Duramax Fluid Types and Capacities - Chevy and GMC Duramax Diesel Forum
Alligator Diesel
 3Likes
post #1 of 37 (permalink) Old 04-26-2012, 08:36 AM Thread Starter
Go Green!
Blackcloud556's Avatar
This is a quick list i threw together for our trucks. If anything is wrong let me know and ill fix it.
*Engine and Filter
Type
SAE 15w-40 for conventional oil
SAE 5w-40 for synthetic oil
Capacity
10.0 quarts w/ Filter
9.20 quarts w/o Filter
*Automatic Transmission
Type
2001-05 Allison Transmissions – DexIII
2006-10 Allison Transmissions - DexVI
Capacity
Drain and fill 5 & 6 speed Allison 1000 7.4 Quarts
Overhaul (dropping valve body) 5 & 6 speed Allison 1000 12.7 quarts
Total Capacity after rebuild 20 Quarts
*Built transmissions of any year run recommended transmission fluid per kit/builder instructions.
*Manual Transmission
Type
NV4500 GM Synthetic Manual Transmission Fluid
ZF S6-650 Synthetic Transmission Fluid approved to Allison specs TES-295
Capacity
NV4500 4 quarts
ZF S6-650 6.3 quarts
*Differential
Type
75w-90 synthetic gear oil for front and rear
Capacity
8.6 Rear 2.16 quarts
9.50 Rear 2.75 quarts
9.75 Rear 3.00 quarts
10.50 Rear 2.75 quarts
11.50 Rear* 3.17 quarts
8.25 Front 1.51 quarts
9.25 Front* 1.83 quarts
*Typical Duramax Size
*Transfer Case
Type
Manual Transfer Case: ATF DEXRON III
Automatic Transfer Case: Auto-Track II fluid
Capacity
NVG 246-NP8 2.0 quarts
NVG 261-NP2 2.0 quarts
NVG 263-NP1 2.0 quarts
*Air Conditioner Refrigerant
Type
R-134a
Capacity
All Models 1.60lbs
*Brake Fluid
Type
DOT 3 Brake Fluid
Capacity
All Models Top-Off as required
*Engine Coolant
Type
50/50 Mixture of DEX-COOL and clean drinkable water
Capacity
6.6 Engine Manual Trans 25 Quarts
6.6 Engine Auto Trans 25.4 Quarts
*Power Steering Fluid
Type
GM Power Steering Fluid
Capacity
Blackcloud556 is offline
post #2 of 37 (permalink) Old 04-26-2012, 08:39 AM
rebpdt's Avatar
Type
2006-10 Allison Transmissions - DexIV
Capacity
Initial Fill 5 & 6 speed Allison 1000 7.4 Quarts
Drain and fill 5 & 6 speed Allison 1000 12.7 quarts
d
aren't those flipped?
CCSB LB7 4x4
rebpdt is offline
post #3 of 37 (permalink) Old 04-26-2012, 09:08 AM Thread Starter
Go Green!
Its right unless amsoils website is wrong
AMSOIL Product Recommendations - 2006%7cCHEVROLET+TRUCKS%7cSILVERADO+2500+HD+PICKUP %7c3
I just took their data and data from Mitchel1 and compiled it.
cathyhill413 likes this.
post #4 of 37 (permalink) Old 04-26-2012, 09:16 AM
it stinks and whistles :)
Brennan's Avatar
Why run 5w40 if your using synthetic?
Sent from a muddy shoe phone
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #5 of 37 (permalink) Old 04-26-2012, 09:16 AM
rebpdt's Avatar
amsoil can't be wrong
just seems like the drain and fill would be the 7.4 qts and the initial would be the higher one
i know i just bought 2 gals of trans fluid when i've drained it to switch to transysnd and had some leftover for adding after spin on changes
CCSB LB7 4x4
rebpdt is offline
post #6 of 37 (permalink) Old 04-26-2012, 09:21 AM Thread Starter
Go Green!
Mitchel has it that way as well..
we also use a lil over 12 quarts here when we do a transgo. :shrug:
post #7 of 37 (permalink) Old 04-26-2012, 09:49 AM
Banned
What is DEX IV?
dieselnuts6 is offline
post #8 of 37 (permalink) Old 04-26-2012, 03:32 PM Thread Starter
Go Green!
Dex 6 is the fluid that comes from the factory in the 6spd allys
post #9 of 37 (permalink) Old 04-26-2012, 04:08 PM
H.G. Wells's Avatar
Hey, thanks for that. Will be doing a fluid change this weekend on trans/transfer case/front/rear
H.G. Wells is offline
post #10 of 37 (permalink) Old 04-26-2012, 04:21 PM
kylez's Avatar
May want to note that some 06 transmissions call for dex 3 based on serial number. Drain and fill is 7.4 qts.
2006 LBZ GMC CCSB 4x4 white
17" XD addicts, 285/70/17, RC Sleeves, Air Lift Bags, Bilstein 5100's, PPE braces, Bakflip tonneau
AFE intake, ProFab DP, MBRP turboback, Insight CTS w/egt, DSP5 from ATP
Transgo JR, EGR blocked, PCV re-routed, M/A pump rub, DDM 5k low/hi & 3k fogs
kylez is offline
