Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > Alternative Fuels - Diesel - Additives - Lubricants
Alternative Fuels - Diesel - Additives - Lubricants Discussion Of Diesel, its Various Additives, Oils, Lubricates & Alternative Fuels EG. Bio-Diesel ect...
Old 10-11-2008, 01:48 PM   eBay Motors   #1 (permalink)
AlisoBob
Points: 370, Level: 6
Points: 370, Level: 6 Points: 370, Level: 6 Points: 370, Level: 6
Activity: 9%
Activity: 9% Activity: 9% Activity: 9%
My thoughts on lubrication...
It seems everyone is really on the "Synthetic" / "Amsoil" bandwagon around here.. and dont get me wrong, its good oil.
That said, let me give you a little background info on myself... I have 25 years in the crane / heavy equipment industry.
In my vehicles, I use either Mobil 1 ( gas motors) or Shell Synthetic Rotella T diesel motors) in the engines.
In the remainder of the vehicles, I use good old dino-oil.
Why?
"The soultion to poultion is dilution"
In the axles, transfercase and powersteering system, there is no filtration to remove wear causing particles, replacing the lubricant is the only answer.
The quality of the oil, no matter how good, cannot overcome the wear induced from the particles suspended in it.
For the cost of one Amsoil oil change, you could service these systems several times, removing the debris with each servicing.
What about the transmission? Thats a grey area I'll leave up to you. Yes, its filtered, and yes the temps suggest synthetics are warrented... but I stick with dino oil here too.
I change it with every oil change, its cheap. I also pull the pan one a year to swap out the internal filter.
I know what Allison says about "Once every 100k miles"
No way.
The filter is $30, and takes 30 minutes to change. I'll do it once a year.
$300 "Deep" transmission pans also seem to be money mis-spent. You can either add an additional cooler, or really double up on the servicing for that money...
I know some of you will strongly disagree, but in 30 years of vehicle ownership, I've never lost a major component on a vehicle. My current ride, a 2002 Silverado 1500 has 188k, and the ONLY non factory part is the "in tank" fuel pump that was replaced ( pre failure) at 150k miles as a precaution.
I predict my new Duramax will last quite a while on a diet on synthetic Rotella T, and dino oil for everything else...
AlisoBob is offline   Reply With Quote
Old 10-11-2008, 04:23 PM   eBay Motors   #2 (permalink)
Durallymax
Points: 2,436, Level: 20
Points: 2,436, Level: 20 Points: 2,436, Level: 20 Points: 2,436, Level: 20
Activity: 91%
Activity: 91% Activity: 91% Activity: 91%
Durallymax's Avatar
Our trucks come with synthetic in the rear. I know on engines its neverssuggested to switch back to dino due to the fact that it will eat up the seals. But in the rearend there arent too many.
You can add a magnetic drain plug or dipstick to attract the particles.
As for the Allison. Servicing more frequently does not compare with a deep transmission pan. A Deep tranny pan adds up to 5 more quarts of capacity which lowers temps no matter what. No amount of servicing can do that. You also HAVE to run a deep pan with a built transmission.
A Deep transmission pan is only $80. The pretty ones are $270. II went with the pretty on because I didnt have to pay for it and it offers 5 quarts of additional capacity and has cooling fins. The $80 pan is the factory allison deep pan which holds and extra 3 quarts but is basically the same as the stock pan just deeper.
In my Engine I will be running Cen-pe-co oil changed every weekend. It truely is the best oil out there especially for the cost.
On our farm we run some cheap dino oil that works fine. Those old cummins motors in our tractors dont care what you put in them.
The "Dieselholic"
Dieselholic Homepage
'03 GMC 2500HD LB7/Allison EC/SB 4x4 Dark Charcoal Metallic SLT. Injectors at 84,000. Sled Puller/DD
EFI Live: V7.5.5/V8.1.2 OS:03904405
Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
Many mods to come over the winter.
Durallymax is offline   Reply With Quote
Old 10-11-2008, 05:12 PM   eBay Motors   #3 (permalink)
snoclo
Points: 240, Level: 4
Points: 240, Level: 4 Points: 240, Level: 4 Points: 240, Level: 4
Activity: 0%
snoclo's Avatar
Synthetic definitely has a place in conditions where it is high temp/high load.
Since my truck came with it, I'll stick with it. The info with my truck states that the motor, tranny, transfer case, & rear diff all came with synthetic.
As far as adding capacity to lower temps, that is false!
You will have a longer period to reach upper temps, but actually the end result will be more hot oil. Not any cooler-just more of it.
I'm sure the finned pan helps reduce temps though, just as a trans cooler/radiator helps-because your flowing over or thru a device that has surface area to dissapate the heat.
The key to longevity- quality of oil/s, frequency/intervals it is changed,& reduced temps.
Adding another cooler or increasing the size of your existing 1 will give you the most for your $$$money$$$
Al in C.R., Iowa
06' LBZ SLT CCSB 4x4,
Edge w/Att. & Trans Go Jr.
