| Alternative Fuels - Diesel - Additives - Lubricants Discussion of diesel, its various additives, oils, lubricants and alternative fuels IE: Bio-Diesel ect... |
| Junior Member Join Date: Jun 2012 Location: Winston-Salem, NC
| Fuel Filter Bleeder Replacement Duramax Fuel Filter Bleeder Valve Anybody used or installed one of these? Guys in the shop are tired of getting diesel all over them when changing the fuel filters on our trucks. Plus the fact is greases everything up if you don't wipe everything down. Open to suggestions.
__________________ 2012 Chevy D/A CC LT Z71 ALL BLACK Stock...for now.:what |
| DuramaxForum Veteran Join Date: Aug 2009 Location: Maine
| Never seen that but not a bad idea. |
| Senior Member Join Date: Dec 2011 Location: Eldon, Iowa
| Never heard of them, but looks like it would work pretty good. Personally, I don't prime till fuel squirts out. I stop as soon as it starts to bubble, then tighten the bleeder and pump it till it is hard. Done!
__________________ 2005 ext cab sb LLY 4" exhaust w/muffler, EGR delete/Sinister diesel, Kodiak LBZ mouthpiece, PCV rerouted, Nicktane/CAT adapter, Autometer pyro & boost gauges, EFI Live by Kory, Transgo, pump rub kit, LBZ intake conv, H2's, Debadged |
| LHN...We ARE the Joneses ![]() Join Date: May 2008 Location: Awww-stin, TX
| Wad up a paper towel and press into the indention on the head to collect/soak up any fuel that spurts out. Works for me, my engine bay stays clean.
__________________ 2007 LBZ 3500 LT3 DRW Crew Cab, Sulastics, Putnam XDR 15K, B&W 30K-Turnover GN+Companion, Ride-Rite Air...EFI'd by Rob 2008 LMM 3500WT DRW Crew Cab, 8 'Flat/GN, Workforce Alum Toolbox, Ride-Rite Air, SulasticsUse-ta Haves 2006-6.0 3500 WT DRW ExCab Flatbed, 2005-LLY 3500 LS DRW Crew Cab, 2002-LB7 3500 LS DRW Crew Cab I Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh shit, he's awake!" |
| Disc Diesel Performance ![]() Join Date: Oct 2008 Location: So Calif.
| I use the drain on the wif sensor and drain the filter before I remove it. I can't stand getting fuel on my hands so a fuel filter access door installed in the inner fenderwell to RR the fuel filter and when filling it back up pump until fuel comes out the bleed screw close it and pump a few more times then wipe the fuel that came out of the bleed screw and its a done deal with no mess at all. For this reason we also designed a drain screw in the bottom of our Billet Wif Delete Plug. Fuel Filter Access Doors are found on the bottom of page 1 and top of page 2 depending on the year truck you have.
__________________ ![]() 2013 Chevy CCLB 4X4 Victory Red email us Amsoil Distributor #1466322 Specialist in Longevity, MPG and Easy Maintenance Factory Authorized Nicktane Dealer Filters 4 your Dmax cheaper than most other Vendors Fumoto Valves, FilterMags, Fuel Filter Access Doors CAI, Exhaust, EFI Live by Kory Willis Your Satisfaction is Our Satisfaction! Last edited by Dirtbikindad393; 11-27-2012 at 08:46 PM. |
