Old 07-05-2008, 01:45 PM   eBay Motors   #1 (permalink)
dieselkid73
no crank, no start, nothing...
2004.5 LLY...i turn the key and the gauge backlight comes on as well as the battery light...no click, no crank, nothing...all accesories, radio, lighting, etc. function corrrectly; just no power to any other idiot lights within the guage cluster...could this mean my PCM is fried?? all fuses and relays check out, checked and rechecked looking at each one and with voltmeter...please help..thank you!
dieselkid73 is offline   Reply With Quote
Old 07-05-2008, 01:48 PM   eBay Motors   #2 (permalink)
deeretracks
The Sheriff
deeretracks's Avatar
Check your batt. cables over good. And check your batt. Make sure you unhook them so that you get an accurate reading.
Craig
2001 Chevy, 4 door, short bed,D-Max, 2 wd.
Special Thanks goes to the person in the WAL-MART parking lot for installing it for me,
Old 07-05-2008, 01:54 PM   eBay Motors   #3 (permalink)
dieselkid73
yes, checked those and they are nearly fully charged...
Old 07-05-2008, 01:58 PM   eBay Motors   #4 (permalink)
deeretracks
The Sheriff
could be in the switch.
Craig
Old 07-05-2008, 02:15 PM   eBay Motors   #5 (permalink)
duramax-rob
duramax-rob's Avatar
I had the same problem on my 01 lb7. Had to disconnect both batteries at same time and have them load tested. Ended up being both batteries were bad and only 2 years old. Haven't had a problem since.
duramax-rob
duramax-rob
__________________________________________________ __________________________________________________ _
2001 Chevy 3500 CC Longbed Dually 4X4, 6.6 Duramax, Hypertec Programmer, Magna Flow 4" Exhaust, 5th wheel hitch, Jayco 32' 5th Wheel
Some's good, More's better, Too much is just enough!!!!
duramax-rob is offline   Reply With Quote
Old 07-05-2008, 08:02 PM   eBay Motors   #6 (permalink)
dieselkid73
are you refering to the ignition? or another switch? if it is ignition, can ireplace it myself or is that dealership work?
Old 07-05-2008, 08:11 PM   eBay Motors   #7 (permalink)
deeretracks
The Sheriff
In the ignition. You can replace it your self. Did you unhook the batts. and then load test them? They need to be done not hooked together.
Craig
Old 07-06-2008, 11:11 AM   eBay Motors   #8 (permalink)
dieselkid73
yes, checked both batteries unhooked, individually...meter reads between 12 to 14 volts...it doesnt do anything when i try to jump start it either...how mucht o replace the ignition switch and how?
Old 07-06-2008, 11:46 AM   eBay Motors   #9 (permalink)
dmax500
dmax500's Avatar
you need to check the ign. switch before you replace it. easy way to rule out an ign. switch is measure your bat voltage should be around 12.3v now put your pos lead of your voltmeter on your ign.1 fuse and your neg on a good ground have someone try to crank the engine voltage should be pretty close to bat voltage if ign. switch is bad or atleast the curcit will read low like 4-8v good indicator if ign. switch is bad
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. PPE pyro and boost gauges coming next month TTS Lift pump and filter and water seperator in the future
dmax500 is offline   Reply With Quote
Old 07-07-2008, 08:51 AM   eBay Motors   #10 (permalink)
gr8shot
gr8shot's Avatar
What about the NSBU switch on the tranny? I've read other threads about it causing no start conditions...
