Aftermarket Downpipe LB7 - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 08-14-2012, 11:10 AM Thread Starter
You didn't build that...
Duramaxn's Avatar
I have been reading up on how to install an aftermarket downpipe on an LB7. Sounds like one of the biggest pains in the rear, so naturally I bought one and am hoping to get it into the shop this weekend.
Ill let you know how the install goes, as well as the performance gains/sound.
Sorry to bugger up the results about the downpipe, but I will be going from stock exhaust and downpipe to MBRP downpipe and 5" straight pipe.
Things I picked up on this forum: Remove the heat-shield, Use a torch and heat the downpipe bolts to break the suckers loose, be patient. Did I miss anything?
Cheers
2002 Chevy 2500HD ECSB 4x4
4" Lift
315 x R16 Toyo MTs on Ultra Wheels
ISSPRO Boost/Pyro
MBRP 5" Straight Pipe with 3" DP
68k miles
EFI by Rob Coddens
Duramaxn is offline
post #2 of 8 (permalink) Old 08-14-2012, 11:13 AM
Thebiggids's Avatar
Dont catch your firewall insulation on fire!!! Ask me how that goes lol make sure you have a fire extinguisher close by ready to go! Goodluck, it sucks...
GideonHeyyaa
01 LB7 EC/SB Ally 4x4
DD: 1990 4runner completely stock 4x4 3.slow
2007 Yukon Denali - Hers
Big Thanks To Adrenaline Truck Performance, Alligator Diesel PerformanceSocal Diesel and Lincoln Diesel Specialties
Thebiggids is offline
post #3 of 8 (permalink) Old 08-14-2012, 11:14 AM
Hang it!...Fire!
TDIpowered's Avatar
pb blaster!!
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
post #4 of 8 (permalink) Old 08-17-2012, 10:34 AM Thread Starter
Duramaxn's Avatar
Update:
Ok, So last night I installed my MBRP 5" straight pipe with 4" front pipe. It sounds amazing!!! I still have the stock downpipe on. I went from stock exhaust, stock muffler, and no cat to this 5" system.
EGT about 150* - 200* degree lower on highway, idles about 50* lower.
Gained 2 LBS of boost. Went from about 19 max boost to about 21 max boost.
Spools up way faster and sounds like a jet engine at WOT haha
Gained quite a bit quicker throttle response in the low end, such as starting from a stop. just barely noticed it in the top end, but it was there.
Noise is incredible! Not loud enough to get you pulled over, but still very deep, throaty, and just plain MEAN!
Best part: Almost every bit as quiet inside the cab (as long as you have the windows rolled up) You notice it, but the engine noise is still louder than the drone
Tonight will be the DPs turn!
4" Lift
ISSPRO Boost/Pyro
68k miles
EFI by Rob Coddens
Duramaxn is offline
post #5 of 8 (permalink) Old 08-17-2012, 10:38 AM
sparepartsracing's Avatar
I didnt use any head to get mine off. Just made some specials tools and they came out. The hardest part was getting to them perfectly
Truck: 2004 eclb lb7
Motor: lbz rods, delipped lb7 pistons, arp main and head studs, federal heads, lml manifold, ppe dampner.
Trans: Bt diesel works built trans, ml converter, Bt tapshift
Fuel: 60% injectors, lbz cp3
Air: s476 over stocker
Exhaust: 5" downpipe, 5" exhaust factory exit no tip. Bd manifold. Everything heat wrapped.
Wheels: 20x10 fuel hostages, 35" nitto trail grapplers
Bumpers: roll pan, big Chevy hitch
sparepartsracing is offline
post #6 of 8 (permalink) Old 08-17-2012, 10:42 AM Thread Starter
Duramaxn's Avatar
OAh, Also! I have a question for all you MBRP users.
How on earth do you stop the tiny exhaust leaks around the connecting points that connect against the flow of the exhaust...that's just a plain flawed design anyhow...
I'm getting a bit of flow out of the cuts which are placed in the flanges, even though the pipe is shoved in ALL the way, and clamped down. I don't really want to weld it in case I need to take it off for some reason.
BTW: my spare tire fits fine. no problems.
4" Lift
ISSPRO Boost/Pyro
68k miles
EFI by Rob Coddens
Duramaxn is offline
post #7 of 8 (permalink) Old 08-17-2012, 11:36 PM Thread Starter
Duramaxn's Avatar
Alright, I installed my MBRP Downpipe tonight with the help of my brother-in-law. Just got done. WOW was it a pain in the rear!! Better plan on having at least a half of a day, from pulling into the shop until the test drive.
Honestly, I am not sure what I think about it. It increases the drone of the 5" strait pipe considerably. Man is my exhaust is loud now. I noticed quite a bit less back pressure. The engine does not act as my brake very well anymore.
I can tell that the upgrade gave it a deeper sound, and the turbo is a bit more noticeable. Boost stayed the same as it was with the stock DP and 5" strait pipe, maybe quicker spool-up..I can't really tell. I feel as though it has more get up and go however.
Make sure to say a prayer before you try to take the stock DP off because they are hard to get to and require patience. Not impossible by any means. Just take your time and be prepared to spend about 20 minutes per bolt trying to figure out how to get enough leverage to break it loose.
I wrapped my DP with heat wrap just in case.
All in all, it was a simple installation, just time consuming.
4" Lift
ISSPRO Boost/Pyro
68k miles
EFI by Rob Coddens
Duramaxn is offline
post #8 of 8 (permalink) Old 08-18-2012, 05:29 PM
Awesome Thread, definitely convinced me to go the MBRP Route.
ThePro is offline
