| Aftermarket Mods. Discuss what Mods are right for you. |
| | eBay Motors #21 (permalink) | |||
| DuramaxForum n00b Join Date: Aug 2012 Location: Blacksburg, Virginia
| 2008 Chevy 3500HD Silverado Dually Lift 6 Inches - Online Garage The size of this truck right here, w? a 6” lift and 35’s, is ideal in my opinion, it’s high enough for good ground clearance, but not to the point where it would be blown over easily. Especially with all the extra weight I’m going to be adding. If you’ve seen an episode of storm chasers after the first season, you’ve probably seen Tim’s truck He’s been in some nasty winds from RFD along with accidentally intercepting a weak tornado. His CoG is much higher, along with a huge surface area for wind. I’m not saying that with a 6” lift and 35s or 37s it won’t be hard to drive in high winds, I’m just trying to figure out the loss of ground clearance (which is really important to me), is really that necessary. Quote:
| | eBay Motors #22 (permalink) | |
| Senior Member Join Date: Mar 2011 Location: Zanesville, Ohio
| Quote:
I have seriously been looking at doing a snorkel, and been searching and searching, seen pictures of it on a duramax, but never seen anyone who actually done it talking about it. I did see ONE dyno test on a supercharged jeep I6, where it actually lost 30 horses with the snorkel. But, ONE guy said, according to his boost guage on his custom turboed avalanche, he lost 50% boost in town, but gained 50% at highway speed, but no dyno test nor did he actually notice anything.
__________________ 2011 Chevrolet Silverado 2500HD WT, Victory Red, 4x4, ECLB, Duramax(LML)/Allison, Heavy Duty Towing Package Insalled: Amp Research, Amsoil, B&W, Back Rack, Bushwacker, Code Alarm, Cognito, DRP, FASS, Goodyear, H&S, Hypertech, Mayhem, MBRP, Plasti Dip, Precision, Ranch Hand, Rhino Linings, Rigid Industries, Rough Country, S&B, Titan, Warn, Weather Guard Need the Guts to Install: Frost Fighter, Snow Performance, Autometer, ATS. http://www.dmaxstore.com, Your Duramax Diesel-Only Shopping Resource | |
| | eBay Motors #23 (permalink) |
| DuramaxForum Veteran Join Date: Aug 2009 Location: Northern VA
| Bead locks are illegal to run on the highway in VA. As far as trans I would contact Big Dipper, search him on here, he is in Baltimore and is the go to guy on the east coast for a built Alison.
__________________ 2003 2500HD LT CCLB, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, Edge CTS, Cognito UCA, Rare Parts Tie Rods, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, PPE Level 2, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air ![]() http://www.trollperformance.com/ You know you want too |
| Junior Member Join Date: Jun 2011 Location: Midland TX
| Independent suspension lift kits dont raise the center section so you really only gain ground clearance by being able to run bigger tires. What have you seen that puts the ground clearance so high on the list?
__________________ Taquache Motorsports 2007 Fiat QCSB Dually Not Stock 2007 Jeep Grand Cherokee Diesel |
| Senior Member Join Date: Jun 2010 Location: Delaware
| This is a perfect thread to look at, that truck is bada$$. I know my gmt900 cc with a 6" bracket set at 5" does not like high winds its all over the road, and definitely get EFIlive over edge. The only thing edge is good for is the CTS monitor to check your gauges.
__________________ ![]() 10 GMC 2500 SLT LMM> 5" mbrp EFIlive dsp5 tuned by Rob Edge CTS insight MBRP dp EGR blocker plate 6" pro comp 35" toyo MT 22 american force SS fox shocks 11 Silverado 6.2L LTZ k&n intake black bear tone and spintech mufflers |
| DuramaxForum Veteran Join Date: Aug 2012 Location: SLC, Utah
| Traction bars too... I would also get a gear rack to go on the roof. Also make sure that the bed cover is 100% secured from being torn off... Also may want to get some recon tail lights so people can see your tail lights better in low visibility conditions... And a light bar too... If all else fails and the truck doesn't workout for you, you can probably buy this Guys cummins off of him ImageUploadedByAutoguide1355158573.422716.jpg
__________________ 2006 LBZ CCLB DRW Suncoast Trans w/ 1056 Billet Garrett 4094 BTLockup Box Built Front End Some More Stuff EFI Live by Starlite Diesel Fastest 1/4 yet: 13.606 (fourth time down the track) |
| | eBay Motors #27 (permalink) |
| Getting stuck myself because I didn't have enough clearance, along with being able to drive over smaller branches and whatever else is needed, in case of emergency. Plus, muddy roads are a chasers worst nightmare. Being able to take a muddy dirt road to catch up from a storm, or get out of the way of one, is an enormous advantage. Plus, getting stuck in the mud with a storm coming straight towards you.. bad news. |
| | eBay Motors #28 (permalink) |
| This looks like a rig you should aim for... ImageUploadedByAutoguide1355175977.198275.jpg
| | eBay Motors #29 (permalink) |
| That's very very close to what I'm looking for! Just more lights, a bed shell, and lots of antennae And lots of other stuff... |
| | eBay Motors #30 (permalink) |
| Are you going to Line X your truck? It would handle hail and rough weather better...
