| If it is a LB7 (8th digit in vin is a 1) then it is probably a bad injector. The injectors in the LB7s are covered under a 7yr 200000 mile warranty. If it is a LLY (8th digit in vin is a 2) then it may be the injector wiring harness. The have been known for the wires rubbing a through and causing problems.
__________________ KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan EFI Live Tuned by IdahoRob!!!!
