Cheveron Delo 400 LE - Page 4 - Chevy and GMC Duramax Diesel Forum
 2Likes
post #31 of 67 (permalink) Old 04-24-2013, 11:55 PM
mackyoudip's Avatar
I like delo better than the rest. Maybe its because it is cheaper..usually.
also it seems to come out less black than rotella..i know that doesnt really mean much, but it makes me feel better..
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #32 of 67 (permalink) Old 04-25-2013, 04:27 PM
Fandango's Avatar
It's great. Mainly because it's sold so cheap at Costco.
2003 2WD CCSB LB7-Allison in Arrival Blue Metallic
Volant CAI
4" Exhaust w/Corsa muffler
EFIlive(20-20 tune)
Fandango is offline
post #33 of 67 (permalink) Old 04-25-2013, 05:00 PM
mikeyL's Avatar
ive always used delo in everything ive ever owned and everyone i know does to always been a great oil
2006 gmc ccsb efi live/dsp5, 4inch dual magnaflow turbo back cat delete, turbo downpipe, egr blocker, bd manifold, tie rod sleeves, leveling kit 20s and 35s hids low beams and fogs,smoked LED tail lights, air dog lift pump soon to come
mikeyL is offline
post #34 of 67 (permalink) Old 04-25-2013, 05:14 PM
Stupid Has The Balls
Odyssey25013's Avatar
Which Brand of Oil Do You Use?
Ben
2006 LLZ LT3 EC/LB
"Going for Broke"
Some Expensive Parts, Good Times, Busted Knuckles, Long Nights and Fancy Gauges So I Can Watch While I Blow Things Up
Special Thanks To Ben Tyler at BT DieselWorks, LLC. For All The Help and Hard Work
Odyssey25013 is offline
post #35 of 67 (permalink) Old 05-04-2013, 08:50 PM
Run Delo here too. Change every 10,000 miles and pulling 15000# 2500 miles per week. Have 2 friends who run it too. One is a diesel mechanic at an ambulance service and swears by it and the other is an OTR 18 wheeler driver and goes 30,000 between changes.
2005 Chevy 2500HD Duramax
lntransport is offline
post #36 of 67 (permalink) Old 05-04-2013, 09:20 PM Thread Starter
02Duramaxdually's Avatar
Well finally got around to run the Delo 400 after I changed the lower oil pan gasket, truck doesnt have the Duramax Tick no more an i noticed a slightly lower oil pressure drop as well. So far so good
2008 Chevy 2500HD CCLB LMM Duramax
Edge Insight CTS with Pyro
Allison Deep Trans Pan
B&W Goosneck Hitch & Airbags
285/75/16's
20% Tint all around with 40% Full Windshield
All stock for now, an staying that way, all emissions equipment still in tact.
155k an rollin
02Duramaxdually is offline
post #37 of 67 (permalink) Old 09-10-2013, 07:01 PM
Any Chevron Product is great. Rotella is good too. Stay away from Penzoil. Find what works good for you.
2003 LB7 4x4
K&N Cold Air Intake
Hypertech Max Energy sta
285/75/16
4 inch exhaust coming soon
pirate94 is offline
post #38 of 67 (permalink) Old 09-29-2013, 05:58 PM
jd424's Avatar
Used Delo 400 for ten years in my Cummins. Now I am trying to decide between the Delo and Delvac.
Thanks.
jd
2013 Silverado 2500hd ext. cab. LML.
jd424 is offline
post #39 of 67 (permalink) Old 10-06-2013, 11:16 AM
sleeprmax's Avatar
Just switched my whole fleet to Delo synthetic. I get it bulk but was cheaper than Rotella. See how it holds up
Andrew
2006 Chevy LBZ ECSB
EFI Tunas by Kory | S&B CAI | Banks Technicooler | Magnaflow 5" | Magnaflow Downpipe| Phantom IIs & Edge CS | Blocked/Rerouted/Capped | Nictane w/CAT Filter | PPE Fuel Fittings | AirDogII | Cognito UCAs | Zone 2'' Lift w/ Rear Blocks | Bilstein 5100s | BMF Novakane 20s | Nitto Terra Grapplers | Recon Cab Markers & LED Tails | Smoked Headlights | Boss V-DXT 8'2" Stainless
Running 285/70/17 Cooper Zeons on stockers for winter
sleeprmax is offline
post #40 of 67 (permalink) Old 10-06-2013, 10:05 PM
Trevamax's Avatar
I change at 5k and delo has been good to me. When I bought the truck it had the tick* and I switched to delo because I wasnt sure what was in there before. The tick went away for about 10k miles and now it's back slightly! So annoying!
2001 LB7 GMC Sierra 2500HD 4x4 SLE Federal,
S&B Cold Air
Michelin LT265 75r16
Merchant Auto TC Pump Rub Fix
Rancho 9000 XL's Front & Rear
Autometer Cobalt Boost & Pyro
Nicktane CAT Adapter
High Idle Mod
Stock Straight Pipe
35% Front Tint
Trevamax is offline
