Home heating oil - Chevy and GMC Duramax Diesel Forum
Old 01-23-2013, 05:13 PM   eBay Motors  #1 (permalink)
KentCountyCoal's Avatar
Home heating oil
This may be beat to death so please correct me or point me in the right direction if you can... But are there risks associated with running heating oil as alternative fuel? Where I'm from people often do this to skate around high diesel costs in dump trucks/commercial diesels. Will this be detrimental to my LLY? Thought about getting an aux tank and filling it to run as alternative on long trips. Thanks. maybe I'm
2005 ECSB LLY
EFI Live
4094 AVNT
Big Dipper 1058
Edge Insight CTS
Air Dog II 165 GPH
PCV, EGR, PPE Ported
Blade Runner MP, 5" MBRP, AFE CAI
KentCountyCoal is offline   Reply With Quote
Old 01-23-2013, 05:53 PM   eBay Motors  #2 (permalink)
1978steven's Avatar
Best to be careful doing something like that, the home heating oil they put in my tank here in NY is red dyed, I'm sure you get caught running that in your truck there are prolly pretty hefty fines associated.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, deep Allison pan, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's, 305/70-17 Nitto Terra Grapplers
1978steven is offline   Reply With Quote
Old 01-23-2013, 07:05 PM   eBay Motors  #3 (permalink)
yeah same in my home state... they're cracking down on the commercial use. Thought i might be sly about it at least for the winter and use the aux tank to mask it. i know the exhaust can be tested to check for it.. but my truck wont pass emissions either way. so i dont know... i just dont want to damage anything. from what i understand its essentially the same thing, maybe a different cetaine rating? idk...
2005 ECSB LLY
EFI Live
4094 AVNT
Big Dipper 1058
Edge Insight CTS
Air Dog II 165 GPH
Old 01-23-2013, 07:08 PM   eBay Motors  #4 (permalink)
Salt sucks
WVRigRat05's Avatar
It wont hurt it. Make sure its clean. other than that, the DOT.
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Motor died 1/19/12 190.131 mi.
Trans. died 7/27/12 200,136 mi.
Built motor/Trans and tuned by Blackout Performance
some parts to take it.
2011 30' Puma KDBSS
WVRigRat05 is online now   Reply With Quote
Old 01-23-2013, 07:14 PM   eBay Motors  #5 (permalink)
lol its funny you mention it cause my dad is a trooper and enforces this law, but still gave me the idea... go figure. even the people enforcing it know its a bull*&^ law to keep diesel prices ^
we agree with you
2005 ECSB LLY
EFI Live
4094 AVNT
Big Dipper 1058
Edge Insight CTS
Air Dog II 165 GPH
Old 01-23-2013, 07:28 PM   eBay Motors  #6 (permalink)
07durty's Avatar
its the exact same fuel just with red dye in it. I put some in my pickup once in a while from our farm tank, just keep it clear when pulling a trailer cuz that's when they dip you!
07durty is offline   Reply With Quote
Old 01-23-2013, 08:26 PM   eBay Motors  #7 (permalink)
Once you quit using the dyed fuel, How many tanks of fuel you'll need to run through your truck before they can't detect it anymore?
I understand that a visual test isn't the only way they detect it, but also through some sort of chemical means to detect the dye....
2003 2500HD Duramax CC LongBed 4x4 Falken Rocky Mountain ATS 265/75R16 (had: BFG AT KO 49,392 miles)
DSB'd: 2000 F250 Powerstroke ExtendedCab Shorty 4x4.
jblather is offline   Reply With Quote
Old 01-23-2013, 08:34 PM   eBay Motors  #8 (permalink)
Jacked_GMC's Avatar
Huge fines for using heating oil in CT and they take the plates off of your truck until you fix the issue. Also one of the companies that i worked for ran heating oil one winter, it ran a lot dirtier and tended to gell up faster in the winter than pump diesel.
2008 Sierra LMM
6" Skyjacker Lift
Banks Dual Exhaust
Diablo Sport Trinity Tuner
Jacked_GMC is offline   Reply With Quote
Old 01-24-2013, 04:36 AM   eBay Motors  #9 (permalink)
07durty's Avatar
It gelling up faster doesn't make any sense because "heating oil" is supposed to be straight #1 diesel.
Old 01-25-2013, 05:41 PM   eBay Motors  #10 (permalink)
Heating oil is very different than On-road diesel fuel. It can have up to 2000 parts/million sulfur content. Ultra Low Sulfur Diesel Fuel can have a max of 15ppm. The warnings you see about newer than 2007 trucks requiring 15ppm ULSD started showing up in 2006 when the EPA required a switch from the the standard of 500ppm diesel. So if you run heating oil in a new truck you could be running 133x more sulphur than the manufacture suggests. In 2012 New York State switched to Ultra Low Sulphur Heating Oil and other states will follow, but another concern is that Heating Oil does not have a minimum Cetane requirement (Centane is the diesel equivalent of Octane) so your performance could suffer.
Heating Oil is #2 Diesel. In winter diesel is blended with Kerosene which has a lower freezing point to prevent gelling. Heating oil is not.
So more than a few reasons to not use it.
spl642 is offline   Reply With Quote
