Well i got twin turbos and im not sure if i should get this Yes/No???
Because after i dropped off my girlfriend at the house and then as i was getting back on the highway and as i was taking the side road to get onto the highway i was going about 55-60MPH and the speed limit was 45MPH so i let my truck cost down to 45MPH and then after i got onto the highwat road i florid it and then my turbos winded up then all of a sudden i heard a loud POP!!!! and then i lost all turbo boost and my truck smokes like a coal train with no power really slow but roals coal like crazy though and well did i pop my turbo or did the hose just blow off because as your driving it you can still hear the turbo power up and it whistles just no Boost and heres a video my friend recorded from later today. Heres the video on how much my truck smokes right now Duramax Rowling Coal The Right Way!!!! - YouTube
Image/Name/Price/Details.
Here is a Picture of my trucks Twin-Turbos
TurboGuard Blow-Off Valve-$646.00
Closing the throttle suddenly when the engine is under load can result in turbo damage. BD's TurboGuard blow-off valve protects your stock or aftermarket turbo from surging and possible compressor wheel explosions. This new advanced TurboGuard kit features adjustable valve opening pressure and a microprocessor with six different custom settings, including valve opening pressure, activation sensitivity, clutch cancellation, and more.
Features:
Steel Weld-On Adapter
Microprocessor W/ Six Custom Settings
Protects Turbocharger From Surging
Fits Many Applications - Fabrication Required
Additional Information
Install Sheet
And i was wondering can someone tell me what this "IS" and "HOW IT WORKS" and "HOW WILL IT WORK ON MY TRUCK?"
Turbo Intake Flange-$44.98
The Empire Performance EPE-M1001MS Turbo Intake Flange for your 04.5-15 GM 6.6L Duramax allows you to custom build your own intake plumbing for a twin turbo setup or intake piece. Retains the use of stock clamps and accepts 3" pipe.
Features:
One Mild Steel Flange
Includes One O-Ring
Allows For Custom Fabrication
Features:
Install Sheet
Features:
Includes One O-Ring
