I Feel Like a Dog Stuck between Two Fire Dydrients,
06-LBZ What is the best Single turbocharger up-grade Really do not want to Deal with Twins, & then Dual CP3,s And then Rods pistons ETC.
What is the best Single that spools the fastest an will pump out 600--650HP for a great all around daily Driver And help lower egts a little No- Towing- Pulling .
I may go to local drags a couple times nothing major.
Cheetah--- BD--- HTT---- ATS ??? or any others i may have forgot
if you go anything above 30psi your going to need head studs a very big expensive job. i'm an lb7 fan with the straight rate turbo but yours has the variable vane. I belive ats makes a variable turbo but is probabbly bukko bucks. personally would use your money and buy a built tranny and buy a good programmer ppe, efi live etc. besides anything over about 500 rwhp and your going to have to build up your bottom end to handle the extra power far as your egts put a 5" turbo back exhaust with a cat delete will run consederably cooler.
2002 Crewcab short box 3/4 tonHD lb7 W/Allison stock, ATS DIESEL E-POWER programmer, 5" Jeg's Subway tunnel exhaust straight piped, cranked up torsion bars. PPE pyro and boost gauges havnt installed yet. air dog 150 lift pump in future installed a fass 150/150 and was impressed with results
you can go 45-50 lbs. boost on stock bolts. you cannot go above 575hp for very long on stock motor. I would go ppe gt 4088 or industrial injection silver 62 for single cp3 and no internal mods.
__________________ 02 D/A C/C
Lloyd Customs twins, NADP tranny
Bob Olson tuning
10.96 @ 128 on fuel
The cheetah would be a good choice, but only with efi live for tuning. Since it is a VVT you have to have EFI to control boost levels. If you want to run PPE you could look at the ATS Auroa 4000 or the Garret GT40.
__________________ KYLE
2010 Camaro SS LS3 426 HP
We do not have a Variable turbo. The MST (which is what I am prototyping) is the closest thing to a Variable turbo we have however it is still being tested and is not available. Turbo size all depends on what the truck is used for and what your HP goal is.
__________________ 2003 GMC Sierra LB7 (SHE LIVES AGAIN) ATS *EXTREME* Transmission, ATS Billet Flexplate, Cryo-treated bottom end (Motor built by me), +90hp Injector Nozzles, ATS Twin CP3's, ATS Aurora 3000/5000 Compounds (Built by me), ATS Headstuds, Low Compression Pistons, 5" Single Stack, EFI Live (Tuned by me), ATS Billet Tie Rod Sleeves, FASS 150/150 www.atsdiesel.com 866-230-4092
Well on the LBZ, you may be looking at pistons if you are planning on getting to the 600-650. They are significantly weaker in the LBZ than in the LLY and the LB7. I have had A LOT of customers with LBZs come in here with cracked pistons around that power range.
Fact of the matter is that if you are looking for a fuel only truck that makes 650hp, don't expect the same spool time as the factory turbo. It takes a larger turbo to support that power.
With the gt4094 I saw 40 psi and a spike of 44 psi, at only 32 psi I made 567 rwhp and 1030 tq and ran 12.54 @ 110 at 7060lb.
__________________ Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live,Gt4202R,PPE Twin Cp3's,PPE lift pump,Dipper 30% injectors, updated BigDipper Trans 1055 converter and ATS Copilot.
Alot Of thanks To Joe & Dan at PPE,George aka BigDipper,Guy at Socal Diesel.
All Work Done By:www.creaturesofthenightperformance.com 11.53 @ 116.92 1.66 60's RIP LBZ 6/1/08@5:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM http://www.dieselbuilder.com/Media/PublicationsArt icle/DB_0808_SleeperSilveradoBuild_2.pdf
i would run the cheetaha on the lbz go to you tube and check brayden fleece out on there he runs the cheetaha and sells them
__________________ 2007 Chevy Classic LBZ, AFE stage 2, Turbo back 5 Inch Magnaflow, EGR block off plate, PPE lift pump, PPE pick up tube out of the tank. Got the efi live tuning from fleece performance on my truck now it is a great tune getting the transgo jr. kit for now
