Will the size (Diameter & Length) of an exhaust tip Create a louder or quieter sound? Or perhaps a deeper or softer sound? Or are they just for appearance? Please explain...
__________________ JC
2003 GMC 2500 Crew Cab Short Box, Lifted, Bagged, 35" BFGs, LB7 Edge Juice With Attitude, MBRB 4" Turbo Back Exhaust, S&B Cold Air Intake
__________________ 2008 silverado dmax LTZ, aFe stage 2,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,SCIV on its way
This is my experience--I have a 4" inlet to 6" outlet 18" long and it has a different tone (especially at idle and reg driving) than a friends with the same 4" exhaust and a 4" to 5" 8" long. Same trucks too, 04.5 LLY and 05LLY
--2004.5 GMC 2500HD 4x4-- Hog 4" SS Turboback w/6" SS Polished Tip, AFE Stage II Intake, EGR Block and Finger Stick, Resonator Plugged, PPE Fuel Release Valve Shim Kit, PPE Tie Rod Sleeves, TTS Dual Lift Pumps, Quadzilla Stealth2 Pioneer In Dash DVD, CD, MP3, and NAV, Boston S60 Internals all around, 10" JL W3 Sub, JL 500/1 Amp, Custom Under-Seat Non-Ported Box, Triple Pillar w/Autometer Sport Comp II (EGT, Oil Temp, BOOST), 15% Tint Up Front 285's BFG A/T, ArmorThane Spray-in Bedliner, Extang R/T Tonneau Cover, Black Step Tubes, Recon LED Big Rig Kit, Red Varad Expansion LEDs, Recon LED Smoked Cab Lights, Black LED Third Brake Light, LED Line of Fire Under Tailgate, Cowl Hood w/Duramax Emblem:cool
He is exactly right. Take a system with no tip then add a 5 or 6 inch tip and it sounds a good bit different
It does sound a little different with a big tip but nothing like a gasser with a set of echo chambers. The Duramax is not that loud with or without it.
__________________ 06 2500 CREW CAB 4X4 LBZ LOONNGGGGG BED 4" DIAMOND EYE EXHAUST, DIABLO @ 120,S&B COLD AIR INTAKE, RESONATOR PLUGGED AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....Its Coming.....EFI LIVE.....
WORK RIG
my 8 inch is suuper deep..way deeper than a 5 inch turbo back
__________________ hey my name is coady! im 18 years old, i drive an 04 blacked out duramax with a 6 inch lift 35 inch a/ts, 20 inch kmc rockstars, and 33x15.50 super swampers, with 16.5x12's. Quadzilla Stealth 2 at 135HP, Train horns, 5/8 lines,limo tint all the way around, 35% tint on windshield, 8 inch brow. 7 inch black stack. afe stage 2 intake. painted grill and bumpers.halo projector black headlights with green L.E.D's,10000k HID's. blacked tail lights. JVS EXAD deck 3 1/2 inch screen. two 15 inch subs,power capasitor, 2000 watt amp. line-x bed liner. http://www.discounttiredirect.com
i have the stock exhaust just straight piped and then i have a 18 inch long by 6 inch tip. I like the sound of it alot. it has a good deep sound in all RPM ranges.
