Old 05-13-2008, 09:55 PM   eBay Motors   #1 (permalink)
07nastymax
Points: 407, Level: 7
Points: 407, Level: 7 Points: 407, Level: 7 Points: 407, Level: 7
Activity: 0%
07nastymax's Avatar
Fuel Knock
I have an 07 LBZ. When i get on the throttle about 50% the engine starts to knock a little when i get on the throttle 100% it really sounds bad. From 100% to closed throttle the noise goes away. The truck idles fine no engine codes. The balance rates are ok. I checked the compression today and did a leak down test both were fine. I dont want to replace any Injectors if its an ECM problem or an ECM if its an injector problem. It only does it when my EFILive tune is on just dont know which one it could be if either of those two any help would be awesome. Thanks for the help guys!
07 LBZ, EGR Block-off, PPE Lift Pump and race valve, Suncoast V with 1057, Volant Intake, 5" Turbo back.
Just got EFI Live...cant wait to see what this truck is capable of.
SNIB
07nastymax is offline   Reply With Quote
Old 05-13-2008, 10:02 PM   eBay Motors   #2 (permalink)
Tow Master
Super Man Moderator
Points: 10,595, Level: 44
Points: 10,595, Level: 44 Points: 10,595, Level: 44 Points: 10,595, Level: 44
Activity: 95%
Activity: 95% Activity: 95% Activity: 95%
Tow Master's Avatar
Did you check the injectors them self? I know you can check them with a multi-meter
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Old 05-14-2008, 11:17 AM   eBay Motors   #3 (permalink)
duramaxin14
Points: 2,259, Level: 19
Points: 2,259, Level: 19 Points: 2,259, Level: 19 Points: 2,259, Level: 19
Activity: 0%
duramaxin14's Avatar
Its normal its the advancement in timing and needing more fuel. When i am at the drag stirp or pulling the sled or trying to get my big spinny then to light without spooling it does it real bad. Make sure timing in the tune is no more then 26 % or it could send a rod south
Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
duramaxin14 is offline   Reply With Quote
Old 05-14-2008, 11:35 AM   eBay Motors   #4 (permalink)
Meyerperformance
DPF Delete man
Points: 8,054, Level: 38
Points: 8,054, Level: 38 Points: 8,054, Level: 38 Points: 8,054, Level: 38
Activity: 100%
Meyerperformance's Avatar
Ya that sounds like a timing tick, becuase its advanced with your efi live
07.5 Chevy Summit White Reg cab LMM, Quadzilla steath 2, 5" MBRP straight pipe, 5" turn-down DPF Deleted, Cobalt boost & pyrometer, line of fire and ice. 5% tint. Banks Ram air intake.
www.meyerperformance.com
(812)-344-4421 Tyler
Old 05-15-2008, 12:20 PM   eBay Motors   #5 (permalink)
07nastymax
Activity: 0%
07nastymax's Avatar
K ill check thanks guys
SNIB
Old 05-15-2008, 12:24 PM   eBay Motors   #6 (permalink)
07nastymax
Activity: 0%
07nastymax's Avatar
Tow Master please explain more about the multi-meter test you are talkin about.
SNIB
Old 05-16-2008, 12:41 AM   eBay Motors   #7 (permalink)
Tow Master
Super Man Moderator
Activity: 95%
Tow Master's Avatar
Hmm I know you can do it but Im not the best with a multi meter. Heres some of the info I have on it
Jason
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
