Alligator Diesel Alligator Diesel Performance |
| | eBay Motors #51 (permalink) |
| DuramaxForum Veteran Join Date: Dec 2010 Location: Southern California
| Thanks guys!
__________________ http://www.trollperformance.com/ |
| | eBay Motors #52 (permalink) |
| Senior Member Join Date: May 2011 Location: Rupert ID
| Ok so I hdt got of the phone with adp and I was told that I could either get a refund or try a new adaptor because the 2nd bad batch was bad due to wrong threads? I decided to have them send me one of their new ones and I'll be sending faulty one back(red). I honestly think they will give the new batch more extensive testing and if not I'll just give udp's adaptor a go. Worst that can happen is I end up dropping a big coin on an ad2
__________________ Silver ccsb lbz 4-6" pro comp lift, Skating 20"s wrapped up in 35" nitto trails,Black 7" axle dumped tip, Debadged, Smoked tail lights Dsp5 @ diesel addiction, Afe cold air intake, Alligator fprv, Alligator cat adaptor w/donoldson filter, PVC re-route, 4" straight pipe, Cobolt boost & egt gauges, Transgo jr. To do list Egr blocker plate |
| | eBay Motors #53 (permalink) |
| Junior Member Join Date: Mar 2011 Location: Butler, PA
| I just got off the phone with Alligator for the third time. The first two guys said they would call me back and never did! I am not tryen to be an ass but this is my daily driver and I am kind of mad that I am going to have to go buy another $50 stock fuel filter to fix a problem that is not my fault. If my truck sits more than 2 hours I have to prime it. This isnt fun at 5 AM. Now I just got off the phone with Alligator and the guy said they are only sending out new adapters. And it will be at least another week atleast! So it looks like I am going to be out $50 for a stock filter and for a Cat filter because I am not wanting to put on a used filter. I hope they can make this right for me. Sorry for the rant, I know its not Alligators fault but I just want them to make this right ASAP.
__________________ 05 EC/SB Sierra SLT Rerouted, AFE MP, 5 Inch D.E. Str8 Pipe, pro fab dp, Edge CTS, EFI by Rob, Sleeves, ported fuel rail fitting, ARP headstuds and grade C gaskets, Leveled on black H2's with 285's. Future Plans: Trac Bars, Lift Pump Tyler @ www.meyerperformance.com |
| | eBay Motors #54 (permalink) | ||
| Senior Member Join Date: Apr 2011 Location: Hopkinsville, KY
| Ok. So if I buy an ADP adapter, then I will wait a couple weeks to see if the new stock of adapters works for everyone.
__________________ 05 GMC LLY crew cab 4x4. aFe intake + mp, catback 4" exhaust, Nicktane Adapter w/CAT filter Wishlist: Edge CTS Insight, downpipe, full 4" exhaust, LML Manifold, EFI, EGR delete, head studs, lift pump Interior:Eclipse Nav/DVD head unit complete with backup camera Quote:
| | eBay Motors #55 (permalink) |
| Honestly man just go with nicktane or a udp adaptor. I can't recommend alligator crap adapters to anyone at this time.
| | eBay Motors #56 (permalink) | |
| Senior Member Join Date: Feb 2008 Location: So. Cal
| Quote:
YEP!!! I was pretty upset when I had to pull off the CAT adapter and put on a new stock filter also. I guess the one plus is that it confirmed the fact that the adaptor was the issue.
__________________ Name: Joe 06 2500 LBZ 4X4 __________________ | |
| | eBay Motors #57 (permalink) | |
| Go Green! ![]() ![]() Join Date: Jun 2010 Location: Coeur D'Alene Idaho
| Quote:
At this time we have suspended all adapter sales. We have had hundreds that work without a problem, then a handful that have prime issues. some loosing prime, some have been leaking. I pressurized one of the "leaking" ones up to 160psi (which is 140-150psi higher then they will ever see, dumped it in a bucket of water and found no leaks at all. Due to not being able to duplicate the problems we felt it prudent to pull the product until they can be 100% fool proof. | |
| | eBay Motors #58 (permalink) |
| Junior Member Join Date: Oct 2011 Location: Altoona, PA
| Thanks for the update Jason. If we have already contacted Alligator about the problem, do we just wait to hear from you guys about a replacement? Hopefully you guys can find the solution. It is very mysterious that the truck will run fine without any leaks, but lose prime after sitting for awhile.
__________________ 2005 Silverado LT 3500 SRW CC LB 6" SuperLift, 315/75/16, LBZ MP, EGR Blocked |
| | eBay Motors #59 (permalink) |
| DuramaxForum Enthusiast Join Date: Apr 2012 Location: Pittsburgh Pa
| Jason took care of the cat adp I had sent the old one back and they sent out the new cat adp. They ll take care of the problem.
__________________ 2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again. 2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ. |
| | eBay Motors #60 (permalink) | |
| Quote:
but whatever problems come up, ill get them fixed for people | |
