| Aftermarket Mods. Discuss what Mods are right for you. |
| Junior Member Join Date: Jun 2012
| I can't find my connector. It must be hidden behind the door panel and its dark out here lol
__________________ 2003 Chevy 2500HD 6.6L, PPE Boost Valve, 5" Turbo Back MBRP Straight pipe, EFI Live |
| Junior Member Join Date: May 2012 Location: El Chuco/Lost Causes
| Might be behind the door unlock lock switch with a snap clip attached to frame of the door. Let us know what u find and we can help from there
__________________ 2002 2500HD LB7 Duramax 170K +|Spyder Front End Conversion (ALL LED & 6k HID)|Royalty Core Custom Grill|20" Rigid LED Bar (Hidden Grill)|EFI LIVE W/DSP5 from Bob Olsen aka "BOBO"|PPE Boost Valve|3" Leveling Kit|18" Pro Comp Mulisha Wheels w/Hankook ATM 285/65/18|Rancho XL9000 w/Shock Extensions|MOOG Idler/Pitman w/ Cognito Support Braces Kit|Edge Insight CS mounted above head console|4" MBRP Turbo Back with 6" Mulisha Tip |
| | eBay Motors #13 (permalink) |
| A bunch of white clips that the wire is taped too I guess I'll wait to pop the door panel off haha
| Senior Member Join Date: Feb 2009 Location: Upstate NY
| I will need these if I end up buying a gooseneck, subscribed.
__________________ Thank you to all of those who have served or continue to serve our country to keep our country free! '05 GMC 2500HD, CCSB, LBZ mouthpiece, A.R.E. cap, N-FAB nerf bars, 265/75/16 General Grabber AT2s. Winter truck- '98 GMC K1500 ECSB Z71, 135,000 one owner miles, custom buckshot dents compliments of 2am drive by. 2010 Camaro 2SS/RS 6.2 6 speed. |
| | eBay Motors #15 (permalink) |
| The 01 and 02 had short wires- and the wires are different. The 03-07 had the longer wires, and plugs into the drivers control panel switch. It should plug in OK, except for the lights. That you will have to run through the door loom.
| | eBay Motors #16 (permalink) |
| Junior Member Join Date: Sep 2010 Location: Portland Maine
| does any one have the "HOW TO" on turning the outer lights to running lights
__________________ 2006 LBZ extended Cab - S&B cold Air Intake MBRP down pipe, 4" Turbo back AFE ss exhaust, EGR cap, EFI Autocal with "Idaho Rob" tunning DSP5 switch, Nicktane fuel filter adapter, EDGE CTS, Hella Black magic behing the grill 50,000 miles |
| | eBay Motors #17 (permalink) |
| Ok so I figured out today I have the two plug into the window control panel. Now my next question would be, do you think I would be able to run mirrors without the signal in the glass or would the mirror just not work? Also do the amber running lights work with the oem connector?
| | eBay Motors #18 (permalink) |
| Yes you can run the mirrors without the signals. The mirrors will work fine. The running lights will NOT work, unless you add a wire to the mirrors-, and wire it into the truck lights.
| | eBay Motors #19 (permalink) | |
| Senior Member Join Date: May 2009 Location: Highland Lakes, NJ
| Quote:
look up Frisco Jarretts on Youtube EDIT: Here is a link! http://www.dieselplace.com/forum/sho...154&highlight=
__________________ 2005 GMC 2500HD • 4x4 • Duramax • Allison • Denali Style Grill • 285-75-16 Cooper Discoverer ATPs • MBRP 4" Stainless Turbo Back • Diamond Eye Turbo Direct Pipe • LBZ Mouthpiece • EGR Blocked & Cooler Bypassed • PPE Standard Level 4 • Autometer Cobalt Boost Gauge • EDGE Insight CTS w/ EGT Probe • Head Gaskets & Studs @ 145,000 MILES Check out some pics HERE HERE Last edited by js05sierrahd; 12-10-2012 at 08:58 AM. | |
| | eBay Motors #20 (permalink) | |
| Quote:
here it is for every one else and the second part http://www.youtube.com/watch?feature...-OK6bfEkc&NR=1
__________________ 2006 LBZ extended Cab - S&B cold Air Intake MBRP down pipe, 4" Turbo back AFE ss exhaust, EGR cap, EFI Autocal with "Idaho Rob" tunning DSP5 switch, Nicktane fuel filter adapter, EDGE CTS, Hella Black magic behing the grill 50,000 miles Last edited by tbabbott; 12-10-2012 at 09:52 AM. | |
