Opti Lube XPD - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 01-25-2012, 05:05 PM Thread Starter
2006blackmax's Avatar
Opti Lube XPD
Just curious I run Summer Blend every tank, good for about 1-1.5 MPG ......Do it mainly for injector lubrication....Anyone else running it in thier fuel ?
2006 2500HD Duramax LBZ with Allison 6 Speed Allison
PullRite SuperGlide 5th Wheel
Merchant Auto Pump Rub Fix
HD Stainless TieRod Sleeves
3600 PSI Tranny Lines
DeepPan / FilterLock
MBRP DownPipe
Cat w /Adapter
AirDog 165
Transgo Jr.
MBRP 4''
2006blackmax is offline
post #2 of 9 (permalink) Old 01-25-2012, 07:54 PM
xaugievike's Avatar
I've got it in mine....my truck is new to me though...so only had it in for about 4 tanks though.
2006 Silverado 2500hd 4x4 CC/LB
LBZ
Silver
Banks Monster Duals
Banks Intake w/ Scoop
Line-X
xaugievike is offline
post #3 of 9 (permalink) Old 01-25-2012, 07:57 PM
rebpdt's Avatar
its one of the best there is based on the last article i saw.
i run standadyne in mine- its local and cheap
if all else fails i just grab diesel kleen at wally world
CCSB LB7 4x4
rebpdt is offline
post #4 of 9 (permalink) Old 01-25-2012, 08:15 PM
mackyoudip's Avatar
I use diesel kleen when I can afford it..optilube isn't as easily obtained so I settle for less..
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #5 of 9 (permalink) Old 01-25-2012, 09:14 PM
I do my fuel and my Jack 100% pure.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline
post #6 of 9 (permalink) Old 01-28-2012, 09:49 PM
steve142's Avatar
I run it in every tank. I buy it by the gallon and mix it 1/2 oz per gallon. A gallon last me about 5 months.
2004 Silverado LB7 CC SB LT, EFI Live DSP5 Tunes by Rob, Oil bi-Pass System, Airdog II 165, Nicktane CAT Adapter, MA pump Rub Fix, SunCoast G-Max 5-3, SunCoast 1056 3D Converter, Transgo, Allison Deep Pan/TranSynd, LML Exhaust Manifold, New Bosch Injectors, 6" RCD Lift W/Bilsteins, 35/12.5/20 Toyo MT's on 20x10 Moto Metal 955's, 4.10 Gears, MBRP turbo downpipe, MBRP 4" turbo back exhaust, Cognito braces, Rare Parts tie rods, Moog Idler/Pittman Arms, S&B CAI, Profab Turbo Horn, ISSPRO EV2 Boost/Pyro/Fuel Pres "A" Pillar gauges, PPE Boost Increase Valve,Tow Mirrors, Kenwood DDX418 w/Nav,Diamond Audio amps,subs and componets, 10" drop down DVD Player w/built in PS2, Remote start Alarm, 250 Amp HO Alternator..
steve142 is offline
post #7 of 9 (permalink) Old 02-08-2012, 08:49 AM
Devan4823Wise's Avatar
I run the XPD but ive done a little research and everyone ive talked to says its great stuff the people at Diesel Diagnostics said its the best bang for your buck
Devan4823Wise is offline
post #8 of 9 (permalink) Old 02-11-2012, 05:07 PM
I use both the Opti lube Summer additive and the Winter Additive. It worked out to be less expensive per tank buying both instead of the XPD. I actually recently ran out of the Winter additive and have been using Diesel Kleen.
My DPF and CAT just fell off so I changed the oil and added their oil additive also. I'm going to run the oil 8-10K and send in a sample.
EDIT: I don't believe in any MPG gains. Period.
'08 3500 GMC CC/LB/D/A/SRW
DuramaxTuner SPADE
DPF/DOC Delete
EGR Block/PVC Reroute
Transgo Jr./Transynd
CTS w/Turbo Timer
Air Ride Airbags w/Air One Wireless
Rancho RS900's
Aahhyes68 is offline
post #9 of 9 (permalink) Old 02-13-2012, 07:55 PM
2005DmaxCCSB's Avatar
Big fan of optilube
2005 Silver Birch Silverado Crew Cab 4x4 LLY Duramax Allison 98k miles. "Truck Norris"
5" turbo back MBRP exhaust, Afe MP, PCV Re-Route, Line-X, EFI Live 5 tune by GA Diesel with Edge CTS Insight switching them, Afe intercooler tubes, EGR blocked, S&B intake, BD exhaust manifold, EGT Probe, Diamond Eye thermal wrapped down pipe, PPE Tie rod sleeves , Merchant Automotive transfer case plate, Cognito steering braces, Chrome H2 Wheels, 285/70/17 Nitto Terra Grapplers and AirDog II 18mpg city, 24-25 highway!
2005DmaxCCSB is offline
