Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods.
After Market Mods. Discuss what Mods are right for you.
Old 09-18-2008, 08:48 PM   eBay Motors   #1 (permalink)
mattfromwy
mattfromwy's Avatar
Big Tires And Preformance
Are there any of you out there running big tires and still running fast 1/4 mile times or 0-60 I can never seem to keep traction. what have you guys done to overcome the tires.
2004 GMC 2500HD LLY HOMETOWN BILLINGS,MT HOME OF THE DIRTYMAX 9.46@149 G&J DIESEL
Edge Juice with Attitude
Crank it up Tierod sleeves
Turbo Resinator Plugged
4" Turbo Back dead kitty No muff (MBRP) 6? Miter Cut Black Stacks
6'' Rancho Lift
17" Procomp Rims 35? Cooper STT
Tinted Windows
Spray In Bedliner, also on the bottom 6'' of truck
Traxx By Kat Radar Detector/Laser Scrambler & Peformance Meter
Custom Built Grill Guard; Bolinger Inc;
mattfromwy is offline   Reply With Quote
Old 09-18-2008, 08:54 PM   eBay Motors   #2 (permalink)
countryredneck
STOCK SUCKS
countryredneck's Avatar
soft tires, 4 wheel drive
'06 duramax, 8" fabtech lift, dirt logic shocks, 24" akuza rims, 38" kuhmos (summer) 20" moto metals, 37" nitto mud grapplers (winter), airaid intake, EFI Live, TTS lift pumps, FPRV shim, stage 4 trans by PATC, upgraded transfer case by merchant automotive, BD manifold, EGR blocker plate, straight piped stacks - waiting to go in---> water/meth injection
'01 chevy ZR2 s-10, chromed out shaved tail gate handle, dual exhaust threw roll plan, ram air hood.
'87 chevy 1 ton dually, welding rig
'86 chevy 1/2, project truck
countryredneck is offline   Reply With Quote
Old 09-18-2008, 09:00 PM   eBay Motors   #3 (permalink)
mattfromwy
mattfromwy's Avatar
What times are you seeing
6'' Rancho Lift
Tinted Windows
Old 09-18-2008, 09:02 PM   eBay Motors   #4 (permalink)
countryredneck
STOCK SUCKS
not a clue at this point.
Old 09-18-2008, 09:07 PM   eBay Motors   #5 (permalink)
timespentsearching
timespentsearching's Avatar
this really is backwareds. it should be harder to spin them. take more power to keep spin more weight at same RPM's. smaller tires spin easier. the hardness of the tire and tire psi are huge though. for more traction let out some air. also 4 wheel drive
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 09-18-2008, 09:12 PM   eBay Motors   #6 (permalink)
countryredneck
STOCK SUCKS
only thing i can think of is less pounds per square inch on the ground, with my summer tires on i had traction issues in 2 wheel
Old 09-18-2008, 09:15 PM   eBay Motors   #7 (permalink)
mattfromwy
mattfromwy's Avatar
I was just contributing it to the fact their is less weight per square in on the ground. Also how destrustive is 4 wheel drive at 60 on pavement.
6'' Rancho Lift
Tinted Windows
Old 09-18-2008, 09:17 PM   eBay Motors   #8 (permalink)
countryredneck
STOCK SUCKS
well i'd never jus drive around in it, but for some tration racing it cant be that bad, racing is hard on a truck to begin with, so whats a little more?
Old 09-18-2008, 09:18 PM   eBay Motors   #9 (permalink)
timespentsearching
yes to some extent this point is true. with almost no weight in the back in 2 wheel you can spin but jsut think aobut race cars. they add wide and bigger tires to increase traction and reduce wheel spin.
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 09-18-2008, 09:34 PM   eBay Motors   #10 (permalink)
countryredneck
STOCK SUCKS
true, but they have to get them smokin hot
