| Alternative Fuels - Diesel - Additives - Lubricants Discussion of diesel, its various additives, oils, lubricants and alternative fuels IE: Bio-Diesel ect... |
| DuramaxForum n00b Join Date: Oct 2012 Location: Texas
| Willie, I was not correct about XL. you are correct and I meant Premium API CJ-4 15W-40. I am concerned about the AMSOIL bulletin saying that the recommended oil change is per the MFG recommendation: " AMSOIL published Technical Service Bulletin MO-2009-10-01 identifying high fuel dilution in 2007 and newer light duty diesel trucks. AMSOIL has revised the drain interval recommendation for these specific applications to the longest manufacturer-recommended interval. Oil drain intervals can be extended further with oil analysis. Please click on the following link for more information:http://www.amsoil.com/techservicesbulletin/MotorOil/TSB%20MO-2009-10-01_CJ-4_Fuel_Dilution.pdf" That is why I said about 10000 miles. I would appreciate you wise advice on this subject. I had issues with my 08 Duramax turbo which would wine so loud under a heavy load I thought it would explode. It would never show up when the GM dealer tried to diagnose it. That mechanic said it was due to not changing the oil often enough. I never solved the issue and traded the truck. I look forward to your input. Thanks |
| DuramaxForum n00b Join Date: Aug 2012
| Mrmanners, I think im going to go with the AMSOIL OE 15W-40, for starters wit a EaO52, and come spring ill switch to the 15W-40 Diesel & Marine, with a bypass kit. sound good?
__________________ 2006 Chevy LBZ CCSB LT3 |
| | eBay Motors #13 (permalink) |
| DF Sponsors ![]() ![]() Join Date: Mar 2009 Location: Kathleen, GA
| That works fine. I just replied to your pm. Sent from my DROID RAZR using AutoGuide App
__________________ Willie AMSOIL Premier Direct Jobber 06 LLY CCSB EFI Live |
| Disc Diesel Performance ![]() Join Date: Oct 2008 Location: So Calif.
| Amsoil is the oil of choice here too! We use it in everything we own.
__________________ ![]() 2013 Chevy CCLB 4X4 Victory Red email us Amsoil Distributor #1466322 Specialist in Longevity, MPG and Easy Maintenance Factory Authorized Nicktane Dealer Filters 4 your Dmax cheaper than most other Vendors Fumoto Valves, FilterMags, Fuel Filter Access Doors CAI, Exhaust, EFI Live by Kory Willis Your Satisfaction is Our Satisfaction! |
| | eBay Motors #15 (permalink) |
| Senior Member Join Date: Sep 2007 Location: Somerset, NJ
| Amsoil in my 2006 Ford Powerstroke...Amsoil 5w-40 all year long...Amsoil front 2 back in rest of my truck...only the best 4 her... Sent from my ADR6400L using AutoGuide.Com Free App
__________________ (Mike)2006 Ford F-350...Truck has goodies !!! |
| | eBay Motors #16 (permalink) |
| DuramaxForum Veteran Join Date: Jul 2007 Location: ObamaNation-Under the Dictator's rule
| You'll love the bypass filter setup, it keeps the oil so much cleaner! I used the billet oil filter adapter and the billet oil cap for the return on mine, along with their massive EaBP110 filter. .
__________________ Ham Radio= Global communications without airtime fees My Antenna-SteppIR Si Vis Pacem, Para bellum !!!! ======================== 07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod) --EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo --SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe --AMSOIL Synthetics and filtration bumper to bumper, including Bypass --DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs --PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes --Danville 3" Y Bridge and big air intake kit / EGR delete |
| | eBay Motors #17 (permalink) |
| follow up.... after a long wait, i changed my oil, been putting it off for a few weeks... now its done! runs a little quieter, but developed a very faint "typewriter-tick" I know its normal and from reading other post it "fades" away, how long dose that usually take?
| | eBay Motors #18 (permalink) |
| Junior Member Join Date: Dec 2011 Location: South Dakota
| I have been using amsoil in mine since I got it 8/06. Mrmannors how much for the bypass filter setup?
__________________ 06 LBZ 2500 LS CC/SB, Insite CTS w/ pyro, Banks Cold air, 4" MBRP, LED rev & dome lights, line-X, Ranch hand bumper, EFI live Idaho Rob, PCV reroute, HID |
| | eBay Motors #19 (permalink) |
| Junior Member Join Date: Oct 2012 Location: eastern high sierras
| im using amsoil too, change it every 10k..
__________________ 2006 1 ton 4X4 w/t..but i do have a ranchhand front bumper and hummer wheels!! |
| | eBay Motors #20 (permalink) |
| Senior Member Join Date: Jun 2010 Location: cincinnati ohio
| im with the rest of them i like the amsoil so much i run it in all are cars and i only do it 1 time per year on all of them my dmax the wifes jeep and my trans am.
__________________ 2001 gmc 3500 ext. cab duelly auto. mbrp 5" turbo back, ppe biv, pump rub fix, ats diff cover, amsoil in all, alligater turbo horn, airaid cai, and ranco 9000XL's GM DRW club member #7 |
