Old 08-10-2009, 06:10 PM   eBay Motors  #21 (permalink)
floridamax's Avatar
I know i have to get rid of my dpf too. Im pretty sure it's the veggie oil that's cloging my dpf. It's just the manual regen that's scares me with the idle at 2500 rpm. sounds like the motor is gonna blow
08 GMC Crew cab long bed 4x4 with 20'' xd spy and terra grappler 305/55/20. airaid filter and box, Full 4'' mbrp turbo back with 6'' tip. Quadzilla stealth 2 on 90hp tune, EGR block off plate and PCV reroute. I t does smoke like a mofo too. Staying off the pedal cause I don't like to piss tree Huggers off.
floridamax is offline   Reply With Quote
Old 08-10-2009, 06:21 PM   eBay Motors  #22 (permalink)
EFI'd and lovin it
Johnasara's Avatar
You have the programmer go get a piece of 4" exhaust pipe and delete just the DPF. You will have to go online and update your quad. But you can do a basic DPF delete by simply removing it.
4" DIAMOND EYE EXHAUST,
EFI LIVE,DSP5,S&B COLD AIR INTAKE, RESONATOR PLUGGED
AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....
WORK RIG
DPF GONE!!!EFI LIVE,DSP5, K&N FILTER, MAF CLEANER IN BED
This is not only your forum you have to share it with over 30,000 others
Old 08-10-2009, 06:24 PM   eBay Motors  #23 (permalink)
floridamax's Avatar
Yeah the programmer update is easy but until i get the exhaust i have to get that dpf cleaned. Im leaving in vacation thursday for 10 days so no time for an exhaust yet.
Old 08-10-2009, 06:25 PM   eBay Motors  #24 (permalink)
floridamax's Avatar
anyone knows if it can be bad for the motor if the manual regen makes it idle at 2500 rpm?
Old 08-10-2009, 06:30 PM   eBay Motors  #25 (permalink)
EFI'd and lovin it
Johnasara's Avatar
I would say it will not hurt it. If you feel like it may be an issue try to drive it around for a while and let it do it on its own.Reset the code with the quad and then drive it
WORK RIG
Old 08-10-2009, 06:33 PM   eBay Motors  #26 (permalink)
floridamax's Avatar
ok i will try now
Old 08-10-2009, 07:01 PM   eBay Motors  #27 (permalink)
blackdeath's Avatar
nope thats what it is , thats why our dont regen at idle , i hated it thats why i just took it off
2008 silverado dmax LTZ, aFe stage 2,suncoast stage 4,1056 converter,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 08-10-2009, 08:10 PM   eBay Motors  #28 (permalink)
Get a quad with dpf delete and you wont mad that you have more money in your pocket from spending less time at the pump. DPF doesnt make any sense.....less soot than before but to get there you have to burn a crap load more gas?? I guess if you cant see the polution it is better..so the tree huggers say
matth113 is offline   Reply With Quote
Old 11-16-2009, 06:15 PM   eBay Motors  #29 (permalink)
darkcherry08's Avatar
I got a little over 27,000 miles before mine came on and quite surprised it took this long.
[B]08 2500 HD Z71
MBRP turbo back,quad on 110 hp tune,ppe shim kit,KandN drop in,modded airbox,readylift leveling kit with 325/60 toyo tires with procomp 18-9in rims,all molding and badging are gone except z71...
Oh did I say my cat and dpf fell offf
darkcherry08 is offline   Reply With Quote
