Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods.
After Market Mods. Discuss what Mods are right for you.
Old 11-20-2008, 05:52 PM   eBay Motors   #1 (permalink)
duramaxchris06
duramaxchris06's Avatar
EGR blocker and fingerstick
Hey everybody. I received my block plate and figerstick today in the mail. im pretty confident on installing the block plate, but not so much on the fingestick. ive printed out instructions on the procedure, but after reviewing them i dont feel anymore confident about it than i did before. I was wondering if any of you have ever installed the fingerstick on an LBZ before. if so what is your advice on this procedure. Also if anyone has any input on making the block plate install go smoother, then im all ears and would love to hear your advice.
Thanks,
Chris
2006 Chevy Duramax LBZ 3500HD CC Dually LT3 4X4
4" turbo back exhaust, 5" pollished stainless steel tip,
Turbo Resonator plugged, FPRV Shim, & EGR Blocked
PPE Hot+2
Autometer Cobalt, boost and pyro
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
Michelin LTX A/S 265/75/R16, 2" spacers.
duramaxchris06 is offline   Reply With Quote
Old 11-20-2008, 06:57 PM   eBay Motors   #2 (permalink)
Big Smith
Big Smith's Avatar
Hey man, I don't know who you got them from , but if you go to Kennedy diesel.com they have a pictorial on how to install them....
2004 LLY
Amsoil from front to back
Mag Hytec on the tranny
Magnaflow turbo back
5000k Super Springs
K&N CAI
MKW with 35's
Hypertech III
Rancho suspension lift w/RS9000
EGR Blocked
Big Smith is offline   Reply With Quote
Old 11-20-2008, 07:46 PM   eBay Motors   #3 (permalink)
duramaxchris06
yeah thats where i got it from....but i was just wondering if anybody had any good input on it before i tackled the project
PPE Hot+2
2008 emblems
Old 11-20-2008, 09:51 PM   eBay Motors   #4 (permalink)
FH Leader
FH Leader's Avatar
I have installed three my self. All I can tell you is use oil on the bolts to get them off. after that try and pry the tube back from the cooler to knock it home. if you have problems John can answer all you questions.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
My iron is yellow
Id rather be dead then CUMMINS RED!
FH Leader is offline   Reply With Quote
Old 11-20-2008, 10:21 PM   eBay Motors   #5 (permalink)
bowhunternkbay
bowhunternkbay's Avatar
Yes. I installed the blocker plate and fingerstick on my LBZ.Got them from Kennedy diesel. Blocker plate was a pain, but I got it installed. Then the fingerstick went in. Instructions are good...check your wires carefully.My soldering job wasn't so hot though.I ended up having to use wire splices on two of the wires.They work pretty good.You can purchase them at any electronics store. But try the solder first,its themost reliable connection.
'06 2500 HD CC/SB
BullyDog TripleDog
AiRaid CAI
MBRP 4" Turboback
Goodyear Silent Armor LT 285/75R16
Blocked,Fingered,Rerouted,Sleeved and Plugged
www.DiscountTireDirect.com
bowhunternkbay is offline   Reply With Quote
Old 11-20-2008, 11:32 PM   eBay Motors   #6 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
I would install the block first and go a couple of days and see if you even need the fingerstick. You may not get a SES light. For the block plate i usually use a end wrench and a small hammer to tap the wrench with.
KYLE
2010 Camaro SS LS3 426 HP
Old 11-21-2008, 06:00 AM   eBay Motors   #7 (permalink)
duramaxchris06
im pretty sure im gonna need the fingerstick, ive been startin to get the p0401 code and SES light from the catless exhaust, usually seems to do it most after WOT or pulling loads.
PPE Hot+2
2008 emblems
Old 11-21-2008, 08:57 AM   eBay Motors   #8 (permalink)
BigRedChevy
Super Moderator
Yeah, that is when you are most likely to see the code.
KYLE
Old 11-25-2008, 02:48 PM   eBay Motors   #9 (permalink)
duramaxchris06
update: I installed my block plate earlier, and boy was that a pain in the neck. After getting the nuts loose i thought it would be easy from there...haha yeah right. Turned out that gettin the nuts loose was the easiest part. After a few cuss words and some beatin and bangin, the block plate finally went into place. Got everything tightened back up and checked for leaks...so far so good. Now my question is.......how likely is it for the nuts to loosten back up some after it has gotten good and warm? I didnt know if it would be a good idea to check them in a couple days, or just assume that it is still tight.
PPE Hot+2
2008 emblems
Old 11-25-2008, 04:07 PM   eBay Motors   #10 (permalink)
WylieD
WylieD's Avatar
Never hurts to double check
07 Chevy Duramax CC SB LBZ 5" Exhaust
AutoMeter Sport Comp II's Banks Ram Air Intake
BD Manifold EGR Blocker Quad Stealth 2 B&W Turnover
5% Tint All Around
Line-X Bed Liner
www.huskerdiesel.com
WylieD is offline   Reply With Quote
