fuel additives? - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 26 (permalink) Old 01-27-2013, 06:17 PM
Jacqson's Avatar
Stanadyne Performance Formula.
2011 Silverado 3500HD SRW LML CCSB LTZ. Line-X over the Rail, Rockers and Side Steps, S&B Intake w/Donaldson Powercore G2 Filter & Scoop, Kennedy Twins/W Filter, Edge Insight CTS, Crown Performance SS Brake Lines, PPE Rear Diff Cover, Bushwacker Fender Flares, Cognito Leveling Kit with UCA's & Steering Braces, Rare Parts Tie Rods, Bilstein 5100's, KC Light Bar, Rigid Dually D2's, LT295/70R/18 Terra Grapplers, Allison Deep Trans Pan, Transynd, Suncoast Filter Lock, Retro Solutions 5000K HID's in my Fog Lamps, Snugtop Canopy plus a few other Goodies.
Jacqson is offline
post #12 of 26 (permalink) Old 01-28-2013, 05:01 PM
I hear (and read the test results) about Opti Lube being the best based on the results of a test. Wasn't that test conducted 5 or 6 years ago? Seems like I remember reading about it on another forum when it was done. If so, hasn't diesel fuel changed - ULSD as well as fuel additives? I'm not saying Opti Lube is bad, I've used it myself but has anyone conducted a more current test on fuel additives?
2011 Chevrolet 3500 Crew Cab Dually 4x4
Thumper7 is offline
post #13 of 26 (permalink) Old 01-28-2013, 05:26 PM
I use Lucas. Had my "garage guy" recommend it. And I got 1-2 mpg increase.
03 LB7, Tuned by Kory W., EFI with maxx effort, Edge CTS, PPE Stage 4 trans, American Outlaw wheels, Goodyear Wrangler 285/65/15,
odle57 is offline
post #14 of 26 (permalink) Old 01-28-2013, 05:39 PM
e46_330i's Avatar
It was conducted a few years ago, yes. Things have changes but Lucas hasn't. It's still garbage lol worse than used motor oil. Use Howes or Stanadyne. TCW3 is great in motors produced before ULSD was introduced.
LLY CCSB SLT 4x4
*EFI DSP5 By: PPEI *DE Downpipe & 5" Dump *ARP Studded *Pro-Fab Deleted *Custom Re-Routed *Alligator FPRV Plugged *DHD Braced & MA Sleeved *20x12 -44's *305/55/20 Terra Graps *LBZ MP, Intake & FPR *Kleinn Horns & On-Board Air *Paramount Restyling Grill hiding a 30" LunatecLED light bar *MA Pump Rub & M1 5w-30 *All-On Mod *PPE Boost & Pyro *Edge CTS W/Reverse Cam
Willie @ Synthetic Motorsports
Kory @ PPEI
Eric @ Merchant Automotive
Jason @ Alligator Performance
e46_330i is offline
post #15 of 26 (permalink) Old 01-28-2013, 06:08 PM
DuramaxForum Guru
HD Dmax Machine's Avatar
Coming soon. New Lubricity Additive Study
HD Dmax Machine is offline
post #16 of 26 (permalink) Old 01-28-2013, 09:50 PM
Optilube XPD is what I use. Got mine from Willie (Mrmanners). Easy to deal with and arrived at my doorstep in no time.
2011 Silverado CC LML LTZ Z71
Backup camera, LTZ Plus Package
Edge Insight CTS, Cognito Leveling Kit, Rough Country Steering Stabilizer, Goodyear Duratrac 275/70/18
SOLD 2005 Silverado CC LTZ, Z71, 6" Lift, Toyo Open Country 35"s
If you can read this,thank a Teacher. If you can read this in English,thank a Soldier.
yngbld32 is offline
post #17 of 26 (permalink) Old 01-29-2013, 12:14 AM
Banned
Originally Posted by HD Dmax Machine View Post
Very interested to see the results! Hope they include redline diesel fuel catalyst!
AZFIREGUY79 is offline
post #18 of 26 (permalink) Old 01-29-2013, 06:05 AM
Good to gear a about a new test. Curious to see the results.
Thumper7 is offline
post #19 of 26 (permalink) Old 01-29-2013, 06:10 AM
Banned
Optilube or Diesel Power Service is all that I will use. Neither has alcohol in it and both have been proven to increase lubricity. I usually use Power Service "grey bottle" bc it has added cetene as well as slickdiesel...
smokinlmm is offline
post #20 of 26 (permalink) Old 01-29-2013, 07:13 AM
Guest
2007
The following are the preliminary results of a research study on diesel fuel
be further commentary and explanation added at a future time.
