| Alternative Fuels - Diesel - Additives - Lubricants Discussion of diesel, its various additives, oils, lubricants and alternative fuels IE: Bio-Diesel ect... |
| Junior Member Join Date: Jun 2010 Location: Albertville, Alabama
| Used oil for fuel I was talking to a friend about using used motor oil mixed with gas and running it for fuel in my truck. I know the oil would have to be filtered and I think it was 1gal of gas to 7gal of oil. I didn't know if anyone knew of someone running this in a duramax. I have a 05 lly. This would be great since I could get free used oil any info would be great. Thanks Sent from my Autoguide iPhone app
__________________ 05' CC/SB LBZ mp 5" Black Stack PPE Standard 315 Bighorns Arb bumper DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| Senior Member Join Date: May 2012 Location: Ontario
| Mixing with gas do you mean diesel or regular unleaded?
__________________ 05 LLY EFI Live Built Trans Built Front End Supporting Mods |
| gas? stick with the green pump handle and some additives in every tank.. IMO
| | eBay Motors #4 (permalink) | |
| Senior Member Join Date: Feb 2011 Location: Fort Sumner, NM
| Quote:
__________________ 05' LLY 12.41 @109.9 Blake SDP Twinz, 40% overs, EFI-Live Props- Idaho Rob4'' Exhaust, Airdog, Traction Bars, Built Front End, Big Thanks to Dustin, Idaho Rob, and Scott 01' LB7 13.5@97 EFILive by me, Grade C HG, ARP studs, 4 in duals, S@B intake, Airdog, PPE boost valve, BT lock up box on stock trans ![]() | |
| I've heard of older diesels running on this combo, but I'm not sure how the high pressure injectors would like it. Is it really worth the risk? Why not just run the fuel that was meant to be in the truck. You don't want to have to replace the injectors, pump or worse the engine.
__________________ 05 LLY EFI Live Built Trans Built Front End Supporting Mods Last edited by andy-stevenson; 11-28-2012 at 07:07 PM. |
| | eBay Motors #6 (permalink) | ||
| DuramaxForum Veteran Join Date: May 2011 Location: Somewhere in TX
| x2.
__________________ 2009 Sierra 2500HD LMM SLE CC/SB 4x4 Stock. ![]() Pacer LED NBS Cab lights, Putco yellow bulb Fog lights, GM Dually light bar, Footwell lights, Tinted windows, GM chrome oval Running Boards, Fumoto oil drain valve, Bilstein HD shocks, PY0 wheels, Michelin LTX M/S2 LT245/75R/16E, Rear rubber Mud Flaps, Curt Hitch class IV, Kenwood speakers, Cobra 29 CB radio, Wilson 2000 CB antenna 2011 Silverado 2500HD LML WT EC/SB 4x2 Stock. (Co. truck) Quote:
| Rara Avis Join Date: Jul 2007 Location: Williston, VT
| Burn your waste oil in one of these instead... Used Oil Heaters | Waste Oil Furnaces | EnergyLogic
__________________ Paul in VT I used to own an ant farm but had to give it up. I couldn't find tractors small enough to fit it. -- Steven Wright NRA Benefactor 2007 GMC 3500 C&C with Hillsboro Aluminum Flatbed 2008 GMC 3500 Crewcab SLT 2012 GMC 1500 Crewcab SLT 2007 Saturn Sky Redline |
| bonfire starter....or ex girlfriends car when u change her oil, pocket her money for new oil. haha j/k
| Duramax Lifetime Supporter Join Date: Apr 2009 Location: Arizona
| Some of the guys doing the 4 cylinder Cummins swap have tried this. Along with the older 6.2 group. It needs to be warmed up and then filtered pretty well (down to 3 or 4 microns). Maybe more with the ash residue. Like the french fry oil crowd, some of them run a separate heated tank & switch over when the everything gets up to temp. Paul's right, though. With a free supply of oil . . . just add a garage to the house & heat it for no cost with a boiler.
__________________ 2007 LBZ 4x4 regular cab S & B Intake - Diablo Predator 285/75/16 Cooper ATP's - 8' Bedslide Amp Steps - Bilsteins - Fumoto |
| Senior Member Join Date: Apr 2011 Location: Corpus Christi, TX
__________________ Jacob 2008 SLE GMC C/C. 4" mbrp, FTE resonator, EFI from duramaxtuner, blocked and rerouted. CAT filter adapter with Donaldson filter. |
