06 lbz Mods? - Chevy and GMC Duramax Diesel Forum
post #1 of 15 (permalink) Old 12-04-2011, 08:08 PM Thread Starter
06 lbz Mods?
I've got an 06 four door silverado with the LBZ Alison 6-speed combo. Looking to get some more power and a little better mpg. I've been told so many different things now (tunner, exhaust, intake, egr delete, ect) I know all these things will help but which product is the best? which gives you the most for your buck? I use this truck at both my daily driver and for pulling my tandem trailers from jobsite to jobsite. I dont ever plan on racing it but who doesn't like more power!!! any input would be great.
Thanks, Joe
ebert04joe is offline
post #2 of 15 (permalink) Old 12-04-2011, 08:12 PM
kylez's Avatar
Efi live, turboback exhaust(brand doesn't matter), egr blocker plate, transgo jr. shift kt, and pcv re-route. Leave intake stock
2006 LBZ GMC CCSB 4x4 white
17" XD addicts, 285/70/17, RC Sleeves, Air Lift Bags, Bilstein 5100's, PPE braces, Bakflip tonneau
AFE intake, ProFab DP, MBRP turboback, Insight CTS w/egt, DSP5 from ATP
Transgo JR, EGR blocked, PCV re-routed, M/A pump rub, DDM 5k low/hi & 3k fogs
kylez is offline
post #3 of 15 (permalink) Old 12-04-2011, 08:19 PM Thread Starter
Whith the EFI live, you create your own map corect? I've done alot of that with sleds and wheelers but never a car. I would imagine the best way to do it is copy somones map, or take it to a dyno? sry for all the questions just new to this stuff.
Thanks Joe
post #4 of 15 (permalink) Old 12-04-2011, 08:26 PM
kylez's Avatar
There are many reputable tuners that will make a tune for you. No need to do it yourself.
kylez is offline
post #5 of 15 (permalink) Old 12-04-2011, 08:27 PM
ATS Diesel Performance
lb7blksmk's Avatar
Send a message via Yahoo to lb7blksmk
Look into the edge cs and cts. Or efi, we offer tunes for efi as well. A tb exhaust will be a good investment as well. With just that you should be able to reach 18 to 20 mpg. Depending on how heavy of a foot you have.
-David
David Spidle
03 LB7Auroura 5000 W/ Manifolds & Up-pipes, Synapse 50mm Gate, 40% Over Injectors, Alligator Stg5 Trans, EFI Live
lb7blksmk is offline
post #6 of 15 (permalink) Old 12-04-2011, 08:28 PM
usafduramax's Avatar
efi live, full exhaust, egr delete/block, pcv re route, and if you get frisky air dog 2 lift pump
usafduramax is offline
post #7 of 15 (permalink) Old 12-04-2011, 10:00 PM
x2 very good choices.
DieselX-Darryl is offline
post #8 of 15 (permalink) Old 12-10-2011, 08:59 AM
Just wondering why most suggest to leave the intake alone?
Is it worthwhile to change the filter in the stock airbox?
How about the grid heater - leave it or remove it?
Just new to me: 2006 Chev Crew LT, LBZ. Still stock. Feel free to let me know what the best mods are. Bang for the buck!!!
nolagtime is offline
post #9 of 15 (permalink) Old 12-10-2011, 09:09 AM
Coffee addict
ty_LBZ's Avatar
K&N and other oiled air filters screw with the mass air flow (MAF) sensor, stock air intake is good up to 500 HP. Id leave the grid heater, easier on the DMAX in cold weather.
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa muffler. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts. Curt class 5 hitch.
10/30/14- cracked piston
03/14/15-Back from the dead
ty_LBZ is offline
post #10 of 15 (permalink) Old 12-10-2011, 09:15 AM
chevy71pickupman's Avatar
Like everyone else says EFI and exhaust to start with. I am running Idaho rob tunes and got 18mpg with winter fuel.
Adam
BIG THANKS TO ROB CODDENS AND DUSTIN GULLETT AT ATPTRUCKS FOR ALL THERE HELP
WWW.ATPTRUCKS.COM
www.alligatorperformance.com
DMAXSTORE.COM
chevy71pickupman is offline
