Old 05-26-2008, 04:26 PM   eBay Motors   #1 (permalink)
r81ders
r81ders's Avatar
please need any help
i got a 04 durmax with stack edge prog. i use to have power when i hit 2 rpms it would scream like i want it to and i felt power kick in, i was going up a hill and lost power truck shut down. it turn back on and able to get to a dealer they said bad fuel filter. They gave it back and it ran great few days later about to jump on highway and samething happen and now dealer says cant find no problem and when i try to punch it it goes to 3 rpms and it screams just few seconds and it feels like it shifts to next gear. i dont have that power i use to have and it feels like a reg. truck i called edge and they help me test and prograhmers r ok..thanks for any help or ideas
r81ders is offline   Reply With Quote
Old 05-26-2008, 06:44 PM   eBay Motors   #2 (permalink)
blackdeath
blackdeath's Avatar
u need to give us some info on ur truck, mods, codes if any, im not sure what 2rpm and 3 rpm mean.... or are u saying 2000 and 3000 rpm
2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
2008 traiblazer ss, straight pipe , 1.5" down
blackdeath is offline   Reply With Quote
Old 05-26-2008, 11:48 PM   eBay Motors   #3 (permalink)
Tow Master
Idiot lookin at the computer
Tow Master's Avatar
Welcome to the forum!
Thats strange. Do what mods do you have done to the truck?
The truck could of went into limp mode due to the trans slipping with all the extra power. You could also have some junk in the tank causeing the fuel filter to clog. Do you have anything done to the trans?
Jason
Old 05-27-2008, 09:00 PM   eBay Motors   #4 (permalink)
r81ders
r81ders's Avatar
check this out i did get codes the first time i took the truck to the dumb ass dealer i got 2 sets of trany codes but they said it was my sterio system that caused those codes to go off and that my trany was ok, thats when they said it was my fuel filter that went bad and they gave my truck back ok, thats why i did not make big deal about there poor excuse to my codes but now that the truck is doing the same thing again they dont have a answer, they say truck is ok?? BLACKDEATH i do mean 2000 & 3000 RPM, my truck has stack edge prog, and K&N filter system with a cut out bottom of the air filter box,4 inch exhaust (BANKS)strait with no catalitic (no back pressure). my problem is no power..my trany seems ok it does not slip and dealer said its ok, my gears are stock with 38inch tires on 20inch rims..
Old 05-27-2008, 09:03 PM   eBay Motors   #5 (permalink)
r81ders
r81ders's Avatar
TOW MASTER what is limp mode and how do i get out or fix
Old 05-27-2008, 09:14 PM   eBay Motors   #6 (permalink)
Maverick684
Maverick684's Avatar
The limp mode that Tow Master is talking about is when the transmission senses slippage and in most cases will either lock you into 3rd gear or limit your rpm's to 2000. The quick temporary fix is to pull over and shut the truck for a minute or two then clear the codes when you get home. About the only fix is to either back off the throttle or replace the trans with a high performance one. Honestly, I am suprised it lasted this long with the size of your truck and the tires. Also I wouldn't rule out low fuel rail pressure either.
05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
On the Way: PPE intake manifold w/EGR delete
Maverick684 is offline   Reply With Quote
Old 05-27-2008, 11:05 PM   eBay Motors   #7 (permalink)
durafire15
durafire15's Avatar
I had the same thing happen to me a couple of times.... Programmed my truck to a higher level without doin mods to the tranny went into limp mode.... try turning down ur horsepower level, i also had bad fuel in my filter....
durafire15 is offline   Reply With Quote
Old 05-28-2008, 12:34 AM   eBay Motors   #8 (permalink)
Diesel Nut
Diesel Performance
Diesel Nut's Avatar
What were the trans codes you had?
I am with these guys and with out further diagnostics it sounds alot like you limped the trans. How many miles on your rig?
We are very busy in the shop, please call for fastest service!
Diesel Nut Motorsports
Everything you need for perfomance
Suncoast, PPE, EFI live, you name it, we have it
1-800-450-7036
Amsoil Online Store
Save some money - Become an Amsoil Preferred Customer
Make some money - Become an Amsoil Dealer
Diesel Nut is offline   Reply With Quote
Old 05-28-2008, 03:11 PM   eBay Motors   #9 (permalink)
TYREBOYZ_DEMAXIN
Experienced Post Whore
TYREBOYZ_DEMAXIN's Avatar
one more question do you have the LLY or LB7.the way to tell is using the Vin # count the 8TH didgit in from right to left and if it is a 1 it is the LB7 if it is a 2 it is the LLY.the reason i ask is if it is the LLY you could be dealing also with a 1093 code which is a low fuel rail pressure but by the way it sounds your going to have to upgrade the tranny or back the power down.
James
TyreBoyz Pulling Team
Old 05-28-2008, 10:43 PM   eBay Motors   #10 (permalink)
Tow Master
Tow Master's Avatar
Yup exactly what Maverick684 said about the "limp mode".
Jason
