how can i get better mileage? - Chevy and GMC Duramax Diesel Forum
post #1 of 52 (permalink) Old 12-26-2011, 12:38 PM Thread Starter
this is my first post so sorry if it is in the wrong spot or something is not right. so i have been looking online about tuners and they say they can give like 100 hp boost. i was talking to my buddies and they say you can set certain rpms for the gears too. that is good but i would like to purchase one if they boost MPG. so what tuners would you recommend. or what has worked for you? also would buying aftermarket intakes, filters, electric fans, exhaust or anything else that i'm missing help too? Thanks!!
07_6.6_ltz is offline
post #2 of 52 (permalink) Old 12-26-2011, 12:43 PM
DieselLuver's Avatar
The best tuner you can get is efi live. Search that up in the forums. Aftermarket intakes arnt that important unless your making 500hp+. You can get a 4" straight pipe exhaust and dpf delete to help.
2007.5 Silverado 2500HD CCSB LTZ LMM
- 6" Fabtech - 35" Procomps - 17" Xd Spy's - Efi live by DDP - MBRP 5" straight pipe - 3" Downpipe - PCV reroute - DDM Hid's
2011 Sierra 2500HD CCSB LML (Buisness vehicle) - 4" Fabtec w/ DirtLogics, 35" micky Thompsons, 20" fuel boost rims - color matched cut out style
DieselLuver is offline
post #3 of 52 (permalink) Old 01-02-2012, 04:34 PM
LS1TENNESSEE's Avatar
Hey i am new to the diesel scene and i have alot of questions but the main one is how can i get better mileage. i have 2006 ext. cab 4x4 duramax with 8 inch fabtech lift, 20 inch wheels with 37in. toyo open country tires, ppe programmer, mbrp exhaust, air raid intake and i keep my fuel filters changed everytime i change oil. I have calculated my mileage several times and the best i have gotten is 12.3 it is literally killing me. any help would be greatly appreciated. thanks
2006 EXT. CAB SHORT BED 4X4 DURAMAX, 8 INCH FABTECH LIFT, 20IN WHEELS W/ 37 INCH TOYO TIRES. MBRP EXHAUST, AIR RAID INTAKE, PPE PROGRAMMER
LS1TENNESSEE is offline
post #4 of 52 (permalink) Old 01-02-2012, 04:42 PM
RedMax316's Avatar
Get rid of lift and big tires lol
Sent from my DROIDX
Donnie 08 GMC Sierra 2500HD cc/sb Debadged 5in straight pipe MPI twins 60% Big Dipper nozzels EFI live tuned by Rob at ATP PVC reroute Bank 3in IC pipe PPE Race Vavle & Ported Fuel Rail Fitting CP3 High Flow Feed Line Kit Raptor 150 lift pump built trans by Big Dipper EGR delete with 3in Y-bridge BD manifold Tinted tail lights & 3rd brake light Recon smoked LED cab lights LED tailgate bar Big Rig amber running lights 8K hids lows & driving Fuel Hostage rims Nitto 420's 305/50/20 3in drop shackles traction bars PPE straight centerlink Rareparts tierods Rancho steering stablizer and shocks line X Bed liner billet fuel door
http://www.atptrucks.com/
RedMax316 is offline
post #5 of 52 (permalink) Old 01-02-2012, 04:46 PM
BUBBA3M's Avatar
Welcome to the DF!! EFI Live and an exhaust will help you.
2013 LML, 6 spd Ally, CC/SB, Bone Stock
2015 Copper Canyon 33ft 5th wheel
BUBBA3M is offline
post #6 of 52 (permalink) Old 01-02-2012, 04:49 PM
joshmundy's Avatar
lift and tires will kill mpg. also if you have the lly motor, not the lbz (i think 2006 is lly but im not 100% on that) you might want to upgrade the mouthpiece to the lbz. Its relatively cheap, helps slightly with mpg but mostly just helps it breath better = lower egt
2008 Chevy 2500HD LTZ CC/SB LMM
NorCalTruck Stage 5 Cognito Leveling Kit - Cognito UCA, Fox Resi Shocks, Rare Parts HD Tie Rods, Cognito HD Swaybar Endlinks and HD pitman and idler arms.
BMF M80 death metal wheels 17x9 Nitto TeraGrappler 285/70-17
EFI LIVE with locking dsp5 switch tuned by Kory Willis
Edge CTS Insight with pyrometer, MBRP SS Turbo Back 4" exhaust no muffler w/ 5" tip, EGR Block Plate
Transgo Jr, PCV Reroute, Resonator Plugged
joshmundy is offline
post #7 of 52 (permalink) Old 01-02-2012, 05:19 PM
Sent from my DROIDX
X2
Jason
2005 Chevy 2500HD LLY CCSB
EFI Live DSP5 by Idaho Rob, Pillar Mount CTS
AFE MP, MBRP 4" Straight Pipe, EGR Delete
Magnaflow DP, LB7 Up Pipe, ARP Head Studs
PCV Reroute, Resonator Block, Shimmed/Ported
Donaldson Filters, Bars Cranked, Debadged
Bilstein 5100's, Rancho 5000 Stabilizer
Gooseneck Hitch, 285's
Sold: 2003 Silverado SS 6.0L AWD
Jkam0365 is offline
post #8 of 52 (permalink) Old 01-02-2012, 07:41 PM
Yeah i understand that the lift and tires are hurting it lol but surely to god there is more mpg in this truck, i mean 12.3 is awful. and i know that it doesnt hurt them that bad cause i have talked to several people with my setup that gets way better than me. i keep seeing people with the egr delete, does my truck need that or is it just the lbz motors cause mine is the lly. and i have the mbrp exhaust but it does have a muffler, so should i straight pipe it. sorry for all the questions but if i dont figure something out soon i am gonna go trade it in. thanks
post #9 of 52 (permalink) Old 01-02-2012, 07:45 PM
Since it's the LLY, have you upgraded your mouthpiece and blocked the egr?
Jason
Jkam0365 is offline
post #10 of 52 (permalink) Old 01-02-2012, 07:57 PM
smokinblack's Avatar
06 LLY and LBZ are basically the same,only difference if i recall is factory tuning,Its basically an LBZ detuned.
2010 CCSB LMM. Built trans, Airdog 165, sleeved,braced,EFI, Isspro gauges, edge cts, mag hytec diff cover
2007.5 LMM-6" Zone Lift,20x10 KMC HOSS rims,35/12.5/20 Mickey Thompson Baja ATZs,4" turbo back to black 6" stack,EFI Tuned by Dans Diesel Performance,Airdog 165, Edge Insight CTS,Mag hytec diff cover,Longhorn Fab Shop Traction Bars,N-FABS,Fabtech tie rods,braced,All black everything [B]
SOLD
smokinblack is offline
