Is it possible to have my truck converted to a dually to increase my tow rating? Is there anything else that would need to be done to increase my tow rating other than adding dual wheels and a 1 ton rated axle? If so, would you recommend it?
'06 LBZ
Duramax Allison Transmission EFILive (stock tuned for now), MBRP duals
How much more weight do you want to be able to tow? You could always just add a leaf or use airbags. If you are wanting the extra stability of a dually then yes you can covert. Chevy/GMC dual wheel conversion kits with wheels
__________________ KYLE
2010 Camaro SS LS3 426 HP
just bolting on 2 more wheels,bigger springs and fenders doesnt change the rating of the rear end i might be wrong but a dually has a bigger heaver axle than a 3/4ton or a 1 ton
__________________ 2002 CREWCAB DUELLY 4X4 6SP MANUAL WITH SUPERCHIPS,SBC single mass/disk flywheel,ppe boost valve, K&N , MUFFLER DELEATE OPP. AND CROME FLAME GRILL
Ya Id say if you want a bigger tow rating you add air bags to help out. Id say the only real difference between a dually and a SRA is there are more leafs in the rear. Air bags will help stifin the ride. The other downfall is. I think EXT cab ac CC cab trucks are rated to tow a little more because they weigh more.
All in all I dont think it will be worth it to try and make a dually
^^x2 on that....there is a couple trucks around here that the owners have done a dually conversion to their 2500, it doesent look the same as a factory dually....actually it sticks out like a sore thumb..ive only ever seen this done on fords though, so i dont know what it would look like on a chevy, but my guess is it probebly wouldnt look any better....ur best bet is to get either helper springs or airbags, and that will be all the added support u should need
__________________ 2006 Chevy Duramax LBZ 3500HD CC Dually LT3 4X4
4" turbo back exhaust, 5" pollished stainless steel tip,
Turbo Resonator plugged, FPRV Shim, & EGR Blocked
PPE Hot+2
Autometer Cobalt, boost and pyro
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
Michelin LTX A/S 265/75/R16, 2" spacers.
I saw a guy driving around here with a dually conversion on an old 60s Chevy, and it actually looked pretty good. If I was going to do one, I would probably put on a flatbed or a utility bed designed for a dually, not a stock dually bed off a 1 ton...of course that's partly because I personally have a short bed. And a dually conversion may look odd on a short bed.
__________________ 2004 K2500HD, LB7, Ext. cab, short box, 285/75/R16, stock (as far as I know)
all of the trucks that ive ever seen with the conversion, the fendor's are evidently part of the kit, idk, but anyway they all looked real goofy lookin
PPE Hot+2
2008 emblems
I was only asking because in the future I expect to purchase a 5th wheel and tow a boat behind it. My truck is only a 3/4 ton right now. I'm thinking a 8000-10000 lb 5th wheel with a 4000 lb boat behind it. Does this sound realistic?
'06 LBZ
