I Put My Buddys Ppe Standard 160 Hp Eccel And I Was Coming Up A Hill And Got On It And Around 80mph It Down Shifted To Like 4300rpm It Has Done It Twice And Both Times It Has Thrown A Code Any Ideas Why??
5 to 4 downshift. Too much power to tranny at that Rpm. I had my Stock LMM do the same thing I was going up a hill and went from 5 to 4 around same RPM. It stalled and would not go over 2000 rpm. If you continue to run like that you should get a Transgo Jr
__________________ 06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
TransGo Jr does not help the 5 speed that much-- Helps the 6 speed trans much more. They make a TransGo where you replace some internal parts, but the trans will have to come out and be disassembled.
__________________ Chevy 04.5 LLY, 265s, shell, XDR, TransGo, deep pan, blocked, fingered, de-badged, PVC mod, 65 Gallon Aero tank, Pre-filter, tow mirrors, BU cam, gauges, GPS, Sirius
If you are going to play that hard with it, no matter what you use, you definitely want to upgrade the converter and the clutches in the tranny before you have to tow it home...
__________________ TRUCK ONE: '03 GMC Sierra 2500HD 4X4 Ext. Cab Short Bed LB7, K&N Intk AFE Fltr, 4in exhaust, Banks Six-gun w/ power PDA and Speed Loader, FASS Fuel System, 6-Spd Manual Tranny w/ Custom Ceramic Dual Disk Clutch By: South Bend, Pyro and Boost Gauges in the A-Pillar
Short answer is NO! These stock transmissions will usually only handle 90 extra hp. You better check your credit card balance because you are going to need it. You may squeeze a little more time if you are easy on the 4-5 shift.