PURPOSE:
The purpose of this research was to determine the ability of multiple diesel fuel additives to replace the vital lubricity component in ULSD (Ultra Low Sulfer Diesel) fuel.
HISTORY:
ULSD fuel is the fuel currently mandated for use in all on road diesel engines. This fuel burns cleaner and is less polluting than it’s predecessor, called Low Sulfer Diesel Fuel. Low sulfer fuel contained less than 500 ppm of sulfer. ULSD contains 15 ppm or less. As diesel fuel is further refined to remove the polluting sulfer, it is inadvertently stripped of its lubricating properties. This vital lubrication is a necessary component of the diesel fuel as it prevents wear in the fuel delivery system. Specifically, it lubricates pumps, high pressure pumps and injectors. Traditional Low sulfer diesel fuel typically contained enough lubricating ability to suffice the needs of these vital components. ULSD fuel, on the other hand, is considered to be very “dry” and incapable of lubricating vital fuel delivery components. As a result, these components are at risk of premature and even catastrophic failure when ULSD fuel is introduced to the system. As a result, all oil companies producing ULSD fuel must replace the lost lubricity with additives. All ULSD fuel purchased at retail fuel stations SHOULD be adequately treated with additives to replace this lost lubricity. The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems. For this reason it may be prudent to use an after market diesel fuel additive to ENSURE adequate lubrication of the fuel delivery system. Additionally, many additives can offer added benefits such as cetane improver, and water separators or emulsifiers.
CONTENT:
In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity. Additionally, claims of improving cetane, water separation or emulsification, bio-diesel compatibility and alcohol content will be noted. These notes were derived from information that was readily available to consumers (via the label and internet information) and none of this information has been evaluated for validity and/or performance. Cetane information has only been noted if the word “cetane” was used in the advertising information. The words “improves power” has not been translated to mean “improves cetane” in this evaluation. Information on alcohol content is provided by indicating “contains no alcohol”. Omission of the words “contains no alcohol” does not imply that it does contain alcohol. This information was simply missing in the information available to a consumer. However, the possibility of a form of alcohol in these products is possible. Additionally, information on dosages and cost per tankful are included for comparison purposes.
How Diesel Fuel Is Evaluated For Lubricating Ability:
Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar. The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better.
METHOD:
An independent research firm in Texas was hired to do the laboratory work. The cost of the research was paid for voluntarily by the participating additive manufacturers. Declining to participate and pay for the research were the following companies: Amsoil and Power Service. Because these are popular products it was determined that they needed to be included in the study. These products were tested using funds collected by diesel enthusiasts at “dieselplace.com”. Additionally, unconventional additives such as 2-cycle oil and used motor oil were tested for their abilities to aid in diesel fuel lubricity. These were also paid for by members of “dieselplace.com”. The study was conducted in the following manner: -The Research firm obtained a quantity of “untreated” ULSD fuel from a supplier. This fuel was basic ULSD fuel intended for use in diesel engines. However, this sample was acquired PRIOR to any attempt to additize the fuel for the purpose of replacing lost lubricity. In other words, it was a “worst case scenario, very dry diesel fuel” that would likely cause damage to any fuel delivery system. This fuel was tested using the HFRR at the Southwest Research Laboratory. This fuel was determined to have a very high HFRR score of 636 microns, typical of an untreated ULSD fuel. It was determined that this batch of fuel would be utilized as the baseline fuel for testing all of the additives. The baseline fuel HFRR score of 636 would be used as the control sample. All additives tested would be evaluated on their ability to replace lost lubricity to the fuel by comparing their scores to the control sample. Any score under 636 shows improvement to the fuels ability to lubricate the fuel delivery system of a diesel engine.
BLIND STUDY:
In order to ensure a completely unbiased approach to the study, the following steps were taken: Each additive tested was obtained independently via internet or over the counter purchases. The only exceptions were Opti-Lube XPD and the bio-diesel sample. The reason for this is because Opti-Lube XPD additive was considered “experimental” at the time of test enrollment and was not yet on the market. It was sent directly from Opti-Lube company. The bio-diesel sample was sponsored by Renewable Energy Group. One of their suppliers, E.H. Wolf and Sons in Slinger, Wisconsin supplied us with a sample of 100% soybean based bio-diesel. This sample was used to blend with the baseline fuel to create a 2% bio-diesel for testing. Each additive was bottled separately in identical glass containers. The bottles were labeled only with a number. This number corresponded to the additive contained in the bottle. The order of numbering was done randomly by drawing names out of a hat. Only Spicer Research held the key to the additives in each bottle. The additive samples were then sent in a box to An independent research firm. The only information given them was the ratio of fuel to be added to each additive sample. For example, bottle “A” needs to be mixed at a ratio of “480-1”. The ratio used for each additive was the “prescribed dosage” found on the bottle label for that product. Used motor oil and 2-cycle oil were tested at a rationally chosen ratio of 200:1. The Research Laboratory mixed the proper ratio of each “bottled fluid” into a separate container containing the baseline fuel. The data, therefore, is meaningful because every additive is tested in the same way using the same fuel. A side-by-side comparison of the effectiveness of each additive is now obtainable.
