Amsoil! - Chevy and GMC Duramax Diesel Forum
Old 10-24-2012, 10:51 AM   eBay Motors  #1 (permalink)
Question Amsoil!
Long story short, my trucks is due for its first Oil Changes this weekend "For Me, 2nd owner", my plan is to switch over to amsoil, my intent is to use a bypass kit in the spring of 13, but for now just switching to a synthetic will have to do.
my question are...
what oil additive shall i use ( if any)?
are the worth the extra $$?
if so who makes the best quality additive?
best filter?
I also plan on doing the Allison spin on as well, and recommendations for that filter?
its a 2006 LBZ with currently 42000 on it.
Fj.jake is offline   Reply With Quote
Old 10-24-2012, 11:08 AM   eBay Motors  #2 (permalink)
KensAuto's Avatar
I personally will not use oil additives, amsoil a good choice....no expert on trans filter
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 10-24-2012, 12:27 PM   eBay Motors  #3 (permalink)
Amsoil is the best. Suggest using XL. I have been using it for 12 years in all my engines. Learned how good it was when a tech left my wifes oil fill cap off her Toyota 4 banger and found out after a 1600 mile trip with no engine damage.
I do not use additives, no need. Change about 10,000 miles, not 25,000 in a duramax until you get the bypass system.
I became a dealer also due to how good it is, but not looking for business on this forum.
You won't go wrong.
chipf2 is offline   Reply With Quote
Old 10-24-2012, 12:42 PM   eBay Motors  #4 (permalink)
StealthBoogie's Avatar
Get with Mrmanners for all your AMSOIL questions and products. He pretty much has every answer to every question and excellent prices
My LMM Build Thread
08' LMM CC SB SLE Z-71 4x4| Tekonsha P3| B&W Turnover| Tow Mirrors| POR 15| EDGE Insight CTS| AMSOIL| Diamond EYE 3" DP/ 4" DE QT Exhaust w/ muffler| PCV Reroute| Batmowheel| EGR Delete| LB7 Uppipe| EFI Live| LED Reverse/Cargo light| RetroSolutions 5k HID's| FX-R 3.0 Retrofit| Billet Valve Plugs| PCV & Resonator Plugs| Bills Custom Intake
Future Mods: 52 gal Titan Tank| FASS 150|Reverse camera| Audio Overhaul|Sound dampening kit| Weather Tech| Denali Grill| LML Denali bumper| LML Manifold| LML Step rails| Hood Vent| EGT Probe| Corsa Muffler| Tie Rods/ Sleeves.....
StealthBoogie is offline   Reply With Quote
Old 10-24-2012, 01:13 PM   eBay Motors  #5 (permalink)
KensAuto's Avatar
^^^Nice guy (mrmanners)
Old 10-24-2012, 02:03 PM   eBay Motors  #6 (permalink)
HD Dmax Machine's Avatar
No need for an oil additive.
Get an AC Delco oil filter, & Allison brand trans spin on filter.
2009 Sierra 2500HD LMM SLE CC/SB 4x4 Stock.
Pacer LED NBS Cab lights, Putco yellow bulb Fog lights, GM Dually light bar, Footwell lights, Tinted windows, GM chrome oval Running Boards, Fumoto oil drain valve, Bilstein HD shocks, PY0 wheels, Michelin LTX M/S2 LT245/75R/16E, Rear rubber Mud Flaps, Curt Hitch class IV, Kenwood speakers, Cobra 29 CB radio, Wilson 2000 CB antenna
2011 Silverado 2500HD LML WT EC/SB 4x2 Stock. (Co. truck)
Originally Posted by The Derp
Everytime "The Derp" gets a CEL the code comes back as ID10T, user error.
Originally Posted by John Caparulo
I went to Canada for 6 weeks. Everybody's French, which is creepy. People runnin' around, speaking French. I'm not used to that. I'm used to America, where everybody speaks Spanish.
HD Dmax Machine is offline   Reply With Quote
Old 10-24-2012, 04:29 PM   eBay Motors  #7 (permalink)
bigjohn's Avatar
Amsoil is great product. Now using Ea filter amsoil so far so good.
