Old 05-10-2008, 07:14 AM   eBay Motors   #1 (permalink)
jimschaechter
Points: 1,125, Level: 13
Points: 1,125, Level: 13 Points: 1,125, Level: 13 Points: 1,125, Level: 13
Activity: 0%
02 Duramax black smoke during acceleration
My Duramax runs well, but under acceleration puffs clouds of black smoke. It has not done this until recently. I don't usually give i tmuch throttle, but I saw that when I did, it puffed a big black cloud. Now the power is fine even towing. I haven't lost any real fuel mileage so oI wonder if I have an injector problem or ?? I have had all 8 injectors replaced under warranty a few years back. I also hav no mods to the truck other than a K and N filter. It is clean. Any ideas? Thanks, JIm
jimschaechter is offline   Reply With Quote
Old 05-10-2008, 07:22 AM   eBay Motors   #2 (permalink)
blackdeath
Points: 2,521, Level: 20
Points: 2,521, Level: 20 Points: 2,521, Level: 20 Points: 2,521, Level: 20
Activity: 8%
Activity: 8% Activity: 8% Activity: 8%
blackdeath's Avatar
did u buy it new
2008 silverado dmax LTZ, aFe stage 2 ppe level 5,dpf delete,autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, 35"nitto a/t. 4"turboback exhaust straight pipe
2008 traiblazer ss, straight pipe , cortex tune
blackdeath is offline   Reply With Quote
Old 05-10-2008, 07:27 AM   eBay Motors   #3 (permalink)
jimschaechter
Activity: 0%
Yes, I did. It has 182,000 miles. 6 speed 4wd crewcab shortbed. I do tow a racecar trailer and horse trailer at times, but nothing extreme in weight. I recently had a glowplug controller go bad, but I am not sure if it was smoking rigt after. Nothing looks amiss under the hood. I remeber when my injectors went bad, the pipe was wet and the crankcase filled with diesel fuel. I have no signs of this now.
Old 05-10-2008, 08:20 AM   eBay Motors   #4 (permalink)
blackdeath
Activity: 8%
blackdeath's Avatar
well our 2006 shop cummins with only cai, smokes black with heavy accel
Old 05-12-2008, 06:44 PM   eBay Motors   #5 (permalink)
nosup4u
Points: 250, Level: 4
Points: 250, Level: 4 Points: 250, Level: 4 Points: 250, Level: 4
Activity: 0%
nosup4u's Avatar
its just unburnt fuel. no worrys
nosup4u is offline   Reply With Quote
Old 05-12-2008, 06:49 PM   eBay Motors   #6 (permalink)
Meyerperformance
Points: 5,417, Level: 31
Points: 5,417, Level: 31 Points: 5,417, Level: 31 Points: 5,417, Level: 31
Activity: 100%
Meyerperformance's Avatar
I cant rememeber if those motors have egr but that could be problem if its going bad on you.
07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice.
www.meyerperformance.com
(812)-344-4421 Tyler
Last edited by Meyerperformance : 05-12-2008 at 06:50 PM. Reason: didnt read thread carefully
Old 05-13-2008, 05:02 PM   eBay Motors   #7 (permalink)
Mikeyt85
Points: 466, Level: 7
Points: 466, Level: 7 Points: 466, Level: 7 Points: 466, Level: 7
Activity: 4%
Activity: 4% Activity: 4% Activity: 4%
Has your oil level dropped? Does the smoke have a blueish tint to it? If it does it may be your turbo.
Mikeyt85 is offline   Reply With Quote
Old 05-13-2008, 08:39 PM   eBay Motors   #8 (permalink)
jaydawg
Points: 666, Level: 9
Points: 666, Level: 9 Points: 666, Level: 9 Points: 666, Level: 9
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
jaydawg's Avatar
I would run some "stanadyne" fuel treatment first. Under hard accel if u can do a 9 count and the soke is gone, that is usually normal(per GM). Try the additive first...u might have some stuff causing the inj. to hang open. Get rid of K & N filter..oil in filter will scew MAF readings..causing black smoke.
jaydawg is offline   Reply With Quote
Old 05-14-2008, 02:56 PM   eBay Motors   #9 (permalink)
woodshop
Points: 269, Level: 5
Points: 269, Level: 5 Points: 269, Level: 5 Points: 269, Level: 5
Activity: 0%
My 06 does this also. I drive it with a real easy foot most of the time and in town driving. I step on it getting on the freeway and I get the smoke. The next time I get back on the freeway to come home it doesn't smoke. I think driving it realy easy does not get all the soot out and you need to blow it out every once in a while. Just my oppinion.
woodshop is offline   Reply With Quote
Old 05-14-2008, 05:16 PM   eBay Motors   #10 (permalink)
kurt
Points: 248, Level: 4
Points: 248, Level: 4 Points: 248, Level: 4 Points: 248, Level: 4
Activity: 0%
i agree.
if i baby the truck around, the first time i get on the freeway i blow smoke like a train. It calms down after that first wot and i have to baby it for awhile before it will smoke again.
kurt is offline   Reply With Quote