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend. Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
1) 2% REG SoyPower biodiesel HFRR 221, 415 micron improvement. 50:1 ratio of baseline fuel to 100% biodiesel 66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel Price: market value
2)Opti-Lube XPD Multi-purpose + anti-gel cetane improver, demulsifier HFRR 317, 319 micron improvement. 256:1 ratio 13 oz/tank $4.35/tank
3)FPPF RV, Bus, SUV
Gas and Diesel cetane improver, emulsifier HFRR 439, 197 micron improvement 640:1 ratio 5.2 oz/tank $2.60/tank
4)Opti-Lube Summer Blend Multi-purpose demulsifier HFRR 447, 189 micron improvement 3000:1 ratio 1.11 oz/tank $0.68/tank
5)Opti-Lube Winter Blend Muti-purpose + anti-gel cetane improver HFRR 461, 175 micron improvement 512:1 ratio 6.5 oz/tank $3.65/tank
6)Schaeffer Diesel Treat 2000 Multi-purpose + anti-gel cetane improver, emulsifier, bio-diesel compatible HFRR 470, 166 micron improvement 1000:1 ratio 3.32 oz/tank $1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil Unconventional (Not ULSD compliant, may damage 2007 or newer systems) HFRR 474, 162 micron improvement 200:1 ratio 16.64 oz/tank $1.09/tank
8)Stanadyne Lubricity Formula Lubricity Only demulsifier, 5% bio-diesel compatible, alcohol free HFRR 479, 157 micron improvement 1000:1 ratio 3.32 oz/tank $1.00/tank
9)Amsoil Diesel Concentrate Multi-purpose demulsifier, bio-diesel compatible, alcohol free HFRR 488, 148 micron improvement 640:1 ratio 5.2 oz/tank $2.16/tank
10)Power Service Diesel Kleen + Cetane Boost Multi-purpose Cetane improver, bio-diesel compatible, alcohol free HFRR 575, 61 micron improvement 400:1 ratio 8.32 oz/tank $1.58/tank
11)Howe’s Meaner Power Kleaner Multi-purpose Alcohol free HFRR 586, 50 micron improvement 1000:1 ratio 3.32 oz/tank $1.36/tank
12)Stanadyne Performance Formula Multi-purpose + anti-gel cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free HFRR 603, 33 micron improvement 480:1 ratio 6.9 oz/tank $4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used. Unconventional (Not ULSD compliant, may damage systems) HFRR 634, 2 micron improvement 200:1 ratio 16.64 oz/tank price: market value
14)Lucas Upper Cylinder Lubricant Gas or diesel HFRR 641, 5 microns worse than baseline (statistically insignificant change) 427:1 ratio 7.8 oz/tank $2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech Multi-purpose, canola oil based additive HFRR 644, 8 microns worse than baseline (statistically insignificant change) 1000:1 ratio 3.32 oz/tank $2.67/tank
16)FPPF Lubricity Plus Fuel Power Multi-purpose + anti-gel Emulsifier, alcohol free HFRR 675, 39 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $1.12/tank
17)Marvel Mystery Oil Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems) HFRR 678, 42 microns worse than baseline fuel. 320:1 ratio 10.4 oz/tank $3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive Multi-purpose Cetane improver, emulsifier, alcohol free HFRR 696, 60 microns worse than baseline fuel 1000:1 ratio 3.32 oz/tank $2.38/tank
19)Primrose Power Blend 2003 Multi-purpose Cetane boost, bio-diesel compatible, emulsifier HFRR 711, 75 microns worse than baseline 1066:1 ratio 3.12 oz/tank $1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association. Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel. Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated. Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
CREDITS:
This study would not have been possible without the participation of all companies involved and dieselplace.com. A special Thank You to all of the dieselplace.com members who generously donated toward this study and waited longer than they should have for the results. You folks are the best. Arlen Spicer, organizer.
Cayenne is offline