4" Silverline-S.S.Turbo Back,
6" Fabtech, roll'n M/T ATZ 325/65/18's
snoclo is offline   Reply With Quote
Old 10-11-2008, 05:41 PM   eBay Motors   #4 (permalink)
AlisoBob
Activity: 9%
Adding volume dosent equal a cooler transmission, it only creates more of a buffer to absorb heat. It will eventually reach the sane temp, given enough time.
Old 10-11-2008, 06:10 PM   eBay Motors   #5 (permalink)
n0useforaname
Knows your Mom
Points: 6,656, Level: 34
Points: 6,656, Level: 34 Points: 6,656, Level: 34 Points: 6,656, Level: 34
Activity: 100%
n0useforaname's Avatar
Either way though, the tranny will stay cooler longer than it would with a small pan. And if you run your truck a lot, it will spend more time cooler than hotter. Either way for me....I always hear of diesel trucks running 300,000 + miles. And most of those diesels are older trucks that ran regular oil... With todays engine upgrades, I don't see why a diesel truck won't last just as long....Synthetic or not.....as long as it's maintenanced properly
RIDE: 1930 Chevy CC LBZ / 2 speed powerglide trans!!
LIFT: Ready Lift Leveling Kit
STARTER: VIPER 2 Way w/ Fart timer!
ADD ONS: H1 Halo Projector headlights, Backdat ass up Camera, Dee Zee running boards, Chrome Bugger Grill, ExTang Solid Fold Tonneau Cover, Line of Fire w/reverse, custom bug shield/vent shades, TomTom GPS
TIRES/WHEELS: 265/75-16 Grabber AT2 Tires on 16x8 ATX series Teflon Coated Wheels
EXHAUSTS: BANKS Monster Dual Exhaust, EGR blocked & CAT removed with MBRP replacment pipe.
CAI: BANKS Ram Air
PROGRAMMERS: BANKS 6 Gun PDA w/Speed Loader --STACKED-- with Quadzilla Stealth 2more sissy stuff to be added!!!lol
Old 10-11-2008, 08:06 PM   eBay Motors   #6 (permalink)
daddysLBZ
Highway travler!!
Points: 6,295, Level: 33
Points: 6,295, Level: 33 Points: 6,295, Level: 33 Points: 6,295, Level: 33
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
daddysLBZ's Avatar
Talking I am picky,but never used synthetic
Never tried the synthetic stuff myself..Not that i don't trust the protective qualities,just I like to have the peace of mind drainin every 5k miles.That's just my opinion,synthetic oils have been proven to be superior in most cases..I use the
oil....Mobil 1 Delvac 1300 15-40
Filter....Mobil 1 ex perf..M1-303
MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350
WORK RIG:03 YukonXLHypertech tuned!!310k miles!
The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
Old 10-11-2008, 08:14 PM   eBay Motors   #7 (permalink)
Durallymax
Activity: 91%
Durallymax's Avatar
well i sand corrected on the deep pan. I woner why you are supposed to run one then with a Stage IV tranny??
I need it for the co-pilot too so it doesnt matter, its going on. It has to for my tranny to funtion properly.
The "Dieselholic"
Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
Old 10-11-2008, 08:21 PM   eBay Motors   #8 (permalink)
BigRedChevy
Post Slut
Points: 10,801, Level: 44
Points: 10,801, Level: 44 Points: 10,801, Level: 44 Points: 10,801, Level: 44
Activity: 100%
BigRedChevy's Avatar
I ran my stage IV for quite some time with the original pan. The only problem i have was that it heated up fast on the track.
KYLE
Old 10-11-2008, 08:25 PM   eBay Motors   #9 (permalink)
daddysLBZ
Highway travler!!
Activity: 47%
daddysLBZ's Avatar
Talking The deeper pan is for a reason/why ya think they require it,duh?
Right!The fluid will heat up sooner or later,but,the reasoning behind the pan is MORE to get hot/op temp.Deeper pan will cool a tad better,because it jus has more air flow on it.But good point pal!
If you are having cooler trans temps cause of the deep pan,then you go boy!!They recomend it for a reason,cause it works,and the cooling fims do function,otherwise what would be the point of SC requiring the pan??You have done the right thing IMO..If your trans is fine,then you have ZERO to be sorry for.Deeper pans also help the windage problems high perf trans encounter also[sloshing,not bein able to pick up fluid under hard corners,and rapid acc etc.]...The fluid can also stay fresher longer if there is more of it,nothing scientific about that..^^but don't tell him that..
Old 10-12-2008, 01:51 PM   eBay Motors   #10 (permalink)
Durallymax
Activity: 91%
Durallymax's Avatar
The factory deep pan doesnt have cooling fins. Its the same pan as the one on our trucks just deeper.
I needed the pan for th co-pilot because it will drain the stock pan.
The "Dieselholic"
Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
