Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods.
After Market Mods. Discuss what Mods are right for you.
Old 07-29-2008, 01:56 PM   eBay Motors   #1 (permalink)
catman_05
Points: 618, Level: 9
Points: 618, Level: 9 Points: 618, Level: 9 Points: 618, Level: 9
Activity: 0%
Exclamation Tie Rod Sleeves And Allighnment Issues
I Installed My Ppe Tie Rod Sleeves The Other Day And When I Put The Ends Back On The Passenger Side Was Tight Gettn It On But I Got It There With The Same Turns As When Ut Came Off. I Went Today To Have It Allighned And They Couldnt Adjust The Toe Inn Cause The Nut And Sleeve Were In There Tight!! So They Took The Nuts Off Both Sides And Tightned The Sleeve Against The Tie Rod End. And Allighned It Out Perfectly Will It Hurt Anything Having The Nut Gone And Just The Sleeve Against The Tie Rod End.
2004 CHEVY LB7 2500HD, CREW CAB, SB. EDGE JUICE WITH ATTITUDE, AFE STG. 2, PPE BOOST VALVE, FASS 95, 4 INCH SILVERLINE, PPE SLEEVES, TOYO MT`S
catman_05 is offline   Reply With Quote
Old 07-29-2008, 02:35 PM   eBay Motors   #2 (permalink)
aggar
Points: 3,404, Level: 24
Points: 3,404, Level: 24 Points: 3,404, Level: 24 Points: 3,404, Level: 24
Activity: 24%
Activity: 24% Activity: 24% Activity: 24%
aggar's Avatar
I don't know if I'd leave the nuts off. they're on there for a purpose. They should know that. Did you clean the tierods off before installing to get off excess dirt and grease? I had to on one of mine. Mine went on just fine but they weren't ppe sleeves. You may have to take them back off and clean to make sure they go on far enough to get the nuts on and you may have to get a wire brush and clean the threads up a little bit.
2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058(Fleece Performance), SC Case Brace, 68mm Cheetah, EFI Live, HP 150 lift pump, Auto meter gauges and pod, EGR Blocker and FRPV shim kit,
2001 Ext Cab LB 2500hd Lb7. BoneStock! ( For Now)
Old 07-29-2008, 02:53 PM   eBay Motors   #3 (permalink)
catman_05
Activity: 0%
No They Were Clean, I Had The Chevy Dealer Allighn It. They Said That They Tightened The Sleeve Against The Tie Rod End.
Old 07-29-2008, 03:01 PM   eBay Motors   #4 (permalink)
05_LLY
Gear Jammer...
Points: 8,160, Level: 38
Points: 8,160, Level: 38 Points: 8,160, Level: 38 Points: 8,160, Level: 38
Activity: 19%
Activity: 19% Activity: 19% Activity: 19%
05_LLY's Avatar
In some sense the sleeve will serve the same as the nut, i would want it there but i dont think it will cause you any problem with out it other than the sleev covering less of the tie rod! Ive run ito problems with them threading tight on trucks that have been under coated and not getting it all off the rod befor installing the sleeve!
Caleb
05 D/ZF Reg. Cab
Under the knife to attach a second turbo
04.5 D/A CC/SB- SCIV w ATS 5star converter,Mike L cooler
Waiting install of GT4094R
Old 07-29-2008, 04:02 PM   eBay Motors   #5 (permalink)
GmcLbz
Points: 1,340, Level: 14
Points: 1,340, Level: 14 Points: 1,340, Level: 14 Points: 1,340, Level: 14
Activity: 5%
Activity: 5% Activity: 5% Activity: 5%
GmcLbz's Avatar
I have been running sleeves with no nuts for several months now with absolutely no issues. My sleeves are longer than any on the market though.
07' GMC CC/SB Diamond Eye direct downpipe, 4" Mbrp DP back, Airaid CAI w/Amsoil dry filter and prefilter, fingered and blocked, Transgo Jr, UDP tie rod sleeves, Cognito braces, H2's w/285 BFG's, Airdog 150, EFI Live, Autometer phantom boost and pyro
GmcLbz is offline   Reply With Quote
Old 07-29-2008, 04:25 PM   eBay Motors   #6 (permalink)
IdahoRob
Points: 4,853, Level: 29
Points: 4,853, Level: 29 Points: 4,853, Level: 29 Points: 4,853, Level: 29
Activity: 14%
Activity: 14% Activity: 14% Activity: 14%
IdahoRob's Avatar
The sleeves can take the place of the lock nuts.
FOR SALE:2007 LBZ CCSB 4x4,EFI(tuned by me), ATP Transmission
11.70 @ 115mph on #2 http://s173.photobucket.com/albums/w...Coddens3mb.flv
PPE, EFI Live, Suncoast Dealer
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
Old 07-29-2008, 04:35 PM   eBay Motors   #7 (permalink)
catman_05
Activity: 0%
I Figured They Would I Just Wanted To Be Sure!
Old 07-29-2008, 11:25 PM   eBay Motors   #8 (permalink)
Tow Master
Idiot lookin at the computer
Points: 12,414, Level: 48
Points: 12,414, Level: 48 Points: 12,414, Level: 48 Points: 12,414, Level: 48
Activity: 90%
Activity: 90% Activity: 90% Activity: 90%
Tow Master's Avatar
Ya I agree with everyone. The sleeves I got didnt come with nuts. As long as the sleeves you got are threaded then they should be able to tighten against the tie rod end and not need the nut.
Jason
Old 07-30-2008, 05:46 AM   eBay Motors   #9 (permalink)
TYREBOYZ_DEMAXIN
Experienced Post Whore
Points: 10,982, Level: 45
Points: 10,982, Level: 45 Points: 10,982, Level: 45 Points: 10,982, Level: 45
Activity: 100%
TYREBOYZ_DEMAXIN's Avatar
i took the nut of my sleeves and used the sleeve as the lock nut..
James
I HAVE THE MEDAL
