Old 05-11-2008, 09:02 PM   eBay Motors   #1 (permalink)
keith t.
Points: 80, Level: 1
Points: 80, Level: 1 Points: 80, Level: 1 Points: 80, Level: 1
Activity: 0%
lost power
i have 04 it has the edge attitude cat back and afe cold air when i hit it hard to pass i loose power i pull over turn it off wate start up then its ok i heard theres like a popoff valve and it goes in limp mode and you can only go like 20mph can any one help
keith t. is offline   Reply With Quote
Old 05-11-2008, 10:52 PM   eBay Motors   #2 (permalink)
Tow Master
Idiot lookin at the computer
Points: 12,439, Level: 48
Points: 12,439, Level: 48 Points: 12,439, Level: 48 Points: 12,439, Level: 48
Activity: 89%
Activity: 89% Activity: 89% Activity: 89%
Tow Master's Avatar
Hello and welcome to the forum!!!
Well unfortunatly all the Duramax's are known for smoking the transmissions when you add over 90HP of power. What happens is thereis so mutch torque when the truck shifts from 3-4 and 4-5 it slips the clutches and burns them causingthe transmission to go into limp mode. The bad part is when you do it once the damage is already done.
Your transmission needs overhauled and get some aftermarket parts especially a torque converter. Fo most of the upgrades it costs you about $2500-3000 installed. If you dont have the $$ your better to lower the edge settings to #1 or 2 untill you can do the trans.
Jason
Old 05-12-2008, 12:02 AM   eBay Motors   #3 (permalink)
BigRedChevy
Post Slut
Points: 10,875, Level: 45
Points: 10,875, Level: 45 Points: 10,875, Level: 45 Points: 10,875, Level: 45
Activity: 100%
BigRedChevy's Avatar
It could also be a fuel filter. Did it just loose power and have a 2000 rpm rev limiter or did it lock in 3rd gear? Did it throw a code? If you had the rev limiter then change the fuel filer and try that, but like Tow Master said keep it under 90HP and watch the 4-5 shift.
KYLE
Old 05-17-2008, 04:28 PM   eBay Motors   #4 (permalink)
keith t.
Activity: 0%
thanks for getting back so fast i got called out of town the next day i did call edge they said to up my low boost fueling adj to 4 if it dont work go to 5 if not that send it in thay will reprogram it so we will see as for the settings i only run in 1or 2 just to tow as for the fuel filteri change it often it did just loose power with the rev limiter but no codes thanks again