2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again.
2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ.
LET'S GO PENS!!!
bigjohn is offline   Reply With Quote
Old 10-25-2012, 02:11 AM   eBay Motors  #8 (permalink)
mrmanners's Avatar
my question are...
best filter?
For your 06 LBZ you will want to use 15W-40 Diesel and Marine oil from AMSOIL and their EaO52 oil filter. The oil is a full synthetic heavily fortified and designed for the older diesel engines requiring 40 weight. This is also an extended drain oil.
If you are not interested in an extended drain you should consider AMSOIL OE 15W-40 Diesel oil. This is a full synthetic AMSOIL came out with in 2011 for individuals looking for a high quality synthetic but not interested in extended drains.
The EaO oil filters are some of the best on the market offering filtration of over 98% of all physical contaminants down to 20 microns plus 2x the capacity of an OEM filter. Combine this with the oil above and your drain interval is up to 3xOEM (about 22.5k miles) or 1 year, whichever comes first. Guaranteed by AMSOIL. When you consider you are running 1 oil change over the life of 3 conventional oil changes you are saving money and I can help you with the pricing you see on the AMSOIL site, saving you an additional 25-35% off that.
No oil additives are required or recommended. The only thing I would consider it flushing your motor with AMSOIL Engine and Transmission Flush to clean up and sludge, vapor, varnish, old oil left behind from previous oil changes.
As far as filters go I offer filter packs from both WIX and Allison. If I can answer any questions, please don't hesitate to ask.
You won't go wrong.
Drain intervals for XL are 10k miles or 6 months with any filter.
I would not recommend XL oil in a diesel engine as it is not formulated for use in diesels.
I run 15w-40 Diesel and Marine in both my LBZ for 1 year. I average about 20-25k miles on a single oil change with no problem at all. In fact to prove that the oil was still good for continued use, I did two oil analysis over the a yr time frame and ended up putting 28k miles on a single oil change. I could have continued to run the oil but I chose to change it out.
If I can answer any more questions about AMSOIL products or help with pricing, please PM me or call 888-563-5143.
Willie
AMSOIL Premier Direct Jobber
06 LLY CCSB EFI Live
mrmanners is online now   Reply With Quote
Old 10-25-2012, 06:08 AM   eBay Motors  #9 (permalink)
Armalite's Avatar
Cant go wrong with willie or amsoil. Been running it in my lml for almost 20k miles. No problems. I'm running the bypass kit. I recently switched everything over to amsoil. Running it in my transmission, transfer case, and soon to be in the rear differential.
Im running both my lgh duramax one tons on amsoil. My big haul truck is running full amsoil - motor, tranny, rear ends, and my dump truck as well.
Very good stuff.
2012 lml cc/4wd
Road Armor Lonestar Front Bumper, Warn 9.5k, Hella 7" and 4" HID's, Rancho 4" lift w/ 2 3/4" 9000s shocks, Cognito UCA's, 35" Trail Grapplers, RCD Sway Bar Links, Nfab 3step bars,front wheel spacers,sulastic shackles, MA sleeves, s&b c.a.i. dry filter w/ outer wear, resonator block plate, amsoil bypass kit, Fumoto drain valve, amsoil syn/ 15-40 motor oil, amsoil syn/ torque drive transmission, amsoil syn/ torque drive transfer case, fabtech stabilizer, opti-lube xpd, HID 55w 6k lows, L.E.D. bulbs throughout, H&S Mini-Maxx, H&S Pyrometer, Vumaxx mount, Autometer Cobalt Pyrometer, Diamond Eye down pipe, FASS Titanium 150, FASS custom filter cover, MBRP 5" Straight pipe exhaust, 6" Chrome MBRP tip, Custom overhead switches, Fuse banks
INSTALL THREAD
http://www.duramaxforum.com/forum/20...-2012-lml.html
Armalite is offline   Reply With Quote
Old 10-25-2012, 03:14 PM   eBay Motors  #10 (permalink)
Willie, how good the Premium API CJ-4 5w40 oil? I believe this oil came out a couple of months ago.
2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids
tmm403 is offline   Reply With Quote
