2002 Chevy Duramax Front and Rear Diff. fluid - Chevy and GMC Duramax Diesel Forum
post #1 of 12 (permalink) Old 11-14-2012, 07:19 AM Thread Starter
I need to change my front and rear differential fluid but I am unsure on how much fluid to use and what the correct way to go about it. I am certain I could figure it out but I donít want to risk screwing anything up. I talked to a high performance diesel mechanic and he recommended Schafers synthetic 80/140 Is this a good choice? Any help is appreciated.
Thanks
Pete
2002 4 door Chevy Silverado 2500HD LB7
EFI Live w/ DPS-5 by Diesel Addiction
ProFlow Airhorn
5" FlowPro Exhaust
Mickey Thompson 285/70/17
Diesel Pete is offline
post #2 of 12 (permalink) Old 11-14-2012, 08:49 AM
Yes Pete, Schaeffers is about the best fluid you can buy. Your diffs are very easy to service. Both have a drain plug and a fill plug.
2002 LB7 Crew Cab Dually,AFE Cold Air Intake,Diamond Eye 5inch Down Pipe Back Straight Piped, Edge Insight, 40% Over II Injectors,
shovelheadsteve is offline
post #3 of 12 (permalink) Old 11-14-2012, 10:24 AM Thread Starter
Thanks, how much fluid do I need to purchase for the front and rear and what weight is recommended.
Pete
ProFlow Airhorn
5" FlowPro Exhaust
post #4 of 12 (permalink) Old 11-14-2012, 01:40 PM
So the recommended weight is 75-90 and you will need 6 to 7 quarts to do both differentials. You will wont to get yourself the little pump that goes into a 1 quart bottle to pump it into the fill hole on the diffs.
post #5 of 12 (permalink) Old 11-14-2012, 06:00 PM
Redline Shockproof...
06 LBZ 2500 4x4 Crew Cab EFI by Kory Willis
20x9 AR Fuel wheels with Nitto Rubber, PPE Sleeves, Fox 2.0's, Cognito Supports, Cold Air, 4" MBRP down pipe back, blocker plate, ADII 165, race plug, pcv re-route, resonator delete plug, Whelen Strobe Kit, limo tint.
FLDMAXMAN is offline
post #6 of 12 (permalink) Old 11-15-2012, 10:40 PM
Discount Diesel Parts
Dirtbikindad393's Avatar
Send a message via AIM to Dirtbikindad393
Diesel Pete...The answer to your question is the front diff will take just short of 2 qts 75W-90 and nothing else. The rear will take just short of 4 qts so you will have to buy 6 qts total of your fluid to service a 4wd and that takes into account that you have a stock rear diff cover.
Now the manual says use 75W-90 you may use 75W-140 as recommended by your guy but remember that the thicker the fluid the longer it takes to warm up in cold weather. It will also reduce fuel mileage slightly if you care about that. If you want to go inbetween that Amsoil makes a 75W-110 Severe Gear for a lighter weight oil than 140 but more protection than 90. I suggest you buy the hand pump to make the job easier and cleaner.
If you decide to use Amsoil Severe Gear warrantied for 100k miles please call me toll free 855-MAD-JACK and we will get you set up with what you need. We stock all 3 weights of Severe Gear 75w-90, 110,140 ready to ship.
www.madjackdiesel.com
Email or Call 855-MAD-JACK
Duramax Specialists
Save on all your Dmax Needs, Filters & Maintenance Items
Amsoil Distributor
We Offer Old Fashion Service!
Your Satisfaction is Our Satisfaction!
Dirtbikindad393 is offline
post #7 of 12 (permalink) Old 11-16-2012, 02:37 AM
bigjohn's Avatar
Amsoil is a great oil I have it in front and rear differential .
2006 GMC Sierra 2500 HD SLT ECLB, LBZ, LED tailights, black turn signals , black aftermarket headlights,265/75/16s uniroyal larados,Bilstein shocks,Banks 4inch exhaust, Nicktane adp, with a 3 micron Donaldson fuel filter, Schaffer's oil, pcv Re-route from alligator performance, Nicktane race plug, GM cab light,Banks 3 inch boost tube,And S&B air intake good to be driving a diesel again.
2002 2500 HD CHEVY Silverado ECLB LB7
bigjohn is offline
post #8 of 12 (permalink) Old 11-19-2012, 12:33 PM
gigem2012's Avatar
Would this be the same for my 2008 LMM??
Jeremy
2008 LMM 2500 4X4 LWB
--All stock
Fightin Texas Aggie
US Navy Veteran.
USS J.F Kennedy enroute to dock in Manhattan for fleet week. (Either '92 or '93)
gigem2012 is offline
post #9 of 12 (permalink) Old 11-20-2012, 10:26 AM
Yes it would!
Duramax Specialists
Amsoil Distributor
post #10 of 12 (permalink) Old 11-20-2012, 04:26 PM
Finally! Wheels on!
TexasRedNeck's Avatar
Pardon the hijack but with regards to synthetic in LSDs, is there anything to be concerned about? I've been a big Amzoil fan for a while now. I did have a complete bearing failure on the rear gear carrier in my gas 2001 CCSB 4WD with 100k on it while using Amzoil, but I'm not sure I'm ready to blame Amzoil given some of GMs bearing quality.
What about friction modifiers? Do you need them with synthetic, with the plates slip more with synthetic?
The Bus
Looking for OBS interior parts: Graphite color code. (1999-2004 IIRC) Door panels for sure, but let me know what you have
RedNeck Dually Build Thread
Dually Club Member #191
Originally Posted by OVERWATCH_09 View Post
The perfect storm of incompetence....Nothing more dangerous than a redneck with money.....
Originally Posted by Goose2448 View Post
It's really complicated sounding, but it's easier than giving a fat girl a bucket of ice cream.
TexasRedNeck is online now
