CAT filter question..... - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 03:19 PM   eBay Motors  #11 (permalink)
I use the cat filter and let my airdog collect the water.
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids
tmm403 is offline   Reply With Quote
Old 11-19-2012, 03:41 PM   eBay Motors  #12 (permalink)
cat 1r-0750 is a 2 micron filter and water seperator. but a Fleetguard fs1212 is a better w/s, but it has to be on vacumm to work right meaning not after a lift pump
2001 RC/lb lb7 zf6 EFI 120hp tune.
5" exhaust, Custom Boost Valve
Holly Lift pump, Dual Filtration system,Custom Traction Bars
16" method race wheels w/ BFG allterrains
Blad tires and clutch slippage thanks to sheid Diesel extravaganza 2012
hvactech is offline   Reply With Quote
Old 11-19-2012, 03:58 PM   eBay Motors  #13 (permalink)
bigjohn's Avatar
You'll be fine running the cat filter there built to separate the water I wouldn't worry about it just change the filter at 6 to 8000 miles.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
LET'S GO PENS!!!
bigjohn is offline   Reply With Quote
Old 11-20-2012, 03:33 AM   eBay Motors  #14 (permalink)
nick1camper's Avatar
Thanks for all the responses. It sounds like I will be better off with the CAT filter alone than with the factory filter. I have yet to see the "water in fuel" light come on anyway, on either of the dmaxes I've owned, so it's worth it for me to switch.
2005 ext cab sb LLY
4" exhaust w/muffler, EGR delete/Sinister diesel, Kodiak LBZ mouthpiece, PCV rerouted, Nicktane/CAT adapter, Autometer pyro & boost gauges, EFI Live by Kory, Transgo, pump rub kit, LBZ intake conv, H2's, Debadged
nick1camper is offline   Reply With Quote
Old 11-20-2012, 06:39 AM   eBay Motors  #15 (permalink)
TakeEm's Avatar
Yeah honestly IMO Cat wouldn't warranty a fuel system on their engines, with a filter that wasn't designed to separate water. I mean, on a job site, transfer tank to transfer tank (shipping to jobsite) I would expect water to be pretty common to get in fuel tanks.
Sent from my Autoguide app.
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 11-20-2012, 06:41 AM   eBay Motors  #16 (permalink)
ATPTRUCKS
sickdiesel's Avatar
Originally Posted by takeem View Post
yeah honestly imo cat wouldn't warranty a fuel system on their engines, with a filter that wasn't designed to separate water. I mean, on a job site, transfer tank to transfer tank (shipping to jobsite) i would expect water to be pretty common to get in fuel tanks.
Sent from my autoguide app.
x2.
Dustin im 22 and yes i bought my trucks myself
Blackout :06 GMC lbz 4x4 Built motor, SDP twins, exergy Injectors, Self built trans
White Thing :07 Chevy lbz 4x4 Caged and built to the hilt
Special thanks to: Mike L, Gtrippin, IdahoRob, SDP, ISSPRO, Yukon, and Cam at AP
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
sickdiesel is offline   Reply With Quote
Old 11-20-2012, 09:21 AM   eBay Motors  #17 (permalink)
2300Hz's Avatar
Technically speaking, Cat does not market the 1R-0750 as a water separator and because of that, they call it a secondary filter. They recommend a water separator as a primary filter. But that does not mean you can't just run the 1R-0750 and be perfectly fine....plenty of people are doing that without problems. Cat would just not recommend it.
For the sake of peace of mind and sanity, I'd run a Donaldson water separator with the clear bowl if that is to be your primary filter.
2005 Silverado LT 3500 SRW CC LB
6" SuperLift, 315/75/16, LBZ MP, EGR Blocked
2300Hz is offline   Reply With Quote
Old 11-26-2012, 07:14 AM   eBay Motors  #18 (permalink)
07LBZ6.6's Avatar
If you dont already know the factory fuel filter and water seperator are so inefficent most people would crap their pants if they knew what was getting through it, 60% at 6 microns vs 98% at 2 microns with the CAT. Im running the CAT 1r-0750 standalone and have no worries about not having the GM "Water Seperator"
2007 LBZ Black Crew Cab Short Bed
LT3 Dark Charcoal Interior with Sunroof
Stock for now...
07LBZ6.6 is offline   Reply With Quote
Old 11-27-2012, 08:41 AM   eBay Motors  #19 (permalink)
ATPTRUCKS
sickdiesel's Avatar
X2.
Old 11-27-2012, 08:50 AM   eBay Motors  #20 (permalink)
Thats cool. I'm pretty much sold on the CAT adapter, but just one more question.... When you pull the filter off to change it, what keeps the adapter from coming off as well?
2005 ext cab sb LLY
