| Aftermarket Mods. Discuss what Mods are right for you. |
| Junior Member Join Date: Jun 2012
| Towing mirrors Looking at these mirrors,2003 Chevy Silverado 2500 Mirror - AM Autoparts Just wondering if my factory will connect to them. I have power signal but not sure if I have heated or not. I turn the defroster on and they warm up but no icon in the mirrors like other mirrors I see. Any input?
__________________ 2003 Chevy 2500HD 6.6L, PPE Boost Valve, 5" Turbo Back MBRP Straight pipe, EFI Live |
| DuramaxForum Veteran Join Date: Aug 2012 Location: Youngsville/Wake Forest
__________________ 2004.5 Sierra SLT 4WD CCSB Black/Black Studded, Deleted, Re-Routed FPRV Race Valve LBZ FPR 20x10 ET -12 Fuel Hostage Nitto 420s 305/50/20 All-On Mod MA Pump Rub Kit 3" DE Down Pipe to a 7" Single Mitre Cut EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI |
| Duramax Lifetime Supporter ![]() Join Date: Jul 2012 Location: butler, pa
| Take a look at the ones atp truck have good deal
__________________ 2007 Classic lbz Turbo back exhaust, Efi live auto cal from idaho Rob egr blocked, trans go jr, grizzly locker,leveled 285-75-16 wrangler duratracs radials on pro comp wheels,remote start, afe intake air dog 165, billstien 5100s,Afe intercooler pipe, pcv valve reroute, diamond eye down pipe , bushwacker pocket flares, BD exhaust manifold, g2 diff cover with girdle stage 5 trans coming soon. line x bed liner,extang trifold toneau,edge cts, allison deep pan with transynd fluid suncoast filter lock. |
| Was wondering how they would fit my truck. Like if I needed all those features for them to work properly
| This space for rent! ![]() Join Date: Oct 2011 Location: MT/K.C./FL
| Mine didn't have the little picture either but they were indeed heated. The factory connection should work w/those. That is a great price, think I paid about $50 more for my that are esentially the same ones. Only bummer is that the signals aren't "Marker" lights. Apparently someone on here has a mod to change that though.
__________________ 05 LT 2500 CCSB 4x4 LLY 11 Harley Road King Classic "Screamin Eagle" 12 F350 King Ranch 6.7l PS Of course all kinds of other stupid "Sh*t" ------ Yes Koho is a fish, but atleast I don't have Walleye vision --------- |
| The one ATP has say power extending which would be sweet but I don't know how it would work. I emailed Rob about it. Sent from my iPhone using AutoGuide.com Free App
| Senior Member Join Date: Oct 2011 Location: Vermont
| I have AM Auto Parts towing mirrors on my LMM.Great mirrors at a great price.
__________________ 2008 LMM Silverado 2500 LTZ ECSB 4X4. Aftermarket calibration,Nicktane with Baldwin BF7587,PPE lift pump with Baldwin BF1212 water separator,285/75/17 Dura Grapplers on H2s,CTS Insight with pyro,Large fender mod. Proud Member U/A Local 693 Plumbers/Pipefitters. |
| Junior Member Join Date: May 2012 Location: El Chuco/Lost Causes
| I am not sure which plug you have in your door right now, however I would go check that first. My 2002 Lb7 the plug didnt match however I expected that, I just cut the plugs and rewired it, I have the drawing for the 2002 Mirror plug and the Wiring for the 2003 so I made it work. I also have the way to add Blinker & parking lights feature. Couple .99 Resistors and 10 feet of 22 Gauge wire and you are set for parking lights. I just haven't had the time to do the "How To - DIY" but I can walk you thru it. I would say go for it, they ship fast and are great lights, I just put a little extra bead of clear silicone around the side marker cause water likes to jump inside. but after that you have a awesome set of lights!!!! Also Check Ebay they sell also on there, it might only be 10 bucks cheaper but with that you can do the Signal & Parking light mod.
__________________ 2002 2500HD LB7 Duramax 170K +|Spyder Front End Conversion (ALL LED & 6k HID)|Royalty Core Custom Grill|20" Rigid LED Bar (Hidden Grill)|EFI LIVE W/DSP5 from Bob Olsen aka "BOBO"|PPE Boost Valve|3" Leveling Kit|18" Pro Comp Mulisha Wheels w/Hankook ATM 285/65/18|Rancho XL9000 w/Shock Extensions|MOOG Idler/Pitman w/ Cognito Support Braces Kit|Edge Insight CS mounted above head console|4" MBRP Turbo Back with 6" Mulisha Tip |
| So order them anyways and you could shoot me the schematic if something isn't right?
| Take a look at your door clips and double check what you have first. So you know what you will need exactly. Pop open the triangle piece on each door and see if you can see the plug and ask vendor if it will work. On the 02 it wasn't plug and play. However I have heard the 03 are. Just double check your harness first that is the for sure way to know what you need. I can upload the diagram or email it to you. First pic is of my 02 factory plug. Second pic of of the 03 mirrors with two plugs, as you can see I had to cut, however look to see if you have the same plug as the 03 I just posted. ImageUploadedByAutoguide1355007195.766160.jpgImageUploadedByAutoguide1355007257.445931.jpg Hope this helps you.
