| Alternative Fuels - Diesel - Additives - Lubricants Discussion of diesel, its various additives, oils, lubricants and alternative fuels IE: Bio-Diesel ect... |
| Duramax Forum Supporter Join Date: May 2012 Location: West Virginia
| Where to buy opti-lube? Where do you guys buy your opti-lube?
__________________ 2006 2500HD LBZ ECLB EFI Live DSP5 By Idaho Rob |
| | eBay Motors #2 (permalink) | ||
| DuramaxForum Veteran Join Date: May 2011 Location: Somewhere in TX
| Only places I knw of is from Opti Lube's website, & Ebay. Im sure other vendors sale it just dont knw who.
__________________ 2009 Sierra 2500HD LMM SLE CC/SB 4x4 Stock. ![]() Pacer LED NBS Cab lights, Putco yellow bulb Fog lights, GM Dually light bar, Footwell lights, Tinted windows, GM chrome oval Running Boards, Fumoto oil drain valve, Bilstein HD shocks, PY0 wheels, Michelin LTX M/S2 LT245/75R/16E, Rear rubber Mud Flaps, Curt Hitch class IV, Kenwood speakers, Cobra 29 CB radio, Wilson 2000 CB antenna 2011 Silverado 2500HD LML WT EC/SB 4x2 Stock. (Co. truck) Quote:
| Senior Member Join Date: Nov 2010 Location: Shavano Park, TX
| Dmaxstore.com has it.
__________________ 2007 LBZ (Blocked and "fingerstuck", Tie Rod Sleeves, Pitman & Idler Arm supports, Pump Rub fix, Bilstein 5100s , Cognito UCAs, 4" Flo-Pro, PCV Re-routed, N-Fabs, Cabin Filter mod, Delayed Blower Module to dry evaporator, Power Steering cooler, Lux amp retrofit, and an HID Projector retrofit) 2006 Jetta TDI (daily driver) |
| Junior Member Join Date: Dec 2010 Location: Ms
| ^2 thats where I got mine from
__________________ Mike Classic LBZ|6"|Toyo AT Custom pearl paint S&B CAI|5" MBRP Exhaust|BD Power Pup|PPE Shim Kit|Profab EGR Delete|Profab DP|LML Manifold|PCV Re-route|Cobalt Boost & Pyro Bilstein 5100 & Stabilizer|Krypto Tie Rods|Moog Pitman|Idler Arms Mag Hytec Diff Cover DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| Senior Member Join Date: Jan 2012
| I get mine straight from opti- lube its way cheaper than the D-max store , no offense to them. Sent from a hand held banana boom-box
__________________ White,06,LBZ,GMC,CC,SB,SLT,82,***miles,17"XD Misfits,305/70-17 Terra Grapps,Leveled Cognito Balljoint UCA's,Alpine deck,Kicker ZX500.1,2-10" Kicker ,PCV reroute,Res. plugged,5"MBRP straight,S&B intake,pipe,6"MBRPTip,Gutted magnaflow cat,AFE MP,EGR blocker, slipyolk,Edge CTS, TransGo Jr,Pro Fab Performance downpipe,AFE IC pipe,Nicktane/donaldson ,FPR plug,Mhale LB7 pistons, LMM rods, clevet bearings and ARP head studs,DS max flow exhaust manifold,new#6 injector,Drilled FRF, Pump rub fix, new trans cooler lines,PPE deep tranny pan,new#6 injector,the motor getting installed By Adams HRC Thanks to him Hes the best in town has saved me lots of $$ http://adamshighrollincustoms.com/[/SIZE] |
| Duramax Lifetime Supporter Join Date: Nov 2011 Location: East Texas
| Buy mine from opti-lube website. No complaints.
__________________ 2012 lml cc/4wd Road Armor Lonestar Front Bumper, Warn 9.5k, Hella 7" and 4" HID's, Rancho 4" lift w/ 2 3/4" 9000s shocks, Cognito UCA's, 35" Trail Grapplers, RCD Sway Bar Links, Nfab 3step bars,front wheel spacers,sulastic shackles, MA sleeves, s&b c.a.i. dry filter w/ outer wear, resonator block plate, amsoil bypass kit, Fumoto drain valve, amsoil syn/ 15-40 motor oil, amsoil syn/ torque drive transmission, amsoil syn/ torque drive transfer case, fabtech stabilizer, opti-lube xpd, HID 55w 6k lows, L.E.D. bulbs throughout, H&S Mini-Maxx, H&S Pyrometer, Vumaxx mount, Autometer Cobalt Pyrometer, Diamond Eye down pipe, FASS Titanium 150, FASS custom filter cover, MBRP 5" Straight pipe exhaust, 6" Chrome MBRP tip, Custom overhead switches, Fuse banks INSTALL THREAD http://www.duramaxforum.com/forum/20...-2012-lml.html |
| Yea they have fast shipping to I think it's around $5-$8 for shipping Sent from a hand held banana boom-box
| Thanks a lot for all the replies guys. I just ordered from opti-lube. What do you guys think of the product?
| Duramax Lifetime Supporter Join Date: Apr 2012 Location: Cameron MT
| I've been using Opti-Lube since April when I bought our truck, so far, no negative effects, I use it with every tank fill and I am assuming it is doing a good job! I buy in gallons, enough to last for about 6 months or so.
__________________ 'MONGO' '02 2500HD 4X4 CC/SB Built transmission - GOS Performance; Suncoast 6 speed conversion 4" Exhaust aFe cold air intake BatMoWheel (stock turbo) ProFlow Air Horn, MBRP Downpipe Edge Insight CTS - EGT Probe; EFILive via CTS - Idaho Rob AirDog II DF-165 Firestone Ride Rite air helper springs Bilstein shockers Fumoto Oil Valve |
| Senior Member Join Date: Nov 2011 Location: NorCal
| Have you guys calculated out what it adds to your $/gallon of fuel every fillup to run the recommended amount of Opti-Lube? Do you see better mileage when using it to offset some of the cost? |
