| Aftermarket Mods. Discuss what Mods are right for you. |
| DuramaxForum n00b Join Date: Sep 2012
| Installed new Airaid CAI and got a check engine light I installed a Airaid CAI on my 2011 2500hd Monday and I was driving it today and I noticed the check engine light was on. I don't have a code reader and my truck only has 28 thousand miles. When I was installing the Airaid filter it kept falling off, but I finally got it to stay and I thought it just fell off again today, but it's on there nice and snug. All the wires are reconnected properly the sensors are in place and I'm clueless to what the problem is. One more thing I didn't unhook the battery when I swapped the sensor over but the truck was off. |
| | eBay Motors #2 (permalink) | |
| DuramaxForum Veteran ![]() Join Date: May 2009 Location: Mtn Home Idaho
| Probably a MAF sensor. My LMM had a CAI on it before I bought it, and when the stock box got put back in it kept throwing a MAF code. It kept putting my truck into reduced power. Has your truck gone into reduced power mode, or did they get rid of that dumb ass idea for 2011?
__________________ 2008 2500HD CCSB EFI Live by Idaho Rob Coddens Adrenaline Truck Performance 4" turbo back MBRP by Pat at BT Diesel lifted with 35s. Quote:
| what matters is our plan Join Date: Jan 2012 Location: Cypress Tx
| subd to see whats up going to be installing my S&B this weekend with the scoop
__________________ Life's simple, you make choices and you don't look back White 2012 LML CCSB LTZ 4x4, all the Options. + NAV/Sunroof/Rear Sliding Glass -Dropped 7.5" RCX, Sulastics, Cognito UCA's/Supports, DUAL Stabilizer's, Nicktane Cat, Fox's, Reso Delete -S&B+Wrap+Scoop, Edge CTS, 5" Flo Pro, XRT PRO on Hot, Nfabs, Debadged, 22x9.5 Throttles on 35x12.50 Gray 2008 ECSB LT Silverado "Texas Edition", OEM 20's- Daily Driver Body Dropped Build Thread - 2001 Sierra / 2000 S10 - Lowering A Lifted Truck - Cognito Support Kit- Cognito UCA kit - How To LML Cat Adapter -Modified Dual Stabilizer Kit- |
| | eBay Motors #4 (permalink) | |
| Quote:
| it stinks and whistles :) Join Date: Aug 2010 Location: newfoundland
| Is the intake a different diameter then the stock one? That could screw with your maf readings Sent from my iPhone using AutoGuide.com App
__________________ |
| Im pretty sure it is but wouldn't it adjust? |
| Like the sensor adapting to the new airflow? |
| The maf is calibrated to measure the air flowing through a certain diameter pipe. you change the diameter of the pipe, you mess up the readings. That's my understanding anyway Sent from my iPhone using AutoGuide.com App
| Okay just took it to the dealership and they cleared the codes. They were P20EE and P2201. They said if it happens again I'm gonna have to put the stock intake back in. |
| I looked up the codes and the P20EE code is for poor quality DEF and the P2201 is the nox sensor. |
