
Superchips Flashpaq Programmer
dannyshumate01 is offline   Reply With Quote
Old 11-06-2009, 02:08 PM   eBay Motors   #2 (permalink)
CA07CC4X4LMM
CA07CC4X4LMM's Avatar
I replaced the window motor on a Suburban once. The motor came off of the assembly with the wire and guide. If it is similar then you should be able to re-attach the existing motor to a new assembly.
2007 Chevy 2500HD Duramax Diesel LMM, 4x4, Crew Cab, Leer Shell, Bed Rug, Side Steps, 265 BFG AT-KO
CA07CC4X4LMM is offline   Reply With Quote
Old 11-06-2009, 02:52 PM   eBay Motors   #3 (permalink)
scottdomine
scottdomine's Avatar
You need a window regulator and the motor may or may not come w/ that part. But if you can get just the regulator w/o the motor, that's all you need
2002 Silverado 2500HD LBZ FE9 Ext Cab 4x4 LT, 133k miles (08/12/09), American Racing Chrome Nitro's, Goodyear Wrangler MT/R 285/75R16, Resonator plugged, B&W Turnover ball, Amsoil Synthetics throughout truck, Bilstein 5100 shocks, Westin Chrome Bars, Adrian Double Lid Box, Line-X sprayed liner, PPE Economy Tuner Running Level 2(Thanks Husker Diesel)! 4" MBRP Turbo Back w/ chrome tip (Thanks again to Husker Diesel), Pillar Mounted Autometer Cobalt Boost and Pyro gauges
"Contact All in One Logistics or http://www.syntheticmotorsports.org for all your AMSOIL needs!"
scottdomine is offline   Reply With Quote
Old 11-06-2009, 03:18 PM   eBay Motors   #4 (permalink)
down_hiller
down_hiller's Avatar
I've changed it before on my dads truck we were looking around and you can buy it with or with out the motor I think its a common problem we had to do both sides
Down_Hiller
1997 Chevrolet k1500 4 inch lift 33" tires dual exhaust
1971 chevrolet k5 blazer 4 inch lift chevy 350 magnaflow exhaust
down_hiller is offline   Reply With Quote
