Gelled up - Chevy and GMC Duramax Diesel Forum
post #1 of 24 (permalink) Old 01-27-2012, 09:49 AM Thread Starter
Gelled up
This is the second time in 2 years the truck jelled up on me. This time the truck just shut off all at once one mile from home. It was 6 below zero outside. Both times I have had double doses of white bottle power service in the fuel. So power service does not stop the fuel from jellying below zero temps. I have been told to use 25% kerosene and I will not have to wonder if it will run. Is kerosene at 25% safe?
2013 chevy 2500 ecsb-stock
Lyman is offline
post #2 of 24 (permalink) Old 01-27-2012, 03:41 PM
I know a lot of folks who use the Schaeffer's Diesel Treat 2000 Winter Blend without any gelling products in colder temps than you mentioned. You should try it.
John Morgan is offline
post #3 of 24 (permalink) Old 01-27-2012, 03:44 PM
JUST TROLLING AROUND
vinnie gillotti's Avatar
Send a message via Yahoo to vinnie gillotti
i live in NH i use howes and have never gelled up. both in my dmax and my peterbilt
vinnie gillotti is offline
post #4 of 24 (permalink) Old 01-27-2012, 05:42 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
Did you have any bio in the fuel? If its available use Diesel #1. Iv used double dose of power service white bottle in -34F & my fuel never gelled.
HD Dmax Machine is offline
post #5 of 24 (permalink) Old 01-27-2012, 07:17 PM
zr600's Avatar
Yeah i was wondering if you were using the right power service. There is two different kinds.
08 2500hd cc sb bw with companion, firestone ride rites, cognito traction bars, cognito uca, fox performance shocks, cognito steering braces, and cognito tierods, bfgkm2 255/80r17.
Old truck 03 1500hd w4me tune, aem cai, 951 moto metal, 285/16 duratracs, bw and companion
zr600 is offline
post #6 of 24 (permalink) Old 01-27-2012, 07:22 PM
bluefx4flare's Avatar
You sure you gelled up?
Your fuel filter can also swell up with water and freeze choking off fuel delivery. Happened to me last winter, nicktane and Cat filter solved that problem.
Where you get your fuel also plays a big role.
Mark 2008 LMM Chevy Silverado 2500HD LTZ
MBRP DP MBRP SS 5" TB Exhaust Edge Insight CTS EGR Blocker EFI LIVE V2 DSP 5 Fumoto Fuel Filter Access Door Aluminum Bleeder Nicktane OEM Adapter Firestone Air Bags Toyo OC ATII 285/70/17 Chrome Boulder H2 Line X Weather Tech's, PCV Re-Route, DDM 6k HID Lows & Fogs.
bluefx4flare is offline
post #7 of 24 (permalink) Old 01-28-2012, 08:27 AM Thread Starter
I get my fuel at a hess station in johnstown ny. I am using the white bottle of power service sense october. The tank or the line under truck was jelled. I also have a uncle 20 miles away that jelled with the same fuel and single dose of white bottle. His went into limp and he made it home. No more fuel from that station and my nieghbor towed me home with his 2012 duramax with nothing in his fuel. He got his fuel from a mobil.
Lyman is offline
post #8 of 24 (permalink) Old 01-28-2012, 08:48 AM
Fuel that is not treated properly by the supplier and at those temps needs the entire bottle of White PS to be effective. But how are you supposed know how it was treated, it's a crap-shoot.
Lesson learned, stop buying fuel there and carry a fuel filter with you with tools to change it out and a bottle of Power Service 911. Would have saved you the tow.
Like I said earlier I use Cat filters now and have a fuel filter access door in the wheel liner. I never want to go through that again. -35C with the wife and 2 year old stranded out in the middle of nowhere and no heat.
Funny how Mobil diesel untreated was OK, Mobil up in Canada is Esso and that's the fuel I got screwed with.
post #9 of 24 (permalink) Old 01-28-2012, 09:37 AM
we are running arctic diesel or diesel #1--same as kerosene or stove oil. our pickups are down on power but will start at -45c with a little struggle... the operators of the big cats find a difference in power more so than the haul truck drivers..
2005 LLY C+ SB-->for sale
2013 LML CC
additions to come soon....
djmercer1 is offline
post #10 of 24 (permalink) Old 01-28-2012, 09:54 AM Thread Starter
I almost forgot, I added 2 bottles of 911 to the tank and let it sit for 1 hour and still nothing. No fuel was coming out of the bleeder on the stock filter.
Lyman is offline
