Old 08-27-2008, 12:06 PM   eBay Motors   #1 (permalink)
sleeper66
Code Help!
I have a 2006 GMC Duramax, LBZ. My poor truck is trowin codes like crazy, so far the codes that I have come up with are. PO401, POO3A, PO108, PO299, PO234. I clear them out with my Edge chip and they'll come right back once I drive it again. I was going to take the chip off and take into the dealer, what should I expect when they look at it? and can I drive it for another week?
sleeper66 is offline   Reply With Quote
Old 08-27-2008, 01:09 PM   eBay Motors   #2 (permalink)
bob213
bob213's Avatar
You need to fill out your signature so that people will know what mods you have done to your truck. Hard to diagnose anything without info.
003a-fuel vol. reg. cntrl. low
0108-map sensor
0299-T/S charger underboost
0234-overboost
p401- egr
I can't tell you what causes these but there are plenty of people on this site that can.
Post your mods and someone will help you.
2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Diablo Sport Predator/EGR Blocked
BD Exhaust Manifold
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" with
True CAI by "KillerBee" THANK YOU!!! Michael...
bob213 is offline   Reply With Quote
Old 08-27-2008, 06:13 PM   eBay Motors   #3 (permalink)
duramaxdr
Strange combination of codes. Clear the codes. Then disconnect the edge completly. See if the codes come back with the edge disconnected.
duramaxdr is offline   Reply With Quote
Old 08-27-2008, 09:40 PM   eBay Motors   #4 (permalink)
daddysLBZ
Your wife's in my profile
daddysLBZ's Avatar
Cool
Are you using theturbo timer feature?If you are,then you need to set the Edge to clear DTC's upon startup.The TT feature sets dtc's every time it's activated,because the truck thinks something is wrong when ignition is off and key is not removed...Make sure the Edge is set to clear DTC's upon startup....
2006 GMC 2500HD 4x4{cc,sb,SLE} 90/175hp tune,nocat/muff!Naked pic of wife hanging from the rear view.
Goodies waiting for installation!! LBZpowered!!
2002 GMC 1500 [2wd]5.3 power{98k}20 in wheels on!!!LOOK AT AVATAR<<<<
1987 Monte Carlo SS all orig!!89k.....
1978 Malibu [2 dr!!]too far in the $$$ to ever think of selling..[ZZ4 from GMPP coming in March!!]
HOT SHOT RIG:2002 GMC Yukon XL***312,674 miles***Hytech tuned,K&N cai[not my choice]...Runs like a whore in church...The left lane was meant to pass,move over or we'll run over your assss!!!P.H.inc. Hot shot 7080let he who touch dis sig die...
Old 08-28-2008, 07:33 AM   eBay Motors   #5 (permalink)
sleeper66
I was using the turbo timer, I shut it off this week to see if that was the problem. I dissconected the chip last weekend, I hooked it back up monday to pull the codes and that's what I found. The truck has a Afe stage 2 cold air intake and 4" exhaust, no cat.
Old 08-28-2008, 09:24 AM   eBay Motors   #6 (permalink)
gr8shot
gr8shot's Avatar
well the straight pipe can cause the egr code, thats fairly common, is your afe an oiled filter? Idk much about afe's, but if it is then that could cause the MAF code, the oil gets on the maf sensor and messes it up and it'll throw a code. Not sure about the others, but I'd bet that your edge is causing them. Clear the codes, and completley disconnect all the edge stuff. Then drive it for a while. You'll probably still get the egr, and maybe the maf code too, but I'd bet the other ones go away!! Bad edge... bad!!
Old 08-29-2008, 07:30 AM   eBay Motors   #7 (permalink)
sleeper66
Yes the filter is an oil filter, I installed it @ about 15,000 miles and haven't had any problem with it in the last 25,000 miles. I did disconect the chip last weekend and drove it all weekend just stock, it still set all the same codes. The only reason I put the chip back on was to read the codes.
Old 09-01-2008, 08:43 AM   eBay Motors   #8 (permalink)
cdimichele
Check the wiring harness on the 24 and 36 pin connectors they May be loose, there also is a service bulletin posted for the egr code OPLIN Research Database Remote Access
If that link does not work, look in the DIY Forum for instrucitons on that website and how to access it
Good luck,
-2006 LLY Banks Six Gun Bundle With Power PDA
cdimichele is offline   Reply With Quote
