Cat filter - Chevy and GMC Duramax Diesel Forum
Alligator Diesel Alligator Diesel Performance
Old 12-13-2012, 04:33 PM   eBay Motors  #1 (permalink)
Cat filter
So my cat adaptor has lost prime 3 times since install. I'm starting to think more and more that this is going to be a constant issue. When I installed I took the check ball and spring out so my question is what do I need to do to fix this? If I have to I'll just revert back to the oem filter till I get an air dog or something
Silver ccsb lbz
4-6" pro comp lift, Skating 20"s wrapped up in 35" nitto trails,Black 7" axle dumped tip, Debadged, Smoked tail lights
Dsp5 @ diesel addiction, Afe cold air intake, Alligator fprv, Alligator cat adaptor w/donoldson filter, PVC re-route, 4" straight pipe, Cobolt boost & egt gauges, Transgo jr.
To do list
Egr blocker plate
Dill Dough is offline   Reply With Quote
Old 12-13-2012, 04:35 PM   eBay Motors  #2 (permalink)
blitzin247's Avatar
who made it?
Purchased 11/15/12: 2004 LB7 CCSB, ATS 4000 turbo, upgraded injectors, Diamond Eye 4 inch turbo back exhaust, H2's on 315/70/17's, Ranch hand front bumper. EFI LIVE by Kory Willis
Purchased parts awaiting install:
Moog problem solver lower ball joints, Moog pitman and idler arm, AD 165
Special thanks to: Brent@LDS, mrmanners@Synthetic Motorsports, and [COLOR="Magenta"]Kory Willis
Jesus loves YOU, Have you asked Him to be your Savior yet?
blitzin247 is offline   Reply With Quote
Old 12-13-2012, 04:47 PM   eBay Motors  #3 (permalink)
Duramax19's Avatar
did you get the rebuild kit when you bought the adapter or did you use the old gaskets.
20" xd wheels 265/60/20 Goodyear wranglers 5" turbo back exhaust EFI live tuning by Danvilleperformance Alligator performance resonator plug Edge CTS Insight ATS Co-pilot PPE deep trans pan Alligator performance tranny cooler lines Garret 4094avnt Pro-fab downpipe
Duramax19 is offline   Reply With Quote
Old 12-13-2012, 04:50 PM   eBay Motors  #4 (permalink)
bigjohn's Avatar
Mine is doing the same thing so I put the oem back on. I notice when I took the cat Adp off on the rubber seal that the grease that I put on was down to the rubber on the two opposite and there was a 1 / 16 of grease on the two opposite side of each other so that told me the filter housing is warped. So tomorrow I'm going to NAPA to get some liquid gasket put a bead down on the cat Adp to see if that cures the problem.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
bigjohn is offline   Reply With Quote
Old 12-13-2012, 04:52 PM   eBay Motors  #5 (permalink)
Stevenmc89's Avatar
Same problems here with my nicktane/donaldson
2002 LB7 CC/SB 4X4, 6" RCX LIFT, 37" TERRA GRAPPLERS, 18" KMC HOSS, K&N CAI, EDGE EVOLUTION CS, STRAIGHT PIPE, NICKTANE, RANCHHAND BUMPER WITH 30" RIGID LIGHT BAR, AND OTHER DOO DADS
Stevenmc89 is offline   Reply With Quote
Old 12-13-2012, 05:04 PM   eBay Motors  #6 (permalink)
Thebiggids's Avatar
Strange. Ive had zero issues with mine for 3 months.
Gideon
01 LB7 EC/SB Ally 4x4 shop ornament
DD: 1990 4runner completely stock 4x4 3.slow
Big Thanks To Adrenaline Truck Performance, Alligator Diesel Performance, and Socal Diesel
Thebiggids is online now   Reply With Quote
Old 12-13-2012, 05:17 PM   eBay Motors  #7 (permalink)
Stevenmc89's Avatar
You're lucky! I pure deformed the little 1/4" holes I was tightening it so tight and it still leaked!
Old 12-13-2012, 05:19 PM   eBay Motors  #8 (permalink)
Alligator made it. That's why I posted under adp section.
But I'm running a Donaldson filter and idk if it's the filter or the adaptor but it's leaking in between the 2 because I popped my hood and saw a couple air bubbles come out.
I haven't really messed with it since the first install but maybe when I get paid I will buy a rebuild kit and year into it one more time before I go back to the oem filter.
But what I don't get is what could cause it to lose prime? Filter, adaptor or bad gaskets?
Silver ccsb lbz
To do list
Egr blocker plate
Old 12-13-2012, 05:25 PM   eBay Motors  #9 (permalink)
Stevenmc89's Avatar
I rebuilt my fuel filter head at the same time I installed the nicktane yesterday and when I put my old wix back on it quit leaking so its definately the adapter
Old 12-13-2012, 05:32 PM   eBay Motors  #10 (permalink)
Well I guess I will pick up a rebuild kit next week and start over again.
But something tells me a dhit load o silicone is gonna be the only cure to these adapters smh...
Silver ccsb lbz
To do list
Egr blocker plate
