Are you adding a amp etc.? Ya you can get a RCA converter that you connect to your speaker wires and it gets power from there. I got mine from Best buy for under $20
So, I think I'm going to get a stack..... Stacks are cool..... No Im just getting one..... Oh.. Well just don't put it on the gay side..... Wait what??
2006 Silverado 2500HD LBZ CC SB Escalade Handles, Front windows tinted to match the rear, painted bumpers, billet grille 4 Kicker 10in Subs in 2 custom box's, Autometer Ultra lite II Pyro and Boost gauges MBRP Turbo Back Stainless Exhaust (Straight piped), w/ stainless tip! PPE Hot+2 285/75/16 Nitto Terra Grapplers on Gear Alloy wheels ****Lost Kitty Reward if found!!**** 1999 Ford F-550 PowerStroke ''Wrecker'' **Jerrdan bed, S&B Intake
im with towmaster on that they sell them at bestbuy for around 20 bucks they will also install them for around 30 or 40 bucks in an hour. but i installed mine under the factory cup holders and tapped into the front speaker wires to get an RCA output, th
Right on,I tapped the wires there also!!Just when he wires the PAC adapter in,he needs to splice in AFTER the factory Bose amp up front,if not the amp will go into ''protect'' or blow fuses.......I can get a pic if he needs,but the best thing to do is get 2 PAC adapters and get a front and rear/left and right signal also using Y connectors.I originally used one off the rears signal.I later added another so I could fade the speakers from front to back without comprimising the signal to the aftermarket amp!Works pretty darn good also..BE SURE to get a shielded adapter and use shielded RCA's to eliminate noise from RF interference....
__________________ 06.LBZ GMC[SLE1] 4x4 .modded a touch!PPE hot+2!
.STAGE V Suncoast,Merchant 4x4,str8piped,285's,
1978 Malibu[2dr.]350ci crate/TH 350 with goods,3.23's 1987 Monte Carlo SS 92k original miles 2001 GMC ex-cab 5.3,tuned,20'Helios
