dealer injection cleaner - Chevy and GMC Duramax Diesel Forum
 1Likes
  • 1 Post By Dmax07classic
post #1 of 10 (permalink) Old 03-21-2012, 12:06 AM Thread Starter
had a balance test and the dealer said they could fix it with thier injection cleaning chem for $200. do they have something that great or will amsoil injection cleaner or something else eventually do the trick?
06 lbz 4" exhaust,fitch fuel catalist,juice,fs2500 bypass,amsoil in everything,pac brake,243k,ppe stage 4 trans,running 19.5 direct bolt ons
05 lly 4" exhaust,fitch,fs2500,amsoil,pac brake,246k,mike l stage 3 trans, running 19.5 direct bolt ons,amsoil in everything
vegas jake is offline
post #2 of 10 (permalink) Old 03-21-2012, 12:18 AM
mackyoudip's Avatar
I'd go buy a few bottles of diesel kleen and run 1 full bottle per tank for the next few tanks. (doesn't matter which size really)
Should be fine after that unless it is something really wrong.
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #3 of 10 (permalink) Old 03-21-2012, 05:12 PM
weldersd's Avatar
Can't remember the link, but a service tech said instead of the injector cleaning gm recommends, he would remove the filter, empty it, then fill it back up with marvels mystery oil, run that for a while, and repeat, re test balance rates.
04 silverado 2500 hd crewcab 4x4 lb7 FASS platnum lift pump, Nicktane adapter running cat filter, air horn port mod, everything else stock.
weldersd is offline
post #4 of 10 (permalink) Old 03-21-2012, 05:16 PM
Banned
Or you can buy the dealer cleaner for 18$ and the hoses for 15$ and clean your injectors up for 33$
ferdkila is offline
post #5 of 10 (permalink) Old 03-21-2012, 05:18 PM
marvels mystery oil = snake oil, it does absolutely nothing except ruin things. Please do a search on it on the internet. Don't use it! I'd be very wary of going to a place that had a service guy that said to use it
2012 Silverado 2500HD Duramax Long Bed Crew Cab
Real pickup trucks don't need stacks
RyanZ71 is offline
post #6 of 10 (permalink) Old 03-21-2012, 07:40 PM
weldersd's Avatar
Well, after I read it, I tried it after having some bad coking issues from running wmo, after I did this, there was noticeable smoother idle, and less smoke, MMO claims to be a carbon/injector cleaner, it worked for me, don't know the active ingredient, but i'm betting one of them is either MEKP, or the ams oil cleaner, I forgot what is called, derived from ethanol, if i'm not mistaken. I thought it was a good thing to do, from it being "oily" it would be ok to use directly as fuel, as with atf. not sure if I would try this with diesel kleen, or power service. I did exactly what I wrote to my lb7 and it seemed to work, for me anyways.
ps, I did a search as you suggested, I found a bunch of good stuff. http:///alternative-fuels-ad...stery-oil.html
weldersd is offline
post #7 of 10 (permalink) Old 03-21-2012, 07:47 PM
weldersd's Avatar
do a search on gm injector service, it's on here I read it. it's very easy to do the oe injector cleaning procedure, get a 15 dollar line tool, (ebay sells a muti size tool) the cleaner from gm and some hose clamps and hoses, idle your truck on the stuff mixed with d#2 and I hear it works well, 200 bucks, guess if you got more money than time, I know i don't.
weldersd is offline
post #8 of 10 (permalink) Old 03-21-2012, 10:42 PM
rms
rms's Avatar
Here ya' go:
How To: DIY - Injector cleaning
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/70/17 Michelin AT's on H2's - 8' Bedslide
Amp Steps - short KYB's - Fumoto
The Arizona Diesel Club
rms is offline
post #9 of 10 (permalink) Old 02-19-2015, 05:07 AM
How much mmo is everyone using in the filter?
68Ss likes this.
Dmax07classic is offline
post #10 of 10 (permalink) Old 02-19-2015, 05:41 AM
lsxzr2's Avatar
Don't use marvel. Go to that link above and do that, best thing you can do.
06 GMC 2500HD LBZ Debadged and Clean
Danville Stg2R billet turbo/ exergy 30% sticks/ EFI Live/ DSP5 / CTS Monitor/ FASS 150/ PPE shim kit/ TransGo JR/ DHD PCV re-route/ S&B intake/ SDP steel 3" Y-bridge & EGR delete/ Magnaflow Stainless Turbo Back/ DHD stainless DP/ LB7 Up-Pipe/ Moto Metal 962 20x12 with Toyo M/T
Big thanks to:
http://dirtyhookerdiesel.com/ http://atptrucks.com/
lsxzr2 is offline
